brooksinc1976 Samba Member
Posted: Wed May 07, 2014 7:36 pm Post subject: Wiring options |
I was planning on running my wires threw my frame but I had a couple guys say that's a bad idea and will weaken the frame. What's your opinion? If not threw the frame what do y'all recomend on how to keep the wires neat and clean. My previous rail I zip tied them and it was a cluster and had sharp edges for the kids.
Thx |
Axitech Samba Member
Joined: August 31, 2011 Posts: 1265 Location: Bucks County, Pa
Posted: Wed May 07, 2014 7:54 pm Post subject: |
You drill a hole in the tube, water WILL get in. That's ok if you are sure you primed and painted the entire inside of the tubes. Did you? Use the inexpensive split looms and zip tie at 6" intervals. _________________ He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.-Thomas Jefferson |
Dale M. Samba Member
Posted: Wed May 07, 2014 8:44 pm Post subject: |
My preferred method it to run wires in corrugated split tube and the use zip ties (plastic wire ties) to secure split tube to frame....
Braided sleeving works well too....
http://www.delcity.net/store/Loom-&-Loom-Clamps/
Ever place you drill frame tubing is a point where you can induce cracking and weakening of frame, a place where water can get in, and there is no access to wires inside frame if you need to do some repair or modifications later.....
IF you do not want razor sharp ends on cut zip ties get a pair of flush cut wire cutters and be sure blades are down close to "knot" when making cut... Verify there is no sharp end by testing with finger, if there is a sharp end your technique needs improvement... Its not the zip ties fault its sharp, its the person doing the cutting and the tools he uses.......
Do not mistake these for standard diagonal wire cutters....
HERC Samba Member
Posted: Thu May 08, 2014 7:14 am Post subject: |
weaken the frame ? it's not made outta wax. _________________ Herc |
Posted: Thu May 08, 2014 7:59 am Post subject: |
HERC wrote: |
weaken the frame ? it's not made outta wax. |
The bigger the hole, the more structure is compromised....
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2912 Location: San Antonio, Nuevo Mexico
Posted: Fri May 09, 2014 1:52 pm Post subject: |
a hole is a "stress riser." stress concentrates there. _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
ringomobile Samba Member
Posted: Sat May 10, 2014 9:41 am Post subject: |
hey brooks,
I had the same thing with my rail, I ended up using a 3/4dia plastic or abs pipe thru the passenger compartment. I ran all of my wires thru and then clamped it to a frame tube. i painted it the same as the chassis and nobody knows the difference, and its plastic so nothing will short out.
I got the idea from the race car guys that have to run a fuel line from fuel cell to engine. |
Posted: Sat May 10, 2014 11:43 am Post subject: |
Thx, guess you made my decision not to drill the frame a lot easer. HA |
