Big Papi Samba Member
Posted: Fri May 02, 2014 9:29 am Post subject: Replace air duct |
Looking to replace the long air ducts that run from the back to the front. Anyone know the proper term for these? And where I could find suitable replacements?
Thanks,
Matt _________________ 1978 ASI Riviera
TypeIV FI |
sallittjob Samba Member
Joined: September 16, 2010 Posts: 340 Location: North NJ
Posted: Fri May 02, 2014 9:32 am Post subject: |
As far as I know you can't get the factory replacement anymore.
Most people use aluminum dryer exhaust hose wrapped in insulation. Hopefully someone can let you know what size you need. _________________ 57' Beetle Deluxe
1192cc SP
71' Super Beetle
1968cc DP
73' 412 Sedan
1679cc FI
75' Westy
1800cc FI |
Hummer Samba Member
Posted: Fri May 02, 2014 9:44 am Post subject: Silicone Tubing |
An alternative is to use 3" silicone tubing. It is weather proof and retains the heat very well. I haven't done the upgrade myself, but my good friend has. He drives his bay year round and swears that he has toasty heat now.
Not sure how he mated the tubing to the heater boxes. I've talked to my dad who is a machinist about manufacturing an adapter that would handle that interface. Just haven't drawn it up in NX yet to get to him.
I can probably get Ryan to share some details about his setup if y'all are interested. He said it wasn't cheap to buy that tubing, but wasn't hatefully expensive either. Can't remember what he had $-wise in the setup. |
Posted: Fri May 02, 2014 9:57 am Post subject: |
I have light weight stovepipe which I cut the mating edge off of and then refastened to size using sheet metal screws. The whole thing is wrapped in self stick close cell foam and then covered with split PVC sewer pipe. Very durable.
The biggest problem with fixing the pipes is if the wye pipe in the back is rusted out. If so I would advise splitting the system so one heater pipe feeds directly into the cabin under the rear seat and the other feeds through a modified center pipe. (even if your wye is in good condition splitting the system is a good idea as you get way more total air flow this way.
My bus is short sleeve comfy at 15*F while highway driving. You just don't want to block the under seat outlet with anything that can be damaged by heat. I am not sure what temperatures I get from the under seat outlet, but I suspect they may come close to 300*F on a hard pull. |
dorney Samba Member
Posted: Fri May 02, 2014 1:39 pm Post subject: |
I have a new metal center/main heat duct if you want to buy it. PM me and I will send you a photo after I get home from work. Was going to use it but now I don't need it.
Mike _________________ Mike D.
'78 Bus |
70Crew Samba Member
Joined: June 12, 2006 Posts: 776 Location: Grand Rapids, MI
Tcash Samba Member
Hummer Samba Member
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Mon Feb 19, 2018 7:39 pm Post subject: |
TCash- This link does not work. _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Tue Feb 20, 2018 8:19 am Post subject: Re: Replace air duct |
This is a piece of double-walled stove pipe that worked well:
_________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
DougB Samba Member
Joined: January 09, 2007 Posts: 1076 Location: Falls Church, Virginia, USA
Posted: Tue Feb 20, 2018 1:29 pm Post subject: Re: Replace air duct |
Wow, you could eat dinner from the underside of that bus SOOOO clean!
- Doug _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
A very, very understanding wife |
Abscate Samba Member
Posted: Tue Feb 20, 2018 3:25 pm Post subject: Re: Replace air duct |
jtauxe wrote: |
Thats why its called B-Vent, because its for Vans...I mean, Bussess _________________ .ssS! |
jtauxe Samba Member
Posted: Tue Feb 20, 2018 4:04 pm Post subject: Re: Replace air duct |
DougB wrote: |
- Doug |
If you liked that, you will love this... A bit of a teaser for the build thread that I really must build some day soon... Here is the undercarriage after bracing (to strengthen the body after adding a fourth door to this double cab) and paint:
http://vw.tauxe.net
DougB Samba Member
Posted: Wed Feb 21, 2018 8:48 am Post subject: Re: Replace air duct |
Oh geez, that's nice! I feel like mine could use the same treatment after spending some time under the chassis last night. Good news is that the rockets were all still nice on the outer and inner sides. Bad news is that I need to replace the driver's side rear jack point (not like I use it anyway, though). The square tube has rusted out on the bottom. _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
RalphWiggam Samba Member
Joined: February 02, 2018 Posts: 906 Location: SouthEast
Posted: Wed Feb 21, 2018 9:24 am Post subject: Re: Replace air duct |
I used a 4ft piece of 2.25" stainless steel tubing from Amazon. That along with (2) 3" to 2.25" silicone couplers from Amazon. Total for everything was about $60 and should last forever. |
Posted: Wed Feb 21, 2018 11:51 am Post subject: Re: Replace air duct |
RalphWiggam wrote: |
Got links and photos? _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
DougB Samba Member
Posted: Wed Feb 21, 2018 12:25 pm Post subject: Re: Replace air duct |
You know, I'm thinking that your tires are too small for that van _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
Posted: Wed Feb 21, 2018 12:43 pm Post subject: Re: Replace air duct |
BUSBOSS wrote: |
Got links and photos? |
Thanks! _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
