Emergency/Hazard Switch ID T2
Tcash
Tcash is offline
PostPosted: Thu May 15, 2014 8:07 pm    Post subject: Emergency/Hazard Switch ID T2 Reply with quote
url=http://www.thesamba.com/vw/forum/viewtopic.php?t=594795]Emergency/Hazard Switch ID T2/url]
L68-69 111 953 235 D, could not find a picture. (211-953-235 A) will work as a replacement.
70-72 211-953-235 A
73-79 111 953 235G
Volkswagen Hazard Switch Wiring
http://www.oldvolkshome.com/hazard_switch_ovh.pdf
Tcash
Tcash is offline
PostPosted: Mon Aug 31, 2015 10:49 pm    Post subject: Hazard Emergency E-switch tie wrap Reply with quote
Hazard emergency switches, are known for popping open. Snap it back together and put a Tie Wrap around it.
otiswesty
otiswesty is offline
PostPosted: Fri Sep 11, 2015 7:14 pm    Post subject: Reply with quote
My hazard switch has terminals 54 and 54f that have no wiring. I am guessing that is normal.
I have a VW T2 workshop manual, wiring diagram does not show these two circuits.
1989 Syncro Westfalia
1978 Sage Green P22 Westfalia
Mercedes Gwagens
Just a regular guy
busdaddy
busdaddy is online now
PostPosted: Fri Sep 11, 2015 7:21 pm    Post subject: Reply with quote
54 & 54f are only used on pre 72 North American delivered buses with the combined brake/signals on the rear, later ones with separate signals deleted those terminals and some got a dash light wire to make the knob glow instead. Someone's put an early switch in your late bus, nothing wrong there, the swap won't work the other way though, a late switch won't work in an early bus.
Freezzr
Freezzr is offline
PostPosted: Tue Sep 06, 2016 1:21 am    Post subject: Reply with quote
My '70 bus is missing that switch with the 54 and 54f lips. Is there a way I can make it work? as I can't find the switch overhere....
busdaddy
PostPosted: Tue Sep 06, 2016 7:40 am    Post subject: Reply with quote
I'm sorry, there's no simple way to duplicate that circuit that I can think of. You could add a trailer light converter under the dash and bypass the HL/HR circuit on the signal switch but that would result in a hell of a mess of wires under there, or you could add a brake light wire to the rear and use 2 bulb Euro style tail lights. Either option sounds like way more work and expense than just importing the proper switch.
Here's one, you'll want to have him list the terminal numbers to confirm before you buy: http://www.thesamba.com/vw/classifieds/detail.php?id=1916295
Freezzr
Freezzr is offline
PostPosted: Fri Sep 09, 2016 6:56 am    Post subject: Re: Emergency/Hazard Switch ID Reply with quote
@busdaddy thanks for your input!
So I've been searching for a while but somehow couldn't find the switch with al the needed connectors. I got a switch lately that had the 54 and 54F numbers on it but not the tabs. I took it apart, cut the tabs from another switch, etc.etc. made the inside work correct (I hope at least), lots of small metalwork and now I have the right switch...
Only a test will show if I did it ok...
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Fri Sep 09, 2016 7:01 am    Post subject: Re: Emergency/Hazard Switch ID Reply with quote
Anybody know what year the glowing switch started? I've always wanted it, but I'm not sure my North America light/switch setup would allow it now....
Three rules of troubleshooting:
1. Do the easiest thing first.
2. Don't rely on the guy before you. He was not able to fix the problem.
3. 90% of problems are between the driver's seat and the steering wheel.
Tcash
Tcash is offline
PostPosted: Fri Sep 09, 2016 8:52 am    Post subject: Re: Emergency/Hazard Switch ID Reply with quote
I am going to say 1973. #26 runs over to the headlight switch.
GD
Tcash
SGKent Premium Member
SGKent is offline
PostPosted: Fri Sep 09, 2016 10:48 am    Post subject: Re: Emergency/Hazard Switch ID Reply with quote
73 would be a good guess. That is the year Fiat changed the way the switch worked - they also added a light to it in 1973. Might have been a DOT change.
machine work recommendations: http://kentcomputer.com/77VW/machinework.pdf
Pointers on rebuilding an engine:
http://kentcomputer.com/77VW/rebuilding_a_vw_engine.pdf
Setting Engine Timing: http://kentcomputer.com/77VW/Timing.pdf
busdaddy
PostPosted: Fri Sep 09, 2016 12:33 pm    Post subject: Re: Emergency/Hazard Switch ID Reply with quote
Same for the illuminated heater controls.
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Fri Sep 09, 2016 12:54 pm    Post subject: Re: Emergency/Hazard Switch ID Reply with quote
I know this was true in the bugs and the Type 3s around that time as well. I was mainly confused because Colin's 1970 bus Chloe has the light-up switch. But then I remembered the gentleman that built it really really really liked lights. RIP Mike "Bookwus." Cool
Tcash
Tcash is offline
PostPosted: Mon Sep 12, 2016 3:36 pm    Post subject: T2a Emergency/Hazard Switch Inner Schematic Reply with quote
Wish we had these for every Switch and Motor.
click on pic
Tcash
