Tcash Samba Member
Posted: Wed Jun 04, 2014 9:26 am Post subject: Rear View Mirror+Mirrors ID T2 |
To link to post copy and paste
Code: |
[url=https://www.thesamba.com/vw/forum/viewtopic.php?t=596832&highlight=id]Mirror Rear View ID T2[/url] |
68 only Rear View Mirror 211 857 501A
69 only Rear View Mirror 211 857 501B
Day Night (anti-dazzle) Rear View Mirror. 70-79 Style
Note the day night was an option.
77 Westfalia Rear View Mirror.
Question: note the round base near the mount. What years did these fit?
Champagne Edition II
68-79 Rear View Mirrors, Inside
211 857 501A 68
211 857 501B 69
361 857 513 68-69 Rubber buffer
211 857 501C 69
211 857 501G 70-71 Day Night (anti-dazzle)
261 857 501 71
211 857 501H 72-79
211 857 501J 72-79
??? 857 501? 78 Champagne Edition II in brown
Tcash
Tcash Samba Member
Posted: Fri Dec 19, 2014 8:36 pm Post subject: |
Champagne Edition rear view mirror
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Fri Dec 19, 2014 9:28 pm Post subject: Re: Rear View Mirror+Mirrors |
Tcash wrote: |
... 69 only Rear View Mirror 211 857 501B
... Tcash |
As a point of interest, 211 857 501B is noted as '69 only. Is there any other mirror that will replace my '69 camper rear view mirror?
Aloha
tp |
Tcash Samba Member
Posted: Sat Dec 20, 2014 6:57 am Post subject: Re: Rear View Mirror+Mirrors |
Tom Powell wrote: |
Tcash wrote: |
Tcash |
Aloha
tp |
70-79 Mast (arm) will fit. They will just be shorter.
70-79 Mirror assembly will fit your 69 Mast (arm). The Mast ball is the same size.
Try and find a Dazzle (day/night) mirror if you can.
Good luck and Happy Holidays
Tcash |
lastchancevw Samba Member
Joined: August 26, 2008 Posts: 190 Location: Southeastern Mass
Posted: Thu Mar 05, 2020 12:49 pm Post subject: Re: Rear View Mirror+Mirrors ID T2 |
Actually, my 69 uses the screw in 68 mirror. Checking the M plate it seems to indicate it was built in October 1968. Looking at my VIN it's lower than the 219 060 788 that is says when the change happened
So some early 69s still used the 68 mirror. _________________ 1970 Commercial Kombi
1971 rusty Westfalia (retired for now)
1971 ghia (waiting)
1974 super beetle (2, maybe can be made into one)
1969 delta blue deluxe bus, half-camperized and being worked on |
Posted: Thu Mar 05, 2020 12:54 pm Post subject: Re: Rear View Mirror+Mirrors |
Tcash wrote: |
Tom Powell wrote: |
Tcash wrote: |
Tcash |
Aloha
tp |
Tcash |
how do you remove the mirror assembly from the ball?
Thanks _________________ 1970 Commercial Kombi
1971 ghia (waiting)
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Thu Mar 05, 2020 1:44 pm Post subject: Re: Rear View Mirror+Mirrors |
lastchancevw wrote: |
Tcash wrote: |
Tom Powell wrote: |
Tcash wrote: |
Tcash |
Aloha
tp |
Tcash |
Thanks |
I've always shot a little spray lubricant onto the ball, and grabbing the mirror, twisted it off the arm bracket. It can be tough as most of the original rear view mirrors are toast.
I've been able to do this to clean up the arms and reinstall the same mirror back onto the original arm. _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Thu Mar 05, 2020 1:54 pm Post subject: Re: Rear View Mirror+Mirrors ID T2 |
T-Cash' legacy lives on. Miss that guy! so many posts of amazing value! unlike this one. Hope he is still doing great and having fun. |
Posted: Wed Mar 11, 2020 8:25 am Post subject: Re: Rear View Mirror+Mirrors |
SamboSamba22 wrote: |
Tcash wrote: |
Tom Powell wrote: |
Tcash wrote: |
Tcash |
Aloha
tp |
Tcash |
Thanks |
I've been able to do this to clean up the arms and reinstall the same mirror back onto the original arm. |
Hmm. yeah. I hate to start an arguement or whatever, but I get the feeling that that's not going to work so well.
Anyway, I have some questions on how the mirrors are even made in the first place. My 68/early 69 mirror had glass that fell out because the black plastic of the mirror assembly was so deteriorated, that there's nothing to hold it in.
because there's no glass in there, you can see that the ball itself is allen-headed screwed into the mast. The mast and the ball are NOT the same piece of metal, which I would have expected them to have been.
So if you can just get the glass out somehow you can unscrew the mirror assembly and ball from the mast
Thing is, I don't know if the later mirrors are made like this or not. And you can't get the glass out of the black plastic part without breaking it (or maybe you can apply a heat gun the black plastic to make it pliable and work the mirror glass out. Obviously they had to somehow get the glass into the black plastic part somehow.
