crvc Samba Member
Posted: Mon May 19, 2014 6:45 am Post subject: New pulley question |
I'm replacing the short block because of constant oil leaks. Every client comments on the leaks while telling me how they had a bug back in college.
I put in a degree pulley last year. When I put it in the replacement block it causes drag. That is, the flywheel won't turn by hand. Any idea why? I can't see any difference between the degree pulley and the three stock pulleys I've got. It slides onto the crankshaft easily while the older pulleys have to be tapped in. The degree pulley turns easily until I add the nut and washer.
I spend all weekend putting the block together with new bearings. Not done yet and had to ride a bike to work today.
Someone in a car yelled, "Where's the bug?" as I was walking the bike up a steep hill. Grrrr.
TIA,
crvc |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Mon May 19, 2014 9:54 am Post subject: |
Does it drag at all with stock pulleys?
If not.. something is wrong with the degree pulley.
Bottoming out on the case, causing the crank trust (end play) to tighten up.
Check the end play after you sung up the pulley.. if end play (thrust) is gone.. something is out of whack..
Start looking and measuring....
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
crvc Samba Member
Posted: Mon May 19, 2014 2:47 pm Post subject: |
No, I had it in the bug for several months. It's just now that I'm building a replacement engine that the pulley doesn't fit. I'll check end play tonight.
Thanks,
crvc |
2nd67 Samba Member
Joined: August 09, 2013 Posts: 204 Location: high desert ca
Posted: Mon May 19, 2014 6:20 pm Post subject: drag |
crvc wrote: |
Thanks,
crvc |
oil slinger reversed? flywheel thrust tolerance not in spec? crank counterweight rubbing on case? distributor drive/gear binding? |
Posted: Tue May 20, 2014 5:35 am Post subject: Re: drag |
2nd67 wrote: |
crvc wrote: |
Thanks,
crvc |
Exactly where I was heading... _________________ aka Ken {o\!/o}
crvc Samba Member
Posted: Wed May 21, 2014 7:04 am Post subject: |
The oil pump bolt heads stick out too far under the sheetmetal, sandwiching the metal between the bolt heads and backside of the pulley causing drag. I cut down an older oil slinger to fit behind the pulley, acting as a washer. My micrometer says it's about 1/32" thickness. That helped but I worry as the running engine heats up it could cause more dragging.
For now I put an older pulley back on as I try to figure out what to do with the degree pulley.
crvc |
Posted: Wed May 21, 2014 7:08 am Post subject: |
Measure and transfer the degree marks over to the stock pulley.
Add notches to the stock pulley at the timing locations you use.. or want.
I add notches and measure from the stock 0 TDC, > 10, 20, and 30.. thats about all I need..
Scrap the degree pulley... or keep it for reference...
Of course ....You could trim down the oil pump studs too...
Adding a second slinger.. as a shim.. is pure hack..
crvc Samba Member
Posted: Wed May 21, 2014 8:44 am Post subject: |
IT's still on the bench. I forgot the old motor has 'flattish' bolt heads, about half the thickness of the stock bolts. If I use these and they work I can pull the homemade "Hack" out.
The old stock pulley has marks for bTDC, TDC, 7.5 aTDC... It's just not pretty like the degree pulley.
crvc |
crvc Samba Member
Posted: Thu May 22, 2014 7:39 am Post subject: |
I saw the allen-head bolts are the same length as the 13mm-head bolts while being half the thickness.
By using the smaller allen-head bolts and grinding some metal off the pump so it's level with the upper bolt heads I should have room use the degree pulley and also remove the homemade washer.
Thanks for the help,
crvc |
