ryecatcher Samba Member
Joined: January 02, 2014 Posts: 81 Location: Tampa, Florida
Posted: Sat May 17, 2014 5:42 am Post subject: Exhaust / venting fan in Flue vent? |
I swear I've searched. Has anyone installed a small fan where the fridge flue vent is to just vent out the van whilst parked?
I don't have the original fridge in there, so the flue vent is sealed off and doing nothing. I was thinking of installing a small fan (like a computer fan) on that hole and wiring in to the existing solar to have a little air movement / hot air extraction when parked in the sun. I'd wire it to the solar 12v output side of things to just run off solar and not the battery (since I'd really only need it in the sun).
Anyone done this? Is it even worth bothering with? I'm in Florida and have no A/C, so every degree counts _________________ 1982 Westfalia Camper, Air Cooled
"Wendeline" |
Terry Kay Banned
Posted: Sat May 17, 2014 7:27 am Post subject: |
Not a bad idea seeing as your reefer is gone.
However, that computer fan your thinking of installing at the back end of that vent hole doesn't move enough CFM to make much difference.
Not in the heat & humidity where your at. _________________ T.K. |
chimivee Samba Member
Joined: September 23, 2009 Posts: 741 Location: Orange, CA
Posted: Sat May 17, 2014 7:34 am Post subject: Re: Exhaust / venting fan in Flue vent? |
ryecatcher wrote: |
I swear I've searched. Has anyone installed a small fan where the fridge flue vent is to just vent out the van whilst parked? |
It's not uncommon to add a computer fan where the city water port is/was to expel the hot air generated by the fridge. But I don't think a similar fan at the flue vent would be very effective at venting the entire van cabin because of the fan's small size/location. A better solution might be a larger fan at the skylight. I've done this and, while I don't have hard data, it does seem to be mildly effective. _________________ -James
86 Syncro Westy, etc |
Westified Samba Member
Posted: Sat May 17, 2014 8:34 am Post subject: |
I have also been thinking of how to deal with this heat problem in Florida. The van gets super heated during the day when parked. Our wimpy A/C systems cannot cool it off after it is super heated. The skylight guy used to sell a solar vent that attached to our skylight. You must cut a round hole in our existing skylight. Either a 3" or 4" hole. These vents are used on boats. They are sold by Westmarine. Read the reviews. They seem to poop out after 2 years of use. It is the only thing I have found. They are made by Nicro. Here is Westmarines website:
http://www.westmarine.com/nicro-ventilation--day-night-plus-solar-vents--P012_363_001_516
The other item I looked at is Fantastic Vent (fantasticvent.com). It is a complete replacement of our skylight. The problem with it is that it requires modifying our hatch size. On Westy owner did install one. These vents have excellent reviews. They have one that detects rain and closes the hatch. _________________ 1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022. |
Terry Kay Banned
Posted: Sat May 17, 2014 9:49 am Post subject: |
I have the Micro stainless vent mounted in my pop top about 2 ft.behind the skylight.
This year it's 10 years old and works fine.
Mind you it's by no means a typhoon, but it moves air. _________________ T.K. |
Posted: Sat May 17, 2014 10:18 am Post subject: |
Thanks TK. I am going to try one as long as I can still fit the Westy in my garage. The vent does reduce my clearance some. I will have to measure. The other option is two skylights and switch for my road trips. Need to garage the Westy due to hurricanes here. It was in the garage during Hurricane Andrew and was fine. Not so for the cars outside. _________________ 1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022. |
VANGAUX Samba Member
Joined: May 25, 2008 Posts: 56 Location: Harrisonburg, VA
Posted: Sat May 17, 2014 10:43 am Post subject: Exhaust Fan |
This is not exactly what you are looking for, but I installed a marine fan by Calframo (model #748) by the kitchen light. It swivels side to side and pivots up and down and we use it as an exhaust fan, cooling fan, hair dryer, etc. and it only uses .25A on high speed. Calframo also has a neat hatch fan but it appears to be too big for our skylights.
Link to their series of fans: http://www.caframo.com/marine/marine_products_12voltfans.php
[/img] _________________ 1991 Westy |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17154 Location: Retired South Florida
Posted: Mon May 19, 2014 9:38 am Post subject: |
I am not using this to cool the van, only to remove heat from behind the stock fridge when camping. Here is a front view and side view. It is angled to keep water from running it. I installed it in the city water port as mentioned above.
For camping on cool enough nights, we use a 12 volt oscillating fan that we clip to the roof cross bar. I notice you are in Florida, if you search the gallery for my username, you will see our camping AC install. I copied many members ideas and added a few touches of my own. mark _________________ ☮️ |
bluebus86 Banned
Posted: Mon May 19, 2014 11:52 am Post subject: Re: Exhaust / venting fan in Flue vent? |
ryecatcher wrote: |
Anyone done this? Is it even worth bothering with? I'm in Florida and have no A/C, so every degree counts |
The hot air in the van will be near the ceiling, not below the belt line of the van where the vent is located, it is also a very very small vent for the air flow.
