Trouble with Big Bumpers and hitch mount bike carrier
SyncroPedro
SyncroPedro is offline
PostPosted: Sat Apr 26, 2014 5:26 pm    Post subject: Trouble with Big Bumpers and hitch mount bike carrier Reply with quote
Greetings,
Well, the gas tank seal project and fuel line replacement job is complete! Thanks to all who contributed so much to those instructional threads which allowed the noob to complete both jobs without much heartburn.
We're getting ready to make our first roadtrip in the new '86 Westy and I wanted to give a test fit of my Kuat hitch mount bike rack to the Van Cafe big bumper I have in the rear.
Well... the male 2" tang on the bike rack that fits into the female receiver went in perfectly, except for one thing! I need about another 1/2" of forward travel in that tang to get the holes to line up in both the rack and hitch mount so I can use the pin/lock to secure the rack to the bumper.
I'll try to upload the 3 photos I took showing how the FRONT of the hitch receiver is butted against the metal shroud that covers the muffler, below the license plate holder.
I think I'm going to need to "snip" that metal shroud on both sides of the receiver and bend the little 2" piece of metal forward so the bike rack tang will slide another 1/2" forward to get the holes to line up in the rack and mount. Then I'll be able to use the locking pin to secure the rack to the bumper.
All of this to say: I really don't WANT to cut that metal shroud! Any other thoughts about how I can get this to work? I hope the pictures load so you can see what I'm battling...
Thanks for your thoughts!
Pedro
In the picture above, you can see the receiver butting up against the metal shroud and the shroud is what stops the bike rack from sliding forward fully.
Above, you see the side view and holes in the receiver for locking pin.
j_dirge
j_dirge is offline
PostPosted: Sat Apr 26, 2014 5:48 pm    Post subject: Reply with quote
Cut the square tubing by 1/2" instead of snipping the sheet metal
And use an anti-rattle pin to secure the bike rack.
-89 GL Westy, still humming along under the power of a used "WBXer of mystery"
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote:
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
SyncroPedro
PostPosted: Sat Apr 26, 2014 6:23 pm    Post subject: Reply with quote
Well, I had hoped to avoid doing that as well, but I just spoke with a welder-friend of mine who has done precisely this thing on another bike rack. He just used an angle grinder and cut right thru it, so that may be the direction I go. Better than cutting up that shrouding! Thanks...
j_dirge
j_dirge is offline
PostPosted: Sat Apr 26, 2014 6:29 pm    Post subject: Reply with quote
It certainly is less than perfect, but you have lots of structure left in that tubing.
I have cut down a couple of hitch type receivers in different applications. and my current Vanagon receiver is maybe 4" long.
No signs of distress with a 4 bike rack on it.
j_dirge
j_dirge is offline
PostPosted: Sat Apr 26, 2014 6:34 pm    Post subject: Reply with quote
oops..
SyncroPedro
PostPosted: Sat Apr 26, 2014 7:00 pm    Post subject: Reply with quote
Wait!
I think I'm confused about your recommendation... I thought you were saying to cut off 1/2" of the end of the bike rack's male square tube so it would slide another 1/2" into the bumper receiver?
But I just looked into the open end of my bike rack tube and there's a long screw/nut device on the inside that acts as a cramming device to secure the bike rack to the inside of the receiver hitch. So shortening that bike rack tube is NOT going to work!
Back to the drawing board...
j_dirge
j_dirge is offline
PostPosted: Sat Apr 26, 2014 7:03 pm    Post subject: Reply with quote
SyncroPedro wrote:
Wait!
Can you post a picture of this jamming device?
Is it something that can be supplanted with an anti-rattle pine?..
The problem is that the cutting the sheet metal does not buy much space.. the muffler is right behind that sheet metal.. no?
Other option is for welder to cut off receiver and move it out 1/2 to 1"
That's not a big deal at all.. maybe one hrs labor.
SyncroPedro
PostPosted: Sat Apr 26, 2014 7:04 pm    Post subject: Reply with quote
J_dirge,
Now that I re-read your post I think you're talking about shortening the female receiver that's part of the bumper by 1/2"?
I don't see how that helps my cause? The male part of my bike rack is bumping into the body-colored shrouding in FRONT of the female receiver. Either the shrouding or the bike rack is the culprit, not the receiver.
Thx!
j_dirge
j_dirge is offline
PostPosted: Sat Apr 26, 2014 7:23 pm    Post subject: Reply with quote
SyncroPedro wrote:
J_dirge,
Thx!
If cutting the male tube on the rack does not work.. can you drill a new keeper pin hole?.. In either male rack tube or female receiver tube, so that new aligns with old (or vice versa)?
SyncroPedro
PostPosted: Sat Apr 26, 2014 7:24 pm    Post subject: Reply with quote
This is one of those situations where the photos were meant to help, but apparently they aren't doing the job.
If you look at the first photo, you can see where the front of the receiver bumps into the shrouding. Then, if you look to the front of that location (UP in the photo) you'll see metal and then 3 vent holes. Look thru the holes and you see my garage floor. I say all of this to indicate that there's plenty of room to trim that metal and allow the bike rack to slide fully into the receiver to the proper point.
It looks like that's where I'm headed, was just hoping to avoid cutting that metal shrouding. I can't see how else to accomplish it.
