CrRusty Samba Member
Posted: Tue Aug 27, 2019 3:55 pm Post subject: CV or Constant Velocity Joint Bolt |
Can anyone explain why VW used recessed hex or recessed 12 point heads on the bolts that attach the axles to the vehicles? Why not use grade 8 bolt? Thx. ---R--- |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34002 Location: Conejo Valley, CA
Posted: Tue Aug 27, 2019 4:34 pm Post subject: Re: CV or Constant Velocity Joint Bolt |
I don't know, but in general one advantage of the type they used is a larger, full circle surface to press on the washer and boot cap. A regular hex bolt might have to have a larger head, and the clearance is tight there. The same clearance issue means you can use a 12-point bit on an air ratchet, where a socket probably won't fit. |
cellobus1 Samba Member
Joined: June 10, 2014 Posts: 284 Location: East Tennessee
Posted: Tue Aug 27, 2019 5:35 pm Post subject: Re: CV or Constant Velocity Joint Bolt |
The 12-pt. "triple-square" bolts give you more options to put the torque wrench on, if it's not a ratcheting torque wrench. Twice as many as an Allen head bolt or regular bolt. _________________ 1976 unrestored daily driver Standard bus, "Stella"
formerly, 1959 Standard bus
formerly, 1973 transporter which was 4 years old when it taught me to drive |
Posted: Tue Aug 27, 2019 6:13 pm Post subject: Re: CV or Constant Velocity Joint Bolt |
A Class 12.9 bolt is a step up from a Grade 8 bolt. Why VW didn't use a larger diameter bolt is the question. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22641 Location: NYC/Upstate/ROW
Much better strength in the head on an internal hex, torn, or triple square than a bolt , too. _________________ .ssS! |
timvw7476 Samba Member
Posted: Tue Aug 27, 2019 8:52 pm Post subject: Re: CV or Constant Velocity Joint Bolt |
The VW Group has been engaging in a love affair with internal drive cap
screws for some decades now...
I even retrofitted some to a Honda CT-90 crankcase so I'm infected too. |
Posted: Wed Aug 28, 2019 3:28 am Post subject: Re: CV or Constant Velocity Joint Bolt |
6 M8 bolts probably have a total shear strength of 2000 kg, way over the force they feel,
Engineering is using sufficient plus margin size fasteners, not the largest fastener that will fit. _________________ .ssS! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Wed Aug 28, 2019 3:32 am Post subject: Re: CV or Constant Velocity Joint Bolt |
The head size is smaller with a triple square than a hex bolt. _________________ Glenn
Member #1009
#BlueSquare |
Jetfxr69 Samba Member
Joined: December 28, 2018 Posts: 1293 Location: White mtns nh
Posted: Wed Aug 28, 2019 5:04 am Post subject: Re: CV or Constant Velocity Joint Bolt |
Almost lost another shaft the other day. Luckily decided to get under and adjust brakes up a little and noticed it. All 6 bolts (triple squares) on the trans side were backing out and 3 of 6 on wheel side were as well. Probably only a few miles from slinging it right off. I did NOT locktite them earlier, so my fault. Retorqued with the proper bit and when they come out this winter for rebuild, will locktite upon reinstalling. My new predeparture check item now. Oil, lights, battery cable tightness, any drips or puddles, and now shaft security. Clear prop- contact! _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
‘72 tintop bastard westy Hudson |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Wed Aug 28, 2019 6:02 am Post subject: Re: CV or Constant Velocity Joint Bolt |
not sure, but it makes drilling them out once they strip at 48yrs old really easy. And the mk4's use the same bolts, so you can find them new. Which is awesome. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Wed Aug 28, 2019 6:25 am Post subject: Re: CV or Constant Velocity Joint Bolt |
Jetfxr69 wrote: |
Almost lost another shaft the other day. Luckily decided to get under and adjust brakes up a little and noticed it. All 6 bolts (triple squares) on the trans side were backing out and 3 of 6 on wheel side were as well. Probably only a few miles from slinging it right off. I did NOT locktite them earlier, so my fault. Retorqued with the proper bit and when they come out this winter for rebuild, will locktite upon reinstalling. My new predeparture check item now. Oil, lights, battery cable tightness, any drips or puddles, and now shaft security. Clear prop- contact! |
Its really hard to get loctite to set in a greasy environment - the 33 ft lbs Torque should not loosen up unless the trans flange is damaged on all the threads - in which case Loctite won't help anyway.
