der58SC Samba Member
Joined: September 15, 2006 Posts: 1359 Location: Oceanside, CA
Posted: Thu May 29, 2014 11:24 am Post subject: Going through wheel cylinders |
Another issue I have had with my SC is that I am always replacing the front right (passenger side) wheel cylinders. When I drove my bus daily I replaced it several times. I rebuilt them about 2 or so years ago and now they are leaking again! No other wheels are leaking. Why this one and always this one?
I have used new German ones and they lasted the longest but I have had this bus for 14 years and I am only replacing the passenger side.
Thoughts? _________________ Like a midget at a urinal, I'm always on my toes
KCCO!!
Strictly Vintage 2s |
Stocknazi Samba Member
Posted: Thu May 29, 2014 5:55 pm Post subject: |
Do you know who made the wheel cylinders?
Did you hone the cylinders and use sil-glyde silicone grease on the bore and seals?
I always take apart/clean and reassemble all my new brake componants using sil-glyde on the bore and seals. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Thu May 29, 2014 7:12 pm Post subject: Re: Going through wheel cylinders |
der58SC wrote: |
Why this one and always this one? |
Anything else weird about that wheel? Do the star adjusters stay where you put them. Are the wheel bearings rocking? Do both front brakes feel equal.
Hot shoes transmitting to the piston to the rubber, extra travel in the bore due to shoe wearing or lack of adjusting, rough bore from strange hone, pulsating from non-round drum, one side or 1/2 side doing all the work, are a few things. |
Posted: Thu May 29, 2014 9:41 pm Post subject: |
Yes I hone the cylinders out. No I do not know who made it but I know it is German. I did not use sil-glyde but did use a grease. Once I used brake fluid as a lube and that worked also. Got the same life out it as I did this last build that I used the grease on.
Nothing else is weird or wrong with this wheel. I have replaced the bearings once. Nothing else and yes the star adjusters keep the brakes at the right adjustment.
Could it be the soft line? I have not replaced the soft line. _________________ Like a midget at a urinal, I'm always on my toes
KCCO!!
Posted: Fri May 30, 2014 6:07 am Post subject: |
If you have not replaced the rubber lines, do so.
Replacing all rubber brake hoses is a given for all my vehicles. They always seem to be swelled shut anyway. I also do not want to put on new cylinders and push all the crap from the old dirty ass hoses through them.
You used a silicone grease, not regular grease, in your cylinders, right?
Using brake fluid only does not really provide any long term lubrication, more of an assembly lube if anything. _________________ WANTED:
Thomas Jefferson |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Fri May 30, 2014 7:22 am Post subject: |
I'm no chemical engineer, but I don't think normal automotive bearing grease is compatible with brake fluid, and might be part of your problem? There is a special lubricant make for use in brake systems that use brake fluid, and I have a squeeze tube of German "ATE" brand brake paste for use in lubricating brake parts during inspection and storage.
Yes! Change all four of your rubber brake lines, as over time they swell inward and start to choke off the return flow of fluid back towards your M/C.
I wonder also if "maybe" you have honed a cylinder a little too much causing too much clearance between the cylinder and the piston/seal causing some leakage?
Let us know what you discover here...
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Posted: Fri May 30, 2014 7:42 am Post subject: |
I think I will be buying a new wheel cylinder and this time I will take it a part and lube it up with silicone grease before I install them. Also I will replace the rubber lines.
I do not think I honed them too much. I think the lack of real grease (no I did not use wheel bearing grease) might be causing this issue. I guess we will see after a few years if this is the case.
Thanks guys. I never thought about the type of grease I use would cause this. _________________ Like a midget at a urinal, I'm always on my toes
KCCO!!
Posted: Fri May 30, 2014 11:39 am Post subject: |
der58SC wrote: |
Thanks guys. I never thought about the type of grease I use would cause this. |
You can get Sil-Glyde silicone grease at NAPA, and some FLAPS stores. _________________ WANTED:
Thomas Jefferson |
Posted: Fri May 30, 2014 12:35 pm Post subject: |
Yeah, definitely use some grease/lubricant that is brake fluid and brake system friendly. I got the huge toothpaste-style tube of ATE brake grease from BBT in Belgium ( www.BBT4VW.com/en ).
The actual link to the ATE brake cylinder paste is: http://www.bbt4vw.com/en/catalogue/4-under-carriage/3-brakes%20/brakecylinder-paste/
Awesome stuff from the very folks who make the cylinders and brake components...
