one4house Samba Member
Joined: July 18, 2009 Posts: 1121 Location: Sherman Texas
Posted: Tue May 06, 2014 8:14 am Post subject: 003 Automatic Transmission Questions. |
I am finally to the fine tuning aspect of my automatic. I have a few questions about the 2nd to 3rd shift.
What, mechanically, initiates the shift from 2nd to 3rd?
What I have right now is a inability to shift from 2nd to third without letting off of the gas fully. It will not shift to 3rd without it. I think that I have a seal leak or something that is not signaling the correct shifting point. I have had this issue with both 34ICT carbs and my current DRLA 40 carbs.
I am looking for pointers on things to check.
On another note, I was also having problems with it shifting from 1st to 2nd far to early, but I swapped the valve body from an extra automatic I had lying around and it helped. I nol onger have the 1st to 2nd issue, but the shift from 2nd to 3rd is still an issue. _________________ My Old 64 Field Find
My Old 66 Squareback
My Old 66 Beetle
My Old 70 Squareback |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Tue May 06, 2014 8:26 am Post subject: |
to me this sounds like a leak within the Valve body, I hope its not the case for this one, but i've had this problem a couple of times with american transmissions. _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
Posted: Tue May 06, 2014 8:30 am Post subject: |
VWporscheGT3 wrote: |
to me this sounds like a leak within the Valve body, I hope its not the case for this one, but i've had this problem a couple of times with american transmissions. |
I agree. I totally think it is a leak somewhere in the valve body. I'm just trying to narrow down where? What seal or piston initiates that shift.
One reason I think it is something beyond just the valve body itself is the fact that i have had the same issue with two different valve bodys. I just wish there was more information about these transmissions. _________________ My Old 64 Field Find
My Old 66 Beetle
bugguy076 Samba Member
Joined: December 11, 2007 Posts: 1068 Location: Dover, PA.
Posted: Tue May 06, 2014 5:34 pm Post subject: |
I think the problem is from running twin carbs. The vacuum is not high enough to to run the clutch canister unless you let the throttle plates close. It may work if you add a vacuum accumulator can with a check valve. Also, resizing the hoses might help. The hose from the accumulator to the clutch will be the same but the hoses from the intakes to the accumulator can should be smaller. I have no idea if this will work, but it's worth a try.
The check valve should be between intakes and accumulator. |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Wed May 07, 2014 7:33 am Post subject: |
bugguy076 wrote: |
Ding, ding! Also when you changed the valve body, did you change the governor? they are matched. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Wed May 07, 2014 8:12 am Post subject: |
mcmscott wrote: |
bugguy076 wrote: |
Ding, ding! Also when you changed the valve body, did you change the governor? they are matched. |
Yes _________________ My Old 64 Field Find
My Old 66 Beetle
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Wed May 07, 2014 2:23 pm Post subject: |
Has this trans been rebuilt or has it sat for a while? My wife had one several years ago that sat for quite a while, probably a year or more. It had shifting problems (had been converted from FI to a set of stock VW dual carbs). We bought some kind of Miracle cure in a bottle for automatic transmissions and poured it in and the problems cleared up after a bit of driving. Drove it for several years after that without any problems. Don't remember what we bought but it was probably something cheap from Wal-Mart. We also did a fluid & filter change but I think that was after the bottle of trans fix stuff had straightened out the shifting problem. |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5363 Location: Lefty, CA
Posted: Thu May 08, 2014 1:46 am Post subject: |
One4,
Sorry to hear that you are still having issues. Unless you have something really messed up in you carb setup, I seriously doubt that the dual carbs are your problem. My trans is a / was a 73 that came with FI. I have ran many different dual carb setups up to my T4 with ICTs and it never gave me grief. My first question for you would be have you ever done a pressure test with gauges on the trans?
In reality, I think that the best way to work through this is to PM me and get my personal info. Then we can talk on the phone and maybe find something that gets left out of the impersonal communication that happens on forums. I live in CA, so I think our time zones are close. Let me know.
David _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Thu May 08, 2014 12:16 pm Post subject: |
Adam, if you have a way to measure manifold vacuum under driving conditions we can compare that to what I get through my stock FI manifolds. I'm thinking a vacuum gauge and a line long enough to reach the passenger seat.
Even with my slightly bigger 1776 and E100 it should still be an instructive comarison. We are at the same altitude.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Posted: Thu May 08, 2014 12:18 pm Post subject: |
Max Welton wrote: |
Max |
I'll shoot you an email. I have some ideas. _________________ My Old 64 Field Find
My Old 66 Beetle