Something isnt right? _________________ .ssS! |
Posted: Wed Aug 28, 2019 7:32 am Post subject: Re: CV or Constant Velocity Joint Bolt |
Abscate wrote: |
Jetfxr69 wrote: |
Something isnt right? |
Agreed, about that only time that I find retorquing is necessary is when buying a vehicle and wanting to drive it home many miles. Almost invariably the bolts will not have been torqued to spec and are all right at the point of coming loose. On the stuff I have owned and serviced, the CV bolts just are not an issue. If the bolts are tight enough to keep the CV outer race from moving at all relative to the flange, the bolts will not come loose. I torque to 33 ft*lbs and make sure the threads have grease on them so the compression of the outer race to the flange is at a max. |
Randy in Maine Samba Member
Posted: Wed Aug 28, 2019 10:18 am Post subject: Re: CV or Constant Velocity Joint Bolt |
Jetfxr69 wrote: |
Having correct new Schorr washers makes this almost never happen. |
SGKent Samba Member
Posted: Wed Aug 28, 2019 11:04 am Post subject: Re: CV or Constant Velocity Joint Bolt |
just as a side note, Grade 2, 5, 8 bolts are SAE measurements. They are not metric. Metric uses a different grading system. Since VW are metric the first observation would be that a grade 8 bolt would not thread into a metric bolt hole.
Metric use (strength # / then size of metric thread used):
4.6 / M5 - M36
4.9 / M1.6 - M16
5.8 / M5 - M24
8.8 / M1.6 - M36
9.8 / M1.6 - M16
10.9 / M5 - M36
12.9 / M1.6 - M36
Equivalent:
US Grade 2 = approx metric 5.8
US Grade 5 = approx metric 8.8
US Grade 8= approx metric 10.9
US Grade above 8 (A574) = approx metric 12.9
There are also different kinds of bolts. Meaning some hold two things together so the force is lengthwise in the bolt, and some are shear bolts, where they take a load where two things slide or hang. A sheer bolt usually has a smaller threaded area but is very beefy where the load is. Say you have two pylons and a piece hangs between them. That would take a shear bolt.
When I told my machinist mentor Bill that I wanted to learn the automotive machinist trade from a race engine builders perspective, he said he didn't have any openings. The guy was known all over the racing circuit, building Indy engines, Vee and SuperVee engines, CART engines, drag engines both for unlimited and unlimited marine racing. I went in a couple times and swept up the shop as a volunteer, and while doing it one day noticed Bill looking thru all his bolt bins for a specific kind of bolt. I took it upon myself to reorganize and sort thru all the fasteners he had to save the shop time. After about a day Bill came over and started going thru all the different kinds of markings, pitches, shanks etc., so that by the time I was done after 10 days he had given me a pretty good lesson on fasteners. Then he offered me a job. When he passed away a couple years ago he did so peacefully in retirement. But everyday I miss that shop and the people in it. They turned out the best engines in the world. When Bill was done training me after about 3 years, my masterpiece was to restore a Ferarri Dino motor for a friend. Restore means making it as good as the day it left the Ferrari factory. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Posted: Wed Aug 28, 2019 11:16 am Post subject: Re: CV or Constant Velocity Joint Bolt |
Randy in Maine wrote: |
Jetfxr69 wrote: |
The washers are worthless if you don't tighten the bolt sufficiently. |
Zed999 Samba Member
Posted: Wed Aug 28, 2019 11:38 am Post subject: Re: CV or Constant Velocity Joint Bolt |
Wildthings wrote: |
Jetfxr69 wrote: |
And tightening those particular bolts sufficiently is worthless without the Schorr washers. |
SGKent Samba Member
Posted: Wed Aug 28, 2019 11:44 am Post subject: Re: CV or Constant Velocity Joint Bolt |
Golly gee Ma. I thought I schorr tightn'd those bolts. Maybe I shud a thrown them in the clothes washer after fixing it like Pa was talking about. He said something about the washer not having torque or something like that. Not sure what he meant but maybe the motor was weak or somethin'. What time lunch be ready? I sure am a hungry. You see who Daisy Mae is a being courted by these days? Some guy picked her up in a VW bus making a clanking as it drove off. Daisy Mae isn't that kinda girl. Boy is he in for a surprise when he reaches for her and she a wallops him with that a rollin pin. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Posted: Wed Aug 28, 2019 12:00 pm Post subject: Re: CV or Constant Velocity Joint Bolt |
Zed999 wrote: |
Wildthings wrote: |
Jetfxr69 wrote: |
Do you use Schorr washer under case bolts or rod bolts? I don't and have never had any come loose that I torqued. If you get the CV bolts sufficiently tight they will not come loose with or without a Schorr washer. |
SGKent Samba Member
Posted: Wed Aug 28, 2019 12:01 pm Post subject: Re: CV or Constant Velocity Joint Bolt |
Wildthings wrote: |
Zed999 wrote: |
Wildthings wrote: |
Jetfxr69 wrote: |
Schorr nuff but it is still a good idea to use them. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
