Egr removal and after burner removal
twinfalls
twinfalls is offline
PostPosted: Sat Jan 03, 2004 12:48 pm    Post subject: Egr removal and after burner removal Reply with quote
Help and see my older posts about it.
It seems that, only new posts get answers.
My question:
How did you removed an EGR and/or an afterburner from a 1974 BW.
dstefun
dstefun is offline
PostPosted: Sat Jan 03, 2004 5:04 pm    Post subject: Reply with quote
Here's his prior thread... http://www.thesamba.com/vw/forum/viewtopic.php?t=59123
You need to know exactly what you have.
Exhaust
Take a look at the diagrams at
http://www.bus-boys.com/Pg33.html for '72-'74 and
http://www.bus-boys.com/page34.html for '75-'78
EGR
http://www.bus-boys.com/emission6874.htm up to '74
This shows the air pump (L) and injection tubes (X)
I can't remove my EGR in California as I have to smog the bus 2 more times before it goes out of date range. CA has 30 years old rule for smog.
Radio Questions R Us - what'cha need to know?
"Out! Out! You demons of stupidity!"
Remember - You are required to get older but you are not required to grow up!
62 SC & 66 Bus
twinfalls
PostPosted: Sat Jan 03, 2004 10:19 pm    Post subject: Reply with quote
The last link is an excellent help: It does show all my EGR and after burner parts.
About the exhaust: Mine is as of the first link: No U shape part.
dstefun
dstefun is offline
PostPosted: Sat Jan 03, 2004 11:17 pm    Post subject: Reply with quote
OK, we just have a terminology problem. The U shaped parts for '75-'78 are called afterburner elbows, and you are applying the term to something in your '74 EGR system.
So, you have '74 exhaust and '74 EGR, and I think your original question was how to remove the EGR. Since I don't have that system, I hesitate to answer. Any '72-'74 owners out there??
62 SC & 66 Bus
twinfalls
PostPosted: Sun Jan 04, 2004 3:45 pm    Post subject: Reply with quote
I was told about U shape parts, and had no idea whatsoever.
Now, I understand I confused with elbows seen on 1975 exhaust.
Where are the U's ? on the 1974 EGR ?
Indeed my stuff is a 1974 EGR, like on the pic,
except where the pic shows a 1973 EGR valve,
my EGR valve is sideways ( exhaust gaz ports are right and left ).
Karl
Karl is offline
PostPosted: Sun Jan 04, 2004 9:12 pm    Post subject: Reply with quote
twinfalls, tell me which # in the last link you think is a 73 EGR valve?
No EGR valves are pictured there. The EGR valve is in the side of each intake manifold.
twinfalls
PostPosted: Mon Jan 05, 2004 3:59 pm    Post subject: Reply with quote
Oups, I thougt G. was a 1973 EGR valve....
Now, I think F. is a 1973 EGR valve.
The pic shows an F. at the left carb and another F at the right carb.
I know for sure, my 74 has one EGR valve, and it's not on either carb.
I bought it used in 1978 in Chicago, it's now in France.
Sorry, all those yearly changes, and cases ( Europe, US, California ) are soo confusing.
F. 021-131-501U EGR Valve On Manifold, Used 1973
- 021-131-501AU EGR Valve On Pipe, Used Calif. 1974
- 021-131-501BU EGR Valve On Pipe, Used Fed. 1974
twinfalls
PostPosted: Tue Jan 06, 2004 10:01 am    Post subject: Reply with quote
State of my removing.
After Burner.
I have removed the pump and attached stuff: Parts L.,W.,J.,M.,V.
Parts:http://www.bus-boys.com/emission6874.htm
This disconnected 3 hoses: V. left open, I. and E. both plugged air tight.
I have left: K. X. and the 4 air injectors. I think I will leave them as is. May be later in case I drop the engine.
Is it worth removing and/or plugging K. ?
EGR.
The filter O. is dead with a big hole from rust. I think the EGR valve has been disabled many years ago, but I do not know exactly what was done...They told me they disabled a valve because of an air leak...
One thing for sure, my engine runs OK.
I think I will continue dumping stuff starting from the fillter proceeding up to the carbs..plugging all hoses that get disconnected. While checking my engine stays OK.
My main concern is to rule out air leaks definitly, and not scew up vaccum needed on non EGR stuff. I see: distributor advance, brakes's servo,a flap in the right air filter to carb duct. Is there more ?
My bus is 200 miles away and it's too cold anyway, this will wait spring 2004. Meanwhile all your comments are welcome, and I still hope meeting a 74 EGR remover
