STL 1973 Thing
Page: Previous  1, 2, 3  Next
ente_kaefer
ente_kaefer is offline
PostPosted: Sat Feb 14, 2015 10:19 pm    Post subject: Reply with quote
mondshine wrote:
Looks good Mike-
The spot on your driveway makes me think that's an un-retouched photo Wink.
Keep an eye on that coil for leaks......most aftermarket oil filled coils aren't made to be mounted "VW style" (upside down).
The Wife also noticed that my car left its 'mark,' I have since placed one of my large 'cookie sheet' drip pans under the engine.
Good catch on the coil !! I need to pull off the chrome cover over the coil and see if it is an epoxy 'Blue' or aftermarket coil.
ente_kaefer
PostPosted: Sat Feb 14, 2015 10:27 pm    Post subject: Reply with quote
Yea, ready to roll !!
Car passed inspection with no issues, and I was able to get license plates as well today.
Weather be damned, I just *had* to use the Thing for some errands this afternoon. It was rather 'brisk' driving as the temp's were in the low 30's this afternoon, I am missing one window for the car, so I drove with only the rear windows installed.
Need to update my list of 'tweaks' to get accomplished before heading to Kubel Treffen Ost !!
ente_kaefer
PostPosted: Mon Mar 30, 2015 8:34 pm    Post subject: Reply with quote
After I finished work today, weather was rather decent out here on the frontier, so I grabbed a wire attachment for my drill, some sandpaper, and steel wool and proceeded to grid off layers of paint and rust on the four rims on my car. Yea, all four rims are stamped 5JK x 14, ET 32.5, so it appears I have all stock 14 inch rims. The spare is a 4J x 15, with a date code of 9/61, so I will need to replace that.
Getting closer to Kubel Treffen East, now I need to replace the tires . . .
mondshine
mondshine is offline
PostPosted: Tue Mar 31, 2015 4:34 am    Post subject: Reply with quote
Looks great Mike-
Got to love the tag in the windshield! Wink
Last year, I replaced all 5 of my tires with Yokohama Y356 195-75-14.
http://www.tirerack.com/tires/tires.jsp?tireMake=Y...;tab=Sizes
So far-so good with the tires; the 25.8 diameter puts my speedometer pretty much in line with my GPS. The spare fits nicely in the trunk.
See you in Dayton, Mondshine
ente_kaefer
PostPosted: Sun Apr 05, 2015 11:02 pm    Post subject: Reply with quote
Made time to perform a 'field expedient repair' to the two ripped sections of my roof with materials I purchased about 18 months ago. I used black denim material that I purchased from Hobby Lobby, cut, and then applied to roof with spray contact cement on the cloth as well as roof.
I also located a buggered up, Austrian zeltbahn to use to cover the rear seats in the car. The camo pattern actually looks pretty good against the orange paint, if I can locate some more, I may see about having seat covers made from the zeltbahns for the car.
ente_kaefer
PostPosted: Thu Apr 23, 2015 9:16 pm    Post subject: Reply with quote
Replaced all four tires with Douglas Xtra Trac II radials, 205/75 R 14. Wow, what a difference from what was on the car !
Now I need to pull the left rear drum, and tap the stripped threads on the drum with a 14mm x 1.5 tap, and then locate three 14mm lug bolts.
JayC
JayC is offline
PostPosted: Fri Apr 24, 2015 9:41 am    Post subject: Reply with quote
Looks great!
mondshine
PostPosted: Sat Apr 25, 2015 4:56 pm    Post subject: Reply with quote
Mike-
Both of my rear drums have been re-tapped to 14mm x 1.5 since I managed to strip a couple 12mm bores several years ago.
The lug bolts are from a late (4 lug) Beetle; cheap, and easy pickings at your local junk yard.
ente_kaefer
PostPosted: Mon Apr 27, 2015 1:52 pm    Post subject: Reply with quote
It appears a local Ace hardware has the 14mm x 1.5 right thread tap, I will locate some 14 x 1.5 lug bolts on The Samba classifieds. I know that the length on the 14mm lug bolts will need to be cut down, I guess I better get a die while at Ace hardware as well.
Do I need to tap all to 14mm, or just the three stripped ones in the brake drum?
I do know that the torque will need to be different, I believe 70 foot pounds for the 12mm bolts, and 90 foot pounds for the 14mm lug bolts.
I will need to add to the 'Stuff I Need To Purchase' list front and rear drums, as I have no idea how old they are. Well, that and seeing that the entire brake system was replaced, adding new drums would complete the job.
mondshine
PostPosted: Mon Apr 27, 2015 2:10 pm    Post subject: Reply with quote
Mike-
I re-tapped all of the holes on my rear drums while they were off, just because the drums are a pain in the neck to remove. I did not need to shorten the late Beetle lug bolts; no clearance issues.
90 LbFt is good for the 14x1.5 lug bolts.
No VW junk yards near St.Louis? You should be able to harvest 10 of them for $5-$10.
Good luck, Mondshine
ente_kaefer
PostPosted: Fri May 01, 2015 11:53 am    Post subject: Reply with quote
mondshine wrote:
Mike-
14 x 1.5 lugs bolts arrived today, and the tap should arrive sometime next week. Unfortunately any air cooled VW's in any local salvage yards are now long gone . . .
ente_kaefer
PostPosted: Mon May 18, 2015 11:06 pm    Post subject: Reply with quote
I was able to pull both of the rear drums, and tap them from 12 x 1.5 to 14 x 1.5. Good thing I was able to purchase 16 really nice 14 x 1.5 lug bolts from The Samba classifieds, lesson learned for me is to not use the aftermarket 12 x 1.5 lug bolts.
