Ghia coming home
Page: Previous  1, 2, 3, 4, 5, 6, 7  Next
halbug
halbug is offline
PostPosted: Sun May 19, 2019 11:57 am    Post subject: Re: Ghia coming home Reply with quote
halbug wrote:
KGCoupe wrote:
I suppose if the seat tracks will allow the seat to travel far enough forward, then the seat back would not really need to fold.
Right on target! I have new seat tracks from the second row seats of a mini van. They have plenty of travel built-in for access to the third row - well, or second in my Ghia Very Happy
Cheers
halbug
Quick Update
Modern seat tracks work nicely, but they make things a little tricky:
- Seats are partly below the top surface of the new tracks
- Release mechanism needs to be actuated synchon on both tracks
- They are somewhat sensible to an absolute flat monting surface (and I am sure the conditions will be different with and without pan mounted to body Rolling Eyes
I decided to do the planning on CAD, otherwise to much trail and error Laughing First Draft below:
Cheers
halbug
Stealth Ghia Transformation: http://www.thesamba.com/vw/forum/viewtopic.php?p=7226044&highlight=#7226044
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Sun May 19, 2019 12:08 pm    Post subject: Re: Ghia coming home Reply with quote
Pssshhh Rolling Eyes You can’t get it done drawing it out on the computer. Very Happy
Lop the original tracks off (since they’re not for a Ghia anyway), bolt some steel to the bottom of the seat, toss it in the car, make some pieces to fill the void, & stitch it all together.
halbug
halbug is offline
PostPosted: Sun May 19, 2019 12:30 pm    Post subject: Re: Ghia coming home Reply with quote
We'll see Wink
jeffrey8164
jeffrey8164 is offline
PostPosted: Sun May 19, 2019 8:43 pm    Post subject: Re: Ghia coming home Reply with quote
There’s a free cad out there somewhere?
(Compression 8.7:1)
https://www.thesamba.com/vw/forum/viewtopic.php?t=696460&highlight=rose
halbug
halbug is offline
PostPosted: Mon May 20, 2019 1:55 am    Post subject: Re: Ghia coming home Reply with quote
Yup! works well for me Very Happy
halbug
halbug is offline
PostPosted: Thu Jul 04, 2019 9:14 am    Post subject: Re: Ghia coming home Reply with quote
LEGO for big boy's Laughing Laughing Laughing
The mechanism for the release took most of the design time. Now everything looks like it is meant to be - looks so simple - now that it is done Rolling Eyes
Got sidetracked waiting on the laserman Cool Once the manifolds are matchported I will get to the seats again.
Cheers
halbug
KGCoupe
KGCoupe is offline
PostPosted: Thu Jul 04, 2019 9:58 am    Post subject: Re: Ghia coming home Reply with quote
If you sell a few sets of your new-and-improved custom seat tracks, you could possibly cover the costs of buying your own seats.
Perhaps you could try selling them to the distributor that you bought your seats from as there must be others using the same seat that also have a need for extended seat travel.
Heck, for that matter I'd be willing to bet there is a market for just about any one of the carefully thought out and extremely well crafted custom touches that you've created for your vintage VWs.
Just a thought.
halbug
halbug is offline
PostPosted: Fri Jul 05, 2019 1:06 am    Post subject: Re: Ghia coming home Reply with quote
Just a thought.
Let's see if it works out first Laughing Laughing Laughing
Either way this solution will never be plug and play. As mentioned before, modern seat tracks are sensitive to variation and our seat pans are far from meeting those reqirements Shocked I will weld everything together on a flat welding table. A cross bar and one seat pod will be fixed to the pan. The forth seat pod will be machined to fit after body install to avoid any twist Twisted Evil
In addition the solution is really taylored to my specific seats and everyone loves different ones.
Thanks for the flowers anyhow Embarassed
TRS63
TRS63 is offline
PostPosted: Fri Jul 05, 2019 4:28 am    Post subject: Re: Ghia coming home Reply with quote
Well thought solution, extremely cool!
Keep us updated!
Grüße
Antoine
Antoine
My 62 ragtop daily driver:
J1
J1 is offline
PostPosted: Fri Jul 05, 2019 10:37 pm    Post subject: Re: Ghia coming home Reply with quote
Seriously?! My jaw keeps hurting from hitting the floor seeing things like this on the Samba! Yes I guess this is LEGOS for big boys if little boys had to design and build their own LEGO pieces.
1971 Ghia coupe. Assume I know nothing and you'll be pretty darn close to the truth.
halbug
halbug is offline
PostPosted: Thu Jul 11, 2019 9:04 am    Post subject: Re: Ghia coming home Reply with quote
Thank you guys!
Some updates:
Bought myself some special long shank grinding discs
... and got the dirty work done and finished Cool
Back to seats
Cheers
halbug
halbug
halbug is offline
PostPosted: Wed Jul 17, 2019 3:15 pm    Post subject: Re: Ghia coming home Reply with quote
Some pictures
Welding jig and prepping parts
Details
Straight forward welding of the seat support. The release mechanism is next. I hope this will go as smooth Cool
Cheers halbug
TRS63
TRS63 is offline
PostPosted: Thu Jul 18, 2019 10:32 pm    Post subject: Re: Ghia coming home Reply with quote
As usual, clean, well thought and a great result.. thanks for sharing!! Cool
Antoine
Antoine
halbug
halbug is offline
PostPosted: Fri Aug 30, 2019 12:26 pm    Post subject: Re: Ghia coming home Reply with quote
No progress on the Ghia Confused
To continue I had to get my little lathe running. I had bought it some time back but never got it running. I cleaned everything, adjusted and oiled... Finally I am making ships in my own basement Cool
See ya
halbug
TDCTDI
TDCTDI is offline
PostPosted: Fri Aug 30, 2019 12:33 pm    Post subject: Re: Ghia coming home Reply with quote
I hope you don't build them so large that you can't get them back out. Shocked
halbug
halbug is offline
PostPosted: Fri Aug 30, 2019 1:36 pm    Post subject: Re: Ghia coming home Reply with quote
I'll put them in a bottle first Cool
Disc
Disc is offline
PostPosted: Sun Sep 01, 2019 11:08 pm    Post subject: Re: Ghia coming home Reply with quote
He probably meant chips...
The glory never gets old, just need new paint.
Nick
halbug
halbug is offline
PostPosted: Sat Sep 21, 2019 10:54 am    Post subject: Re: Ghia coming home Reply with quote
One seat console is done Very Happy
All works as hoped. Return spring pulls lever with the rubber against adjustable stop to help avoid rattle. As do wave washers, so I don't have end-play in the shaft. All clears the seat. I'm happy with how it turned out. Here some pics.
Side covers are on the to-do-list.
Cheers
halbug
halbug
halbug is offline
PostPosted: Sun Nov 10, 2019 12:10 pm    Post subject: Re: Ghia coming home Reply with quote
I got the console and mechanism for the passenger side welded a couple weeks ago. The levers for the seat adjust needed hard brazing. I have been pushing this out, as I haven't done brazing for decades and wasn't sure how it would turn out... Embarassed
Either way - I did them today and the result is decent. I am not sure if I shall grind the excessive brass away or if it even looks better to leave them as is??? The chrome plater will polish them anyway before dipping...
This concludes the seat consoles Cool I will have to grind and weld a couple things on the Thing pan next, including the bracketry to mount the seat tracks to the pan.
Cheers
halbug
xzener
xzener is offline
PostPosted: Sun Nov 10, 2019 7:44 pm    Post subject: Re: Ghia coming home Reply with quote
Wow, nice work on the tracks. Shocked
My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>!
Page 5 of 7
