Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 679 Location: SE Oklahoma
Posted: Tue Apr 29, 2014 12:54 pm Post subject: Tow bar angle to hitch |
what do you think about the angle of the tow bar to the hitch? Do I need to get a receiver hitch adapter to lower it?
_________________ 1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to." |
risk Samba Member
Joined: June 24, 2004 Posts: 710 Location: Stumpbroke, Arkansas
Posted: Tue Apr 29, 2014 1:01 pm Post subject: |
If you go accross a dip in the road or a sharp incline the bar might hit the body or bumper on the car and could cause some damage... I have towed with a similar setup and actually lifted the front end of the bug off the ground pulling in a steep drive..
It will be ok if you keep that in mind and avoid those situations..but yes, a drop hitch would be better. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31373 Location: Hot Arizona
eburciaga11 Samba Member
Posted: Tue Apr 29, 2014 11:11 pm Post subject: |
I work at uhaul, we sell recievers that have different drops. Fairly priced 25-30 dollars |
Cusser Samba Member
Posted: Wed Apr 30, 2014 7:05 am Post subject: |
Thanks everyone. I took your advice and went out and bought this adjustable hitch from Northern Tool for $50. Ranges from an 8" drop to a 7" rise. Exactly what I needed!
http://www.northerntool.com/shop/tools/product_200442407_200442407
1966 Beetle 1300
1971 Super Beetle
1974 Thing
EVfun Samba Member
Posted: Wed Apr 30, 2014 4:31 pm Post subject: |
The main reason to shoot for a nearly level hitch is braking. The hitch pivots at the lower torsion tube and at the ball. If the ball is a lot higher then when braking the bug will lift the back of the truck, cutting into stopping power and control. _________________
Wildthings wrote: |