Job was made easier in that since new rear brake cylinders, brake shoes, and springs were installed it was not that difficult to remove the nut that secures the rear brake drum to the drive shaft. My circa late 1980's Craftsman torque wrench only goes to 160 foot pounds, so I tightened the rear drum bolts as best as I could, installing new cotter pins.
Next on the list, two of the 6mm studs came out of the drain plate housing on the engine block when I removed them, so I need to replace them as well as the cap nuts.
I have a replacement roof ordered from Convertible Specialties, it will be interesting to see how the instillation goes.
Also waiting on a CSP finned sump plate so I can installed a VDO oil temperature gauge.
Depending on the day job, in theory, I would like to get all accomplished on the car so I can make a 'dry run' for Kubel Treffen East by trying to make it to the GROOVE VW event in Springfield, MO on SAT, 06/13/2015,
http://groovevws.com/content.aspx?page_id=87&club_id=813651&item_id=400133. If not, a run to Hermann, MO . . .
ente_kaefer
PostPosted: Fri Sep 04, 2015 3:36 am    Post subject: Reply with quote
Still trying to get all that needs to get accomplished on my car, the 'Day Job' has been crazy, well, it does pay the bills as well as my all too many hobbies and interests . . .
Progress, I have gone from . . .
. . . so that I could pull all four rims to grind off old paint from the stock rims, and prime each rim. After I mounted the rims back onto the car, I liked the look of the Rustoleum, red, primer, so for now they will remain that way. I also readjusted all of the drum brakes in preparation of bleeding the brake system.
To . . .
With the car on ramps on the front, it will make it a lot easier to bleed the brakes. Not long after I purchased the car, I pulled the gas tank to sand it down, prime, and painted with undercoating. It was then that I determined that a previous owner replaced the steel fuel line with 1/4 inch fuel line from the front to the rear of the car. Great . . .
The concern I have is the age of the fuel line, and what it is rubbing against inside the tunnel to the rear of the car. I located within the Type 1 section of The Samba some good guides on replacing the metal fuel line, although I will admit, it does not look like it will be a 'fun' job. I am leaning towards running the line through conduit on the right, outside of the tunnel, over the bit of metal that covers wires going to the rear of the car. Wir werden sehen . . .
I also replaced the speedometer in the car with one from a 1970 Type 1, I like the larger numbers . . .
I noticed that when replacing the speedometer that a previous owner had 'repaired' some wiring using black and red wires. Great . . .
So, as it stands right now, my list of things to do is . . .
- Bleed brake system
- Replace voltage regulator and fuel pump
- Rebuilt and adjust the carburetor
- Sort out wiring mess behind the front dash
- Get the replacement roof installed on frame
- Rebuild all four side windows
And any other 'stuff' I encounter while performing tasks listed above.
imtb
imtb is offline
PostPosted: Fri Sep 04, 2015 6:55 am    Post subject: Reply with quote
Looks good, nice find for St. Louis.
ente_kaefer
PostPosted: Thu Jan 28, 2016 11:33 pm    Post subject: Reply with quote
It has taken at least 18 months to get all of the items identified that need to be corrected and fixed with my vehicle, however, it will now start, idle, accelerate, stop, water will no longer will leak through the roof when it rains, and I now have heat !
A ‘Special Mention in Dispatches’ for Jason Douglas of Midwest Air Cooled and Machine, in Arnold, Missouri. For any Samba members in the St. Louis, Missouri, metropolitan area, you may know him from Archway Import’s; he now has his own shop. I was hitting crunch time in terms of time to get all of the work completed on my vehicle; Jason was able to complete it all, and his attention to detail as well quality of work is outstanding!
Jason was able to install a complete BN-4 gas heater system that I purchased from The Samba classifieds, as well as install a replacement roof for my vehicle from The Thing Shop. While he had the car, I also ordered from The Thing Shop a five point show / roll bar and had it installed, and had him install CSP front disc brakes on the vehicle.
So, if you are in the St. Louis, Missouri area, and see an orange Thing in South County, or Jefferson County, odds are it is I . . .
ente_kaefer
PostPosted: Tue Mar 08, 2016 12:34 pm    Post subject: Re: STL 1973 Thing Reply with quote
To the best of my knowledge, there is only one area of my vehicle that has significant rust, that being, the area to the left of the lower hinge of the drivers side door.
I believe I found the source, a missing body plug.
Now I need to determine what the part number is for the body plug is, and replace all missing on the vehicle.
Argh, somehow The Samba 'flipped' the pictures after I uploaded them . . .
Ron Domeck
Ron Domeck is offline
PostPosted: Tue Mar 08, 2016 8:52 pm    Post subject: Re: STL 1973 Thing Reply with quote
The Thing Shop has these. They are called body caps. This area is very common rust area.
GI Joe
GI Joe is offline
PostPosted: Tue Mar 08, 2016 9:32 pm    Post subject: Re: STL 1973 Thing Reply with quote
It appears your lower edge of that rocker has been repaired at some point... Your lower "rib" is only sorta there....
Maybe compare the Pass side, and see if both were done.
'74 Thing, "Our Thing"....Blue 181
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember
ente_kaefer
PostPosted: Wed Mar 09, 2016 6:21 am    Post subject: Re: STL 1973 Thing Reply with quote
Good catch, I intend to . . .
The person I purchased the vehicle from was stationed at Shaw Air Force Base, near Myrtle Beach, South Carolina, it was his daily driver. The vehicle has been repainted at least once. When I get to the point where I can get the paint stripped off the vehicle, it will be, err, interesting to see what body repairs previous owners have made, and how.
ente_kaefer
PostPosted: Wed Mar 09, 2016 6:24 am    Post subject: Re: STL 1973 Thing Reply with quote
Would this be the 12mm x 1mm, rubber plug, or the body cap, part number 311837347 ? The Thing Shop has both . . .
Page 2 of 3
