How to remove the rear hatch?
insyncro
Banned
insyncro is offline
PostPosted: Sat Apr 19, 2014 6:41 am    Post subject: Reply with quote
madspaniard wrote:
insyncro wrote:
Classic VW has the boots available again.
Import item.
Thanks Dylan
I'll be in Europe this summer. How do you order stuff from Classic VW. I could bring some with me, small enough.
I call them and place the orders.
Not sure if they have an actual brick and mortar retail environment or not.
The second reason I call is that the inventory changes often and new parts become available before the site gets updated.
To make the shipping worthwhile for me, I make extremely large orders and have them package it for freight not parcel shipping.
madspaniard
madspaniard is offline
PostPosted: Sat Apr 19, 2014 6:23 am    Post subject: Reply with quote
Import item.
Thanks Dylan
I tried here but the part number did not turn in any results. The other problem is both the driver and the passenger side boots have the same part number but they are different.
http://www.volkswagen-classicparts.de/bestand/index_e.html
insyncro
Banned
insyncro is offline
PostPosted: Sat Apr 19, 2014 5:26 am    Post subject: Reply with quote
Import item.
madspaniard
PostPosted: Fri Apr 18, 2014 9:46 pm    Post subject: Reply with quote
Edited above, it looks like both boots are NLA
Part numbers
http://www.thesamba.com/vw/forum/viewtopic.php?t=568842&highlight=hatch
http://www.thesamba.com/vw/forum/viewtopic.php?t=538771&highlight=hatch
Some ideas to fix the boot
http://www.thesamba.com/vw/forum/viewtopic.php?t=576425&highlight=hatch
IdahoDoug
IdahoDoug is offline
PostPosted: Fri Apr 18, 2014 9:38 pm    Post subject: Reply with quote
Wow, talk about timing. I will be pulling my rear hatch to paint in a week or so. Timely thread - thanks for the info! Wolfram Grey here, as well!
DougM
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa project in pieces, 2002 BMW 325iX
greenbrier62
greenbrier62 is offline
PostPosted: Fri Apr 18, 2014 9:04 pm    Post subject: Gosh darn it...THANKS! Reply with quote
Hey thanks Insyncro...I figured they came off some how. I was able to use one of my picks to disengage the tab that holds the terminals on.
Also, thanks Goffoz for the tip on the boot.
Does anyone know the part number or where to get them? Maybe I'll call BD on Monday...
Thanks again!!
1987 Vanagon camper
2005 VW Passat TDI
1962 Chevy Greenbrier
madspaniard
PostPosted: Fri Apr 18, 2014 7:54 pm    Post subject: Reply with quote
goffoz wrote:
...I think passengers is smaller and NLA
Anyhow then you can install new boots and have easier access for wiring.
Yes, passenger side boot is NLA, so is driver side boot.
goffoz
goffoz is offline
PostPosted: Fri Apr 18, 2014 7:43 pm    Post subject: Reply with quote
If I recall correctly, the connectors are in the van, you need to pull the headliner at the hatch.
pull the door welting, and the fabric tape from the flange, if you pull the headliner down you'll see the connectors and a ground screw, in the door frame. It all comes off with the hatch.
While you have the hatch off, grind one of the boot holes to match the other. ....one side has a bigger hole,and that boot is still available
I don't recall which side Confused...I think passengers is smaller and NLA
insyncro
Banned
insyncro is offline
PostPosted: Fri Apr 18, 2014 7:26 pm    Post subject: Reply with quote
Get a terminal tool or make one to remove the plastic connector from the terminal end.
greenbrier62
PostPosted: Fri Apr 18, 2014 5:59 pm    Post subject: How to remove the rear hatch? Reply with quote
So...I'm stuck here. How do these wiring harness pieces fit through the holes so I can remove the rear hatch? As you might know, I'm re-painting...
This one is too big for the passenger side hole:
The pic is of the wiring that connects to the rear wiper motor. On the same lines, how do I pull off the wash fluid hose...just pull? Maybe cut it off?
Here is the defrogger (yes, defrogger) connection on the drivers side, same issue:
Thoughts? I've tried to pull the connector off of the wires...Is there a trick to that I'm missing? I'm pretty resourceful, but this has me stumped and I'm not interested in breaking more brittle plastic if I can help it...Maybe I'll just cut all the wires at their respective connectors and get rid of them all together?
Thanks in advance,
(By the way, Bostig reliability rules!!)
1987 Vanagon camper
2005 VW Passat TDI