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Fri May 30, 2014 6:24 pm Post subject: |
Every bus I have ever owned and driven I have either replaced the hard lines or at the very least pulled a pipe cleaner through them. The long, front to back one is by far the hardest to do either way. But you absolutely will not believe the amount of gunky crap that that comes out. I use brake cleaner first until it starts to flow out of the opposite end and then pull the pipe cleaners through until everything looks clean.
Brake system efficiency is all about pressure AND volume. A lot of problems can be traced to obstructions, either partial or full, in the hard lines. Of course this isn't meant to discount the other parts of the system. It is just sometimes a matter of out of sight, out of mind. "If the hard lines aren't obviously failed, they pass the test". _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
SambaUser1M Samba Member
Joined: October 27, 2012 Posts: 135 Location: Irvine, CA
Posted: Fri May 30, 2014 9:14 pm Post subject: Re: Going through wheel cylinders |
der58SC wrote: |
Thoughts? |
Is the drum over-spec, allowing the seals to travel too far in the wheel cylinder? It happened to mine. I fixed it with Old Speed's disc brake kit. |
volksaddict Samba Member
Posted: Sat May 31, 2014 5:03 am Post subject: |
I've probably rebuilt hundreds - ok almost that many - wheel cylinders and masters on all types of vehs. never once have I lubed one with anything except brake fluid, an assembly lube as was said earlier. Didn't even know there was a lube for hyd cylinders, they didn't teach me that in high school. Sorry to all those owners of cylinders running around out there that I put out.
Learn something new here all the time. |
Harleyelf Samba Member
Joined: April 23, 2009 Posts: 1572 Location: Appleton, WI
Posted: Sat May 31, 2014 5:50 am Post subject: |
Have you tried swapping the drums to see if the issue moves? |
Posted: Sat May 31, 2014 7:21 am Post subject: |
Harleyelf wrote: |
No I have not and never thought of that. I am not sure if the drum is over spec. I guess I could take it to a shop to find out.
I ended up buying new cylinders. Still not sure if I will use the new ones or rebuild the existing ones yet. I bought them because jbugs is closed on the weekends now and I am hoping to get the brakes done this weekend. _________________ Like a midget at a urinal, I'm always on my toes
KCCO!!
Posted: Sat May 31, 2014 7:36 am Post subject: |
der58SC wrote: |
Harleyelf wrote: |
I ended up buying new cylinders. Still not sure if I will use the new ones or rebuild the existing ones yet. I bought them because jbugs is closed on the weekends now and I am hoping to get the brakes done this weekend. |
O'Reilly's can measure drums. Any Auto Zone type parts place that turns drop and rotors will have digital calipers for measuring. They're not as accurate as a drum mic, but too few people can actually accurately read a drum mic, so calipers are just as good. |
BarryL Samba Member
Posted: Sat May 31, 2014 9:09 am Post subject: |
volksaddict wrote: |
Didn't even know there was a lube for hyd cylinders,... |
Although not totally necessary if you bleed and service your brakes often enough, it's kinda' relatively new depending on what and where you learnt stuff. I use red rubber grease, myself. It isn't so much for the replacement of the tried-and-true only-use-brake-fluid method as it is to keep the part of the bore and piston/shoe end that is normally dry of any lube from corroding and the rubber stays supple longer.
Regarding the regular grease, petroleum based grease will eat any brake rubber as well as gear oil that runs onto it. |
elise111 Samba Member
Joined: October 13, 2005 Posts: 106 Location: Redondo Beach, CA
Posted: Sat May 31, 2014 12:21 pm Post subject: |
Oversized drums were the culprit for me too. Mine were +1-2mm oversized, and the previous owner had several wheel cylinders replaced. I've found in- spec drums and never had an issue since. Took a while to find decent german drums though!
Pete |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Sat May 31, 2014 12:39 pm Post subject: |
no biggie, ATE themselves say to use their brake grease OR brake fluid. I used it for the first time (permetex brand) doing my porsche rear calipers, I've always used fluid before this |
Posted: Mon Jun 02, 2014 4:49 am Post subject: |
See - I thought I made a mistake once but I was wrong |
Posted: Mon Jun 02, 2014 6:36 am Post subject: |
thanks guys. I will have the drum measured today hopefully. If the the drum is the problem, I will be glad to hopefully put a stop to this crap. _________________ Like a midget at a urinal, I'm always on my toes
KCCO!!
