Harleyelf Samba Member
Joined: April 23, 2009 Posts: 1572 Location: Appleton, WI
Posted: Sun May 28, 2017 10:50 am Post subject: Re: Lights pulsating (flickering) |
I'd examine the wires near the fuses for corroded connector tips and broken wire strands. They were bent at a sharp angle fifty years ago. |
VW BRETT Samba Member
Posted: Mon May 29, 2017 10:12 am Post subject: Re: Lights pulsating (flickering) |
Going to replace the generator I think the stater is just to worn out or maybe a bad section in the winding _________________ YOU CAME IN THAT THING? YOU'RE BRAVER THAN I THOUGHT.
63 SINGLECAB
67 13 WINDOW DELUX
20 ATLAS |
Posted: Mon Apr 15, 2019 4:10 pm Post subject: Re: Lights pulsating (flickering) |
Well I figured it out and forgot to post the solution, turned out I had the unusual 38 amp gen and was trying to use a 30 amp regulator, updated to the correct 38 amp regulator and problem solved. Boy do I feel dumb, never even thought to check the amps on the gen, had the motor out and was replacing it when I noticed it, did put a new 38 amp gen in as well so now I have an extra one _________________ YOU CAME IN THAT THING? YOU'RE BRAVER THAN I THOUGHT.
63 SINGLECAB
67 13 WINDOW DELUX
20 ATLAS |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Mon Apr 15, 2019 6:56 pm Post subject: Re: Lights pulsating (flickering) |
That was a one year only generator that had it's own fan tin, hub, and fan bolt. Glad you fixed it. |
Posted: Tue Apr 16, 2019 6:36 am Post subject: Re: Lights pulsating (flickering) |
The motor was built by the PO I had no idea never even heard of a 38 amp gen. The Samba forums are what educated me on the subject. _________________ YOU CAME IN THAT THING? YOU'RE BRAVER THAN I THOUGHT.
63 SINGLECAB
67 13 WINDOW DELUX
20 ATLAS |
