halbug Samba Member
TRS63 Samba Member
Joined: December 17, 2017 Posts: 999 Location: Stuttgart - Germany
halbug Samba Member
halbug Samba Member
TRS63 Samba Member
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1137 Location: Melbourne Australia
Posted: Sat Jan 28, 2023 1:33 pm Post subject: Re: Ghia coming home |
That is great work there. A lot of hose connections . Do you have a pressure tester for hoses? Is there a little tank for the gearbox oiling system, or does it just recirculate?
As well as being functional it looks great! WELL DONE |
halbug Samba Member
Inchpincher61 Samba Member
Joined: February 05, 2016 Posts: 141 Location: Germany
Posted: Sun Jan 29, 2023 6:42 am Post subject: Re: Ghia coming home |
halbug wrote: |
Wheels are back from acid dipping and cathodic dip painting (KTL) . Even thought this is only the base coat, I could not resist to check how the wheels would look like in black paint and chrome trim.
What do you think? Gloss Black the way to go?
Of course! That's going to be sweet
By the way: This one of the craziest Ghia builds here. I am really I'm really impressed and excited about the final result!
Can you explain why its necessary to have this oiling system? That would be very interesting to me.
Cheers |
halbug Samba Member
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Tue Jan 31, 2023 2:52 pm Post subject: Re: Ghia coming home |
Holy SH!T on the trans oiling setup! _________________ Steve
Steve's 87 Syncro project |
halbug Samba Member
halbug Samba Member
Posted: Sun Feb 12, 2023 3:49 pm Post subject: Re: Ghia coming home |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
halbug Samba Member
halbug Samba Member
Posted: Wed Feb 15, 2023 12:11 pm Post subject: Re: Ghia coming home |
Question: can someone here share pictures and/or explain how exactly VW build the isolated contact ring onto the steering shaft?
I'm working on my steering column and need to add a feature to get current isolated onto a cable leading to the horn button. The steering column assembly will ground the power. Similar to the pre 58? VW's. The contact brush is clear to me but I like to know how VW assembled the isolated ring onto the shaft to maybe copy it.
Cheers _________________ Stealth Ghia Transformation: http://www.thesamba.com/vw/forum/viewtopic.php?p=7226044&highlight=#7226044
My Berg5: https://www.thesamba.com/vw/forum/viewtopic.php?t=730276&start=0 |
halbug Samba Member
Posted: Fri Mar 03, 2023 11:46 am Post subject: Re: Ghia coming home |
Here is my Frankenstein steering column (SC)
SC tube, and turn signal switch from my 65 Ghia
SC shaft from an early super beetle, so that the old steering wheels fit. Cut in half to adjust the length.
Shoulder machined to fit two ball bearings onto the shaft.
Standard industrial ball bearings installed on VW spacer. I used two bearing because they are pretty small to fit into the old SC tube.
Adapter fits into SC tube and holds the bearing in place.
Completed with a custom plastic spacer just like VW did on super beetles. This set up gives me exact 2mm (VW spec) clearance between turn signal and steering wheel.
Lower end: Standard industrial needle bearing with adapter into SC tube, original race and a proper seal to keep water and debris out.
To run the current from the horn relay to the horn button I choose the principle and a carbon brush from pre 58 VWs.
The steel nut will be soldered to the SC tube. Threaded tube is made from plastic to isolate and brass cap leads the current from the inside to the connector. Cap will be painted black on the outside to isolate and so it looks better.
Again pre 58 principle with insulator plastic ring and brass race, including connector. Wire will be run through the shaft to the horn button. The column will be grounded so the current will find the battery
That's it Once I know the correct length SC tube needs to be shortened and and shaft welded together again. _________________ Stealth Ghia Transformation: http://www.thesamba.com/vw/forum/viewtopic.php?p=7226044&highlight=#7226044
Posted: Fri Mar 03, 2023 2:53 pm Post subject: Re: Ghia coming home |
Some very creative and skilful work there. I'm looking forward to the finished result |
halbug Samba Member
halbug Samba Member