Little to be gained cept maybe a dead battery by hooking a fan to it, verses leaving the front widows both opened an inch or few , this will allow cross flow of air as it is near the roof line, so hot air will be removed,
also the fan powered unit will be very ineffective if there are no windows opened. You have to allow air in, to replace what the fan pulls out. If you open the windows you may find you don't need the fan. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Crooked Designer Samba Member
Joined: March 22, 2018 Posts: 323 Location: Chicago, IL
Posted: Fri Jan 12, 2024 4:12 pm Post subject: Re: Exhaust / venting fan in Flue vent? |
Did a bit of searching and this was the closest I found to the topic, so if this has been discussed somewhere else, feel free to point me there.
I want to use my unused flue vent from the original dometic fridge as an exhaust fan for my new truck fridge. I'd like to be able to exhaust hot air from behind the fridge out of the van. Keep things cooler inside (not expecting this to cool the inside of the van, but would like the fridge not to heat it further) and want the fridge to be more efficient. I've read a bunch of people saying that an additional fan behind the fridge helps a lot on that front.
I'm thinking a 12v computer fan on the inside facing out and a dryer vent type cover on the outside to keep it weather tight. I don't like how this looks and its probably too big, but this is the idea. Maybe have the vent fan hooked up to the fridge compressor power, so when the fridge compressor kicks on, it automatically starts the fan.
Would be even cooler if I could make it look stock on the outside by using the chrome flue vent cover, but not sure how I would make that work without water getting in.
does anyone know dimension of hole in the van wall for the original flue vent on a westy? (its an 85, but assuming they're all the same?) / has anyone done this already?
This is the opening I'm talking about with the fridge removed. This is a still from the GoWesty video for installing the fridge delete kit.
_________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit
Last edited by Crooked Designer on Fri Jan 12, 2024 4:57 pm; edited 1 time in total |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Fri Jan 12, 2024 4:34 pm Post subject: Re: Exhaust / venting fan in Flue vent? |
I don't see why you can't just leave the original flue vent cover in there and make it look stock. The vent was designed to shed water. _________________ 89 Westy 2.1 Auto |
Posted: Fri Jan 12, 2024 4:44 pm Post subject: Re: Exhaust / venting fan in Flue vent? |
PDXWesty wrote: |
I don't see why you can't just leave the original flue vent cover in there and make it look stock. The vent was designed to shed water. |
Shed water while parked is one thing, but driving at expressway speeds in the rain is what I'm more concerned about. Don't get me wrong, I'd love for it to look stock on the outside, but I just don't think that original vent cover can provide that.
I'm pretty sure I saw somewhere in the manual that it originally had a valve under the dometic fridge to drain any condensation or moisture from the air intake / exhaust tubes. I'm not super confident it would create a weather tight closure for a 4" fan and I definitely don't want water in that wall as I still have the original insulation behind there. _________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4798 Location: Bemidji, MN
Posted: Fri Jan 12, 2024 5:37 pm Post subject: Re: Exhaust / venting fan in Flue vent? |
while admirable to suck heat out (that's why other RVs have the fridge hot stuff in an exterior compartment), it's also advantageous to not transfer the heat to the interior in the first place. insulating the hot exhaust pipe does 2 things... keeps the interior cooler AND increases stack temperature so the water vapor from propane combustion exits as VAPOR and not acid rain running down the inside of your van aka fridge side seam rust.
thread here: https://www.thesamba.com/vw/forum/viewtopic.php?p=9445702 _________________ -dan
www.thefixitworkshop.com |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Jan 12, 2024 5:53 pm Post subject: Re: Exhaust / venting fan in Flue vent? |
^^^ Dan, he’s using the flue port to vent his 12v Truckfridge.
If I was cool enough to have a full Westy I might have an opinion, but I’m not and I don’t…sorry.
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Fri Jan 12, 2024 6:08 pm Post subject: Re: Exhaust / venting fan in Flue vent? |
dhaavers wrote: |
- Dave |
again, my critical readings skills fail me. now that i'm retired, it's so nice to not have to be exact in everything!!!! _________________ -dan
Posted: Fri Jan 12, 2024 8:39 pm Post subject: Re: Exhaust / venting fan in Flue vent? |
DanHoug wrote: |
dhaavers wrote: |
- Dave |
again, my critical readings skills fail me. now that i'm retired, it's so nice to not have to be exact in everything!!!! |
You happen to know how big that hole is that the Dometic vent goes through? _________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit |
Posted: Tue Jan 16, 2024 11:46 am Post subject: Re: Exhaust / venting fan in Flue vent? |
Looks like the internet already has everything if you look long enough.
Has anyone done this before?
Looks like they drilled an extra hole (presumably because they're using the stock dometic fridge and need the original flue vent to do it's job. I would be repurposing that original opening, but this is the idea. Love that you can seal it off when your'e driving in rain. _________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit |
