Trickle charger install?
Beeble1
Beeble1 is offline
PostPosted: Sat Apr 19, 2014 7:08 pm    Post subject: Trickle charger install? Reply with quote
A after trying to start my bug for the first time this year, the battery was dead. This isn't the first time this happened, it happened to me last year also.
So, I've seen those trickle chargers for cigarette lighters, but since the PO removed mine, can I wire a little connector to the fuse box to do the job? Or could I route the trickle charger through the diagnostic plug?
Beeble1, 73 Super (o\_|_/o) 1600cc w/ Dealer A/C
Beeble2, 13 Beetle 2.5l daily driver
Bishop-Wayne Volkswagen Kankakee, IL items wanted!
Turner Volkswagen Kankakee, IL items wanted!
View user's profile Send private message Send e-mail Twitter Gallery Classifieds Feedback
jderianSF
jderianSF is offline
PostPosted: Sat Apr 19, 2014 8:02 pm    Post subject: Re: Trickle charger install? Reply with quote
Most of the modern trickle chargers, (now called smart chargers, because they moniter the battery charge, and only charge when needed) come with connectors that can be attached directly onto the battery. You could leave the connector dangling out from under the back seat, and just connect it as necessary.
Jason
vernonc
vernonc is offline
PostPosted: Sun Apr 20, 2014 3:54 am    Post subject: Reply with quote
I would find out what is draining the battery while it sits and correct that. There's no reason to have to add a 'trickle charger' to any automobile if things are right. Just my thoughts.
mort
"Those who don't read newspapers are un-informed. Those who do read newspapers are mis-informed." Will Rogers
'69 sedan, low mileage, all original.....currently being 'freshened-up' for road trips and daily driving...just not every day
Freshening-up link http://www.thesamba.com/vw/forum/viewtopic.php?t=617386
pwmcguire
pwmcguire is offline
PostPosted: Sun Apr 20, 2014 4:15 am    Post subject: Reply with quote
Try this, remove the negative battery terminal and connect a test light between the battery terminal and the cable. If it lights, you have power flowing with the key off (= dead Battery) pull one fuse and see if it goes out, replace it and pull the next one. This will narrow it down to what circuit is drawing the power. You can do a closer inspection of that circuit.
andk5591 Premium Member
andk5591 is offline
PostPosted: Sun Apr 20, 2014 4:46 am    Post subject: Reply with quote
If the car was parked all winter without charging at all, its not real surprising - particulalry if you have a modern stereo head unit. And if its the same battery from last year, its already been damaged by the complete discharge - doing it twice makes it even worse. Do a little research on sulphating pltes on lead acid batteries.
I agree to test for parasitic loss, but your battery has been compromised some already.
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
Captain Jacques
Captain Jacques is offline
PostPosted: Sun Apr 20, 2014 5:08 am    Post subject: Reply with quote
I agree. I keep all the cars I don't regularly use on trickle chargers. You can also run the leads from the battery through a grommet in the firewall and have the connector in the engine bay for easy access.
Safe Sex: The Next Best Thing To Being There.
'75 Super Vert (Carbed)
1989 Lada Niva
2000 SL320 Panoramic
2001 Alfa 156 Sportwagon Selespeed
Globespotter
Globespotter is offline
PostPosted: Sun Apr 20, 2014 9:07 am    Post subject: Reply with quote
I bought a Battery Tender this year - it has a plug that you wire directly to the battery - small plug hangs out under the rear seat, and can be easily plugged in and out.
Worked like a charm!
1977 Westfalia - October 2015 - Current
1971 Super Beetle - May 2012 - Current
1979 Westfalia - 1986-1991
1971 Super Beetle - 1977-1980
Read the story about my Survivor Super Beetle: http://globespotter.com/survivor/
My 77 Westy M-Plate decoded: https://vw-type2-id.xyz/mplate/72067382
"You can save the world, but you funck one goat, what do you get remembered for" - markswagen
andk5591 is offline
PostPosted: Sun Apr 20, 2014 5:12 pm    Post subject: Reply with quote
I am too cheap to have a dedicated charger on each car (6 of them), I have a trickle charger and a regular charger that will do trickle charge. I just rotate them through the cars over the course of a week - about once every 6 weeks over winter. Used to replace the battery in our buggy every other year before I started doing this.