Thanks,
Pedro
kamzcab86
kamzcab86 is offline
PostPosted: Sat Apr 26, 2014 8:47 pm    Post subject: Reply with quote
^That's what was done to my GoWesty hitch because Dad didn't like how far out my Thule rack stuck (i.e. opposite problem OP has). Not too big of a deal, but a good drill and bit is needed. Surely that would work for the OP's situation too, instead of -yikes- cutting part of the van out.
Edit: I should note that my Thule's lock pin is a screw-in type, hence drilling the holes into the hitch rather than the rack.
~Kamz Anxious
2016 Golf GTI S
"I fear the day that technology will surpass our human interaction; the world will have a generation of idiots." ~Albert Einstein
SyncroPedro
PostPosted: Sat Apr 26, 2014 9:57 pm    Post subject: Reply with quote
Agreed, this is a better option than cutting that metal shroud, which is what I've been hoping to avoid all along! Looks like we'll be searching out one burly drill bit...
IdahoDoug
IdahoDoug is offline
PostPosted: Sat Apr 26, 2014 10:13 pm    Post subject: Reply with quote
Had precisely that situation on another vehicle with a bike rack. Drilled new holes in the bike rack's male portion, and moved the inner clip/tension thing. I brought my rack to a machine shop as that is tough hitch steel and you will spend more time trying to drill than driving over and back and you will wear out even a good bit and need a powerful drill. Push the rack in as far as it will go, take a nail and scratch the needed hole location through the hitch's hole, drop off the rack at a welder/shop. I think they charged me $15 to drill it.
Touch up with black paint to prevent rust.
DougM
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa project in pieces.
j_dirge
j_dirge is offline
PostPosted: Sun Apr 27, 2014 7:44 am    Post subject: Reply with quote
Yep.
My 4 bike rack has three draw-pin holes drilled for different placement "settings" depending on which of two vehicles it is installed on.. and if either vehicle may be carrying a trash bag on the rear mounted spare.
Having some adjustability is great.
I drilled these holes myself using a corded drill.. a newer bit and running it slow with some cutting oil. It did not take long (much less time than making the run to the shop) and doing it yourself allows one to set the rack to your liking and get it positively right. No guess work.
chatski
Location: Currently Columbus, GA. Will likely change often and with limited notice.
chatski is offline
PostPosted: Wed Dec 30, 2015 11:42 am    Post subject: Re: Trouble with Big Bumpers and hitch mount bike carrier Reply with quote
I ran into this same problem with the VC Big Bumpers and a Kuat bike rack. I ended up just pushing the rack in, and there was some 'give' to the body behind the bumper. It fit, scratched the paint a little, but I'm not incredibly concerned. If I had to, I would cut the body to allow space for the rack.
"Life's a battery. Charge it."
'86 Westfalia GL "Gertrude" (2010-present)
'86 Westfalia "Squatch" (2012-2015)
'89 Vanagon Carat "The Grizz" (2013-2015)
raoul mitgong
raoul mitgong is offline
PostPosted: Wed Dec 30, 2015 12:20 pm    Post subject: Re: Trouble with Big Bumpers and hitch mount bike carrier Reply with quote
That pin hole is about 1/2" in diameter so moving it only 1/2 an inch and you will have a very small web of metal between or overlapping holes. Overlapping will cause your drill bit to catch. You might have to drill it 3/4 or a full inch back.
That will put you close to the support plate so make sure you have clearance for the type of pin you are using.
Pilot drill it.
-d
84 Westy with a 2.1 (Groover)
86 Tintop Syncro (Crow)
86 Tintop Syncro to Westy project (Tom Servo)
91 Westy (Only the top 12 inches of this van (a burn victim))
j_dirge
j_dirge is offline
PostPosted: Wed Dec 30, 2015 1:06 pm    Post subject: Re: Trouble with Big Bumpers and hitch mount bike carrier Reply with quote
Grab a beer.. and a hacksaw and a finish file
Cut 1/4" off the end of the male part of the hitch accessory. The part that sticks in to the receiver.
Dinging up the sheetmetal behind may not concern you now.. But its a lot harder to repair it than it is to protect it.
0to60in6min
0to60in6min is offline
PostPosted: Wed Dec 30, 2015 1:26 pm    Post subject: Re: Trouble with Big Bumpers and hitch mount bike carrier Reply with quote
as suggested you have 2 options
- trim/cut the hitch
- drill new pin holes
have you consider a 3rd option?
- bend the metal shroud forward about 1/2"
Terry Kay
Banned
Terry Kay is offline
PostPosted: Wed Dec 30, 2015 2:15 pm    Post subject: Re: Trouble with Big Bumpers and hitch mount bike carrier Reply with quote
Boy, a lot of Merry go Rounding here.
Take the bumper off, cut the damned inside of the receiver off so it doesn't beat on the lower valance panel.
Then adjust the length of the hitch bar to fit the hole.
That does look like a horses ass set up.
Try loosing the bumper bolts and yank out on the bumper to see if it will slide out a hair to get it off of the body panel.
Somebody wasn't watching what they they were doing prior to mounting the bumper--maybe.
No drilling the pin holes required.
Want to drill them anyway?
Try a drill press.
The hole will be dead nuts straight & true.
T.K.
