Chassis tube diameters / dimensions
lightice
lightice is offline
PostPosted: Sun Sep 28, 2014 1:27 am    Post subject: Reply with quote
accelerator cable. 2400mm long, 8mm OD, 1mm wall thickness
clutch cable. 1845 mm long, 12mm OD, 1mm wall thickness.
handbrake cable 1535mm long, 12mm OD, 1mm wall thickness (2req)
heater control cable. 2775 mm long, 8mm OD, 1mm wall thickness (2req)
gear linkage rod. 1475mm long, 30mm OD, 1mm wall thickness
esde
esde is offline
PostPosted: Sat Sep 27, 2014 7:05 pm    Post subject: Reply with quote
I have some chunks of the tubes cut from my 65 saved. The accelerator, heater, and another mystery tube (choke?) are 8mm outside, 5mm inside. The emergency brake tubes are 12mm outside, 10mm inside. The clutch tube for the most part was MIA when I got it, but the holes in the chassis suggest 12mm also.
iamdonquixote
iamdonquixote is offline
PostPosted: Sat Sep 27, 2014 5:28 pm    Post subject: Reply with quote
yeah, this is for as John says "a belly pan bus"
j.pickens
j.pickens is offline
PostPosted: Thu Jun 05, 2014 8:42 am    Post subject: Re: chassis tube diameters / dimensions Reply with quote
Clara wrote:
j.pickens wrote:
Clara wrote:
iamdonquixote wrote:
Anyone have the specs on the OD/ID and length of the following chassis tubes:
accel cable tube
heater cable tube
fuel reserve cable tube
choke reserve cable tube
heater tube
clutch cable tube
e brake cable tube
thanks
there is no tube for the reserve or choke cable.
They just come in sheaths, which are tied to the bus with metal cable tabs.
Unless you have a belly pan bus?
mm ... now we need to look under and 61or older belly pan bus.
Observe:
BeaterBarndoor wrote:
Red Fau Veh wrote:
Clara Premium Member
Clara is offline
PostPosted: Thu Jun 05, 2014 6:04 am    Post subject: Re: chassis tube diameters / dimensions Reply with quote
accel cable tube
heater cable tube
heater tube
clutch cable tube
e brake cable tube
thanks
j.pickens
PostPosted: Wed Jun 04, 2014 8:21 pm    Post subject: Re: chassis tube diameters / dimensions Reply with quote
accel cable tube
heater cable tube
heater tube
clutch cable tube
e brake cable tube
thanks
Clara is offline
PostPosted: Wed Jun 04, 2014 6:53 pm    Post subject: Re: chassis tube diameters / dimensions Reply with quote
accel cable tube
heater cable tube
heater tube
clutch cable tube
e brake cable tube
thanks
MrBusCo Premium Member
MrBusCo is offline
PostPosted: Wed Jun 04, 2014 10:30 am    Post subject: Reply with quote
6th row down
http://www.alanhschofield.com/ourparts/cat_644528-Chassis-Underside.html
Josh The Bus Guy formerly known as JOGR
BlazeCutUSA.com MrBusCo.com
View user's profile Send private message Visit poster's website AIM Address Facebook Gallery Classifieds Feedback
crowlejo
crowlejo is offline
PostPosted: Wed Jun 04, 2014 9:09 am    Post subject: Reply with quote
Did anybody ever find this out? I also need it. I'm deployed and trying to gather parts for a project waiting for me at home. Everything was cut out of the cargo floor, including the tubes Crying or Very sad
iamdonquixote
PostPosted: Sun Apr 20, 2014 12:17 pm    Post subject: Reply with quote
I wonder if there is some tech doc from VW?
flemcadiddlehopper
flemcadiddlehopper is offline
PostPosted: Sun Apr 20, 2014 9:41 am    Post subject: Reply with quote
I'll try and squeeze under my '67 today and measure up the heater control tubes , throttle tube, and the clutch tube. No heater tube to measure as it was replaced with exhaust pipe.
Gordo.
Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others.
iamdonquixote
PostPosted: Sun Apr 20, 2014 9:24 am    Post subject: Reply with quote
I assumed they were all the same 55-67 except the shift rod tube.
60' - hence the choke cable and reserve cable tube
flemcadiddlehopper
PostPosted: Sun Apr 20, 2014 9:09 am    Post subject: Reply with quote
what year?
Gordo.
iamdonquixote
PostPosted: Sun Apr 20, 2014 8:31 am    Post subject: Chassis tube diameters / dimensions Reply with quote
accel cable tube
heater cable tube
heater tube
clutch cable tube
e brake cable tube
thanks
