Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 679 Location: SE Oklahoma
Posted: Sun May 25, 2014 8:20 am Post subject: Read my plugs please |
Working on my Thing today in preparation for the trip to Branson in July. Did a 4 hour trip last Friday as a test drive. It was running a little hot - enough to make the "save my bug" sensor trigger the oil light to start flashing on and off.
So I plan to do a complete tune up , check timing etc. Started
by pulling the plugs this morning- they're about a year and less than 3000 miles old. They look fouled to me - what is your read? (forgot to rotate the photo - but cyl#1 is top left)
Thanks _________________ 1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to." |
Posted: Sun May 25, 2014 9:39 am Post subject: |
You need to take a picture looking more directly at the end of the plugs. Kind of hard to see anything but dark shadows in what you posted. Also use a darker back ground so the camera doesn't darken the picture as much.
Head temperature and oil temperature are not real related. What weight oil are you running? Try a 5w30, 10w30, 5w40, 10w40 oil preferably a "high mileage" synthetic. A straight weight 30wt would also be acceptable. |
Posted: Sun May 25, 2014 12:09 pm Post subject: |
here is a better shot.
I'm using 10W30 oil. running a 34PICT3 Bocar and a Brazilian case of unknown displacement. Am about to check timing...
1966 Beetle 1300
1971 Super Beetle
1974 Thing
Posted: Sun May 25, 2014 12:14 pm Post subject: |
The plugs look pretty decent to me. |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Sun May 25, 2014 1:04 pm Post subject: |
I agree looks like mine when I removed after 6000 miles mine runs 180 to 190 avg 20 mpg on 1775 stock carb 100 cam centrifical advance dist headers |
brooklyn thing Samba Member
Posted: Sun May 25, 2014 1:09 pm Post subject: |
Maybe a bit too rich? |
Posted: Sun May 25, 2014 3:08 pm Post subject: |
brooklyn thing wrote: |
That's what I was thinking too. Will make a small adjustment.
I dialed back the timing a couple of degrees just to see if the engine might run a little cooler. FYI - it's got a 009 distributor on it.
Also found right rear brakes were too tight and adjusted those. Will go for another test drive tomorrow.
Thanks for your input, gentlemen! _________________ 1963 Beetle
1966 Beetle 1300
1971 Super Beetle
1974 Thing
Posted: Sun May 25, 2014 4:55 pm Post subject: |
But not that bad really ....... |
Posted: Sun May 25, 2014 7:08 pm Post subject: |
dont go to lean or you will see a burned piston looks ok |
CraigInPA Samba Member
Joined: March 09, 2011 Posts: 212 Location: Norristown, PA
Posted: Mon May 26, 2014 6:31 am Post subject: |
At 3000 miles, those plugs look fine to me. You might be running a tiny bit rich, but not enough, IMO, for concern.
I'd check the valves and timing, put in some fresh plugs, and continue driving the car. |
