SCM Samba Member
Joined: January 26, 2011 Posts: 3118 Location: Bozeman MT
Posted: Sun May 04, 2014 2:55 pm Post subject: How's the 4-prong Westy slider switch work? |
Hi Volks,
One of the interior lighting upgrades I would like to do is to add lights that will be switched on when the slider is opened. I know some vans had a dedicated switch on the slider that did that but mine does not. I do have a 4-pronged switch that I assume is only there to power the power door lock.
One of the 4 prongs doesn't have a wire going to it. I don't know much about automotive wiring or wire diagrams, plus my Bentley is on loan to a friend. Do any of you have some suggestions for how I can rig the OEM style (3 position) door lights to operate using this switch? What does each prong of the switch do? Thanks!
_________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Yellow Rabbit Samba Member
Posted: Sun May 04, 2014 5:15 pm Post subject: |
I think the campers are not wired with the switch so it doesn't drain your battery when camping. There was a VW switch that you could depress and disable the lights from coming on. I think maybe this was on second gen Golf trunk lights. Maybe this could be adapted. |
toomanyveedubs Samba Member
Joined: November 26, 2007 Posts: 596 Location: Great White North
70coupyel Samba Member
Joined: September 06, 2006 Posts: 1657 Location: So.Cal
Posted: Sun May 04, 2014 7:21 pm Post subject: |
I saw one if these on EBay last week for $15 bucks. _________________
TheAndante wrote: |
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer |
