128vw Samba Member
Joined: April 05, 2006 Posts: 222 Location: Western Massachusetts
Posted: Mon Apr 28, 2014 3:45 pm Post subject: FK8 with 1.3 rockers |
I started to build my 2334 about 6 years ago, bought most of the parts,. AJ Sims 041 heads ported, Fk8 cam. Got the case together, heads on and had major health problems. Just getting back to it now. I had bought ,a set of rockers that were supposed to be CB 1.4. Now when I check them they
only give a valve lift of .480 which is about only 1.3.
There are no markings on the rockers, the mounting hole is offset and the adjusters are on the push rod side. The standoffs are about .100 higher
than stock and the mounting studs are too short They look like the ones shown on CB's site.
How can I tell who made these? Will these rockers work with the FK8 cam?
Do I need to run valve caps? Are longer mounting studs available?
Thanks, Tom |
fastfil Samba Member
Joined: November 25, 2006 Posts: 356 Location: Sunshine Coast, AUS
Posted: Mon Apr 28, 2014 4:43 pm Post subject: |
My CB 1.3 rockers came with longer rocker studs. Removing the original studs from my new 044s was an absolute bitch fight though. Ended up welding up and down the old studs (what was left after snapping) to breakdown the thread locker. I'd love to know what they use.
Do some measuring and you should easily be able to work out their ratio.
I'd use lash caps on any motor with greater than stock valve lift.
1.3 rockers on an FK8? Depends on the application. Sure it will work, and it would have to prolong the life of your valve train. But, are you trying to get all the hp you can get out of your motor? _________________ "...swingaxle...transaxle...same diff." |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Mon Apr 28, 2014 5:33 pm Post subject: |
You can safely run smaller 1.1, 1.25, or 1.3 rockers on any cam ground for 1.4 or 1.5 rockers. You are in effect just making the cam smaller. You will wear stuff out quickly running 1.4 or 1.5 ratio rockers on a cam that was ground for 1.1 or 1.25 rockers.
I'm running CB 1.3 rockers on my 2165 with an FK-8 cam. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
mark tucker Samba Member
Posted: Mon Apr 28, 2014 9:04 pm Post subject: |
studs stuck?? never seen that before most were loose or cam out oh so easy.I ran 1.25 on my fk8 in my 1874.ran great. |
128vw Samba Member
Posted: Tue Apr 29, 2014 11:52 am Post subject: |
To adjust rocker height with the CB rockers with the adjuster on the push rod end do you line up the push rod with the adjuster at half lift? |
Posted: Tue Apr 29, 2014 12:28 pm Post subject: |
I dont. the cb's Ive used were very close out of the box, but that was on new heads.I removed about.040" from the rocker blocks to lower the rockers to get just what I wanted. I go off the foot print/contact patch.I would rather have the pushrod&adjuster inline lator in the lift cycle where theres more pressure. |
filmfolks Samba Member
Posted: Fri Jul 28, 2023 9:45 am Post subject: |
vwracerdave wrote: |
I'm running CB 1.3 rockers on my 2165 with an FK-8 cam. |
Thanks Dave. |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3462 Location: Paradise, Ca
Posted: Fri Jul 28, 2023 10:53 am Post subject: |
mark tucker wrote: |
A great point that many dont get. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7214 Location: Videbaek Denmark
Posted: Fri Jul 28, 2023 12:32 pm Post subject: |
jpaull wrote: |
A great point that many dont get. |
X3 _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
nsracing Samba Member
Posted: Sat Jul 29, 2023 3:30 pm Post subject: Re: FK8 with 1.3 rockers |
I have talked about that point -in line adjuster vs. pushrod at full lift -for many years, and many thought I was crazy.
Slightly over at top of lift works too but not too much - a smidgin.
People be running half-inch lifts, good gracious! That is a lot of herky-jerky!
Yes - we could all use a more stout rocker studs. That is one spot we never got for years. The biggest bolts I have seen came from Pauter. Does any shop produce something similar now without breaking the bank?
Have not been posting in a while. Is Tucker and Modok behaving themselves? |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Sat Jul 29, 2023 4:58 pm Post subject: Re: FK8 with 1.3 rockers |
fk8 with 1.3 rockers
It's been done many times and mostly works good.
SCAT pro-comp or autocraft 1.25 rockers end up at a 1.3 approx ratio because they got the geometry slightly wrong. Or maybe even before that. In any case, it's always been that way, and still is.
There are 1.3 rockers (aftermarket with adjuster on pushrod)
and 1.2 rockers (stock style with pushrod hole moved),
1.25 rockers almost don't exist, but the new CB stock style ones are close, and you'd think that's a good thing but actually it isn't, because the pushrods end up fouling the tubes worse than ever, which is ironic. |
