sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2008 Location: Texas
Posted: Mon May 26, 2014 9:49 am Post subject: Transmission C-clip removal help |
Does anyone have an easy trick for removing the 2 transmission c-clips on my '66 bug? I've tried filing down some needle nose pliers but they just didn't grab and hold on like I need. Trying to avoid going out and buying a specific tool just for this. Thanks
_________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
BWD Samba Mailman
Joined: August 23, 2002 Posts: 2154 Location: In bed.
Posted: Mon May 26, 2014 10:27 am Post subject: |
I used some of these, filed down.
_________________ BWD
JHC
member #2850
1966 Beetle
_____________________________ |
oldmanmark Samba Member
Joined: July 08, 2006 Posts: 842 Location: n.w. indiana,chicagoland
Posted: Mon May 26, 2014 4:46 pm Post subject: |
The long curved needle nose worked easier than the straight for me. File a groove on each side that grips the snap ring at the tip. The groove will bite the pinch holes on the ring and won't slide off. |
Posted: Mon May 26, 2014 4:47 pm Post subject: |
carcrazed Samba Member
Posted: Mon May 26, 2014 5:08 pm Post subject: |
LOTS of patience. I used long needle nose pliers. After about 30 minutes of continuous work, it popped out _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Mon May 26, 2014 6:03 pm Post subject: |
Buy the right tool and be done with it. Sooner or later you are just going to need it again.
Just make sure the tips are the correct size for the hole in the clip.... _________________ In Stereo, Where Available! |
fla2smoker Samba Member
Joined: December 31, 2011 Posts: 574 Location: Parrish, Florida
Posted: Mon May 26, 2014 7:20 pm Post subject: |
I ended up purchasing Knipex 4411j3 pliers and expected to use them for other circlips. FYI They are too large for the brake pedal circlip. _________________ View my 66 build thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=507996 |
Posted: Mon May 26, 2014 7:59 pm Post subject: |
Thanks all. I'll probably just end up going and buying a pair of snap ring pliers... _________________ .
chink13 Samba Member
Joined: May 07, 2009 Posts: 143 Location: Ocean Springs, MS
Posted: Tue May 27, 2014 7:11 am Post subject: |
I jus bought the big set that harbor freight sells!! worked wonders an plus all the different sizes help with other jobs btw its only like $15-$20 money well spent in my eyes!! |
