windfish Samba Member
Posted: Sun May 18, 2014 3:37 pm Post subject: Valve questions |
Two quick questions on valves..
I got this engine ('71 1600 DP) off craigslist, it had been reportedly gone through somewhat recently. I had a local mechanic set the carb and valves so I had a good starting point. Today I pulled the valve covers for the first time, went though and reset all the valves to .006 inches. Most were just a little tight, but none terrible.
First, how much should I expect to hear the valves?
I don't know if they're louder now than before or not, ears say yes but realistically probably not. I think on an aircooled vw engine you're just going to hear them, but just making sure. Here's a real short vid -
Second, the base is a bit pitted by cylinder 4's valves. I noticed that corner of the cover was damp with oil, not dripping but you could tell there was some very minor seepage.
For now I just put on a new gasket. Thinking about picking up some gasket maker to help smooth that area, anything else I can/should do for it? |
Posted: Mon May 19, 2014 4:41 pm Post subject: |
Will bump this once..
Figured it would be an easy one -- a "yeah, that's normal" or a "naw, that's too much noise."
May pop the covers off again tomorrow and double check anyways.
This is my first and only aircooled vw engine so I don't really have a baseline.
Making sure there is a gap, even six thousandths of an inch, means there should be some noise regardless since metal will contact metal, right? |
Samer1275 Samba Member
Joined: July 24, 2011 Posts: 205 Location: Jupiter, FL
Posted: Mon May 19, 2014 5:40 pm Post subject: |
As long as engine was dead cold when you adjusted to 0.006" you should be fine. I'm certainly no expert on engine sound but it sounds OK to me. _________________ 1969 Karmann Ghia Coupe |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
Posted: Mon May 19, 2014 5:59 pm Post subject: |
Sounds good to me.
You will allways get a little seepage on the valve covers. _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
Brian Samba Moderator
Posted: Mon May 19, 2014 6:05 pm Post subject: |
sounds okay, and you should be able to spin the push rods when both valves are closed. Slightly loose will make noise, too tight will burn your valve. Which do you prefer? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Danwvw Samba Member
Posted: Mon May 19, 2014 6:06 pm Post subject: |
Yeah that sounds good to me! What you don't want is one that stands out louder than the others. I set mine a tight 4 thousandths on the intake and a tight 6 thousandths on the exhaust! _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
gp98 Samba Member
Joined: May 17, 2010 Posts: 225 Location: Massachusetts
Posted: Mon May 19, 2014 6:09 pm Post subject: |
sounds good, vw good. _________________ 1972 Super Beetle
1961 Dune Buggy,2010 Larz Anderson Class Winner
1971 BSA Lighting
1969 tin top westy |
Posted: Mon May 19, 2014 6:21 pm Post subject: |
I'm perfectly fine with some valve noise if it's supposed to be there, just a little nervous about screwing up this engine doing somthin' dumb.
Cheers guys. |
zak414 Samba Member
Joined: July 30, 2013 Posts: 184 Location: Elk Grove, CA
Posted: Mon May 19, 2014 6:34 pm Post subject: |
Haha...I thought about saying it sounded alright, but only because that's how mine sounds and it works for me. I feel like I don't truly know enough about the condition of my engine to give others an opinion on how their's is running. _________________ 1962 Bug
40 HP Engine
28 Pict Carb rebuilt by Volkzbitz
Big Cap Distributor rebuilt by Tasb |
Posted: Mon May 19, 2014 6:37 pm Post subject: |
windfish wrote: |
Cheers guys. |
Just take your time, and youll be fine.
I do my valves at every oil change, i mean, why not? oil is all over the place. lol. _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
Posted: Mon May 19, 2014 7:02 pm Post subject: |
Mr.Duncan wrote: |
windfish wrote: |
Cheers guys. |
I do my valves at every oil change, i mean, why not? oil is all over the place. lol. |
I think its recommended to check them every 600 miles, but that's pretty frequent. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
DeathTrap Samba Member
Joined: February 26, 2004 Posts: 1757 Location: Sacramento/Vermont
Posted: Tue May 20, 2014 3:13 pm Post subject: |
go tighten the exhaust nuts
should assemble with never seize stuff and tighten as many heat cycles as it takes to seat the gaskets
it's usuall exhaust leaks
get the siphon hose to your ear while you poke around with the other end
you'll hear it |
