bstroop Samba Member
Joined: September 06, 2013 Posts: 12 Location: Klamath Falls
Posted: Mon Apr 28, 2014 5:23 pm Post subject: Different Nankang series? |
I've been searching for Nankang tires and haven't been able to find a similar series to match front and back.
Front 145r15 is CX668 series
Rear 185/65/15 Is XR611 series
Does anyone know where I can find a matching set? Or is it common to run different series? |
Posted: Wed Apr 30, 2014 7:15 pm Post subject: |
Awesome......thanks for the help.
Lots of research before asking questions on my 2 posts.
I'll just wing it. |
spotfreerynse Samba Member
Joined: November 09, 2007 Posts: 440 Location: ROCKWALL TX
Posted: Tue May 06, 2014 12:17 pm Post subject: |
Hey there , you can run same brands , but not in 145's they are pretty exclusive to a couple of manufactures I think , unless the rears are nankangs ... . Just go to a 145/65/15 or 155/60/15 in front , and find rears in the same brand . Hope This helps . FYI , Ive never had same brand all the way around . : ) |
Posted: Tue May 06, 2014 7:54 pm Post subject: |
Thanks,
I continued to search different brands and found a matching set of yokohama Envigor's that look pretty nice.
145/65 front
185/65 rear
Wheels, tires, spindles, tie rod ends, bearings etc. all showed up today. Can't wait to start. |
GearHeadKeith Samba Member
Joined: January 14, 2003 Posts: 112 Location: Detroit, MI
Posted: Wed Jul 14, 2021 7:06 pm Post subject: Re: Different Nankang series? |
The traditional Cal-Look set-up is 145SR15 (same as a 145/80R15) front and 165SR15 (165/80R15) rear. Three tires are currently available in this size combination:
Nankang CX668
Firestone F560 (sold by Coker Tire)
Micheline XZX (sold by Coker Tire)
If you want a 145/80R15 front tire, those are your choices.
If you can fit a wider front tire, a 175/65R15 front & 195/65R15 rear gives the same look (same overall diameters as 145/165) with a wider footprint. Continental used to make matched tiers in these sizes. _________________ Keith Gilbert - DdK
1971 Super Beetle sedan, Shantung yellow with black interior. Cosmetically unrestored with over 366k miles.
1776cc: 9.2:1 compression, dual Weber 40DCN on Deano intakes, Primo Petrucci 40mm/36mm round-port heads, Crower VW284F cam, Kymco 1.5" exhaust
SSC trans with 3.78/2.25/1.48/1.04 & 4.12 Gleason R&P, Type IV output flanges, Berg Shifter
Topline front struts/springs/sway bar, Sway-a-Way rear bar, 4-wheel disc brakes
Owned since 1994: 3rd owner since new! |
Slow 1200 Samba Member
Posted: Fri Jul 23, 2021 1:31 am Post subject: Re: Different Nankang series? |
I recently got 145s and 165s for my 67, they are Nankangs but instead of the CX668s they are "Econex", which have a different tread pattern |