I dunno.. this idea that you're going to just grab and pull the mirror off the ball like dislocating your arm socket doesn't seem like it's going to work anyway, kinda seems like most of the mirrors are too brittle to do that with these days, and perfectly fine if you don't mess around with them like that.
Which makes me wonder, why would you remove the mirror assembly from the mast and put the sameone back on just to clean up the mast? Seems like a lot of effort, risking breaking the mirror and in the end you'll probably end up with a mirror that's too loose and floppy because you blew out the ball and socket
So.. anyway i might go and sacrifice a later 70s non-screw on style bug mirror (of which i have dozens) and smash the glass just to see how it's made underneath that, and if the ball part is removable from the mast like on the 68/early bus mirrors. If the ball and mast is two pieces then maybe the ball can somehow be grabbed on the thin part where it screws into the mast?
EDIT- I just popped off a later style mirror from the ball and determined that the later style mirror ball and mast is the same piece of metal. Also, even though the mirror popped off allright, when I popped it on my 68 style ball, the whole thing was way too loose to be useful.
Is there a recommended super sticky grease that might tighten up the whole thing. Seems like the act of popping one off and on just stresses the plastic too much to be tight anymore _________________ 1970 Commercial Kombi
1971 ghia (waiting)
Last edited by lastchancevw on Wed Mar 11, 2020 9:00 am; edited 2 times in total |
Posted: Wed Mar 11, 2020 8:28 am Post subject: Re: Rear View Mirror+Mirrors ID T2 |
uh, not sure that "77 Westfalia Rear View Mirror." (the one with the round base) is quite right. That looks like a standard Beetle non day/night mirror. See how it's slightly off center? I don't think bus mirrors are ever off center. _________________ 1970 Commercial Kombi
1971 ghia (waiting)
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Thu Mar 12, 2020 9:16 am Post subject: Re: Rear View Mirror+Mirrors |
Tom Powell wrote: |
Tcash wrote: |
... Tcash |
Aloha
tp |
250 Euros for just an interior rear-view mirror, seems like a LOT of money to me!!!
https://kieftenklok.nl/shop/en/front-page/t2-1968-...nos-detail
I have a second-hand one of these on my 1973 VW "1600" Type 2 Westfalia Continental , together with the matching sun visors from a 1968~69 VW Type 2.
It enables me see further rearward than the original NON-anti-dazzle 1973 VW Type 2 mirror.
Ideally, I would like to have a dipping, anti-dazzle mirror head on my late-1969 long mirror-stem. _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net
alikatcraig Samba Member
Joined: September 09, 2007 Posts: 556 Location: Anaheim, CA
Posted: Fri Mar 13, 2020 9:39 pm Post subject: Re: Rear View Mirror+Mirrors ID T2 |
Here's mine. 1968 stem with Vanagon mirror. Sensible size and not fried with the So-Cal sun. _________________ 1967 Ghia
1971 Deluxe Microbus
1974 Convertible Bug
1973 Standard Bug
1998 Mexican Bug |
Posted: Sat Mar 14, 2020 9:12 am Post subject: Re: Rear View Mirror+Mirrors ID T2 |
alikatcraig wrote: |
Here's mine. 1968 stem with Vanagon mirror. Sensible size and not fried with the So-Cal sun. |
That's a late-1969 stem Alistair!
The chrome-plated 1968 & early-1969 stem is fastened to the ceiling using two countersunk machine screws.
How did you manage to substitute the "Vanagon mirror" without cracking the mirror's ball socket!?!
Back in the early-1980s, I tried to substitute the dipping anti-dazzle mirror head from a VW 411/412 onto my original 1973 VW 1600 Type 2 mirror stem, but the plastic ball-socket cracked. _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
airschooled Air-Schooled
Posted: Sat Mar 14, 2020 11:51 am Post subject: Re: Rear View Mirror+Mirrors ID T2 |
NASkeet wrote: |
How did you manage to substitute the "Vanagon mirror" without cracking the mirror's ball socket!?! |
Step 1: Pull off old cracked mirror
Step 2: Push on Vanagon mirror
Robbie
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Sun Mar 15, 2020 2:30 pm Post subject: Re: Rear View Mirror+Mirrors ID T2 |
Sorry for the typo - yes I meant '69. The Vanagon mirror came off the Vanagon easily with a little vaseline and refitting to the '69 one was a reverse of the process. _________________ 1967 Ghia
1973 Standard Bug
1998 Mexican Bug |
Posted: Mon Mar 16, 2020 7:59 am Post subject: Re: Rear View Mirror+Mirrors ID T2 |
Actually, to follow up on what I wrote before. I played around with the whole "popping mirrors off the ball and socket joint" thing and here's what worked for me.
penetrating oil will help you get the mirror off the socket, however even if you wipe all that off when you put them back together, what works better is this:
Coat the inside of the socket and the outside of the ball with spray glue (3M or whatever). The stuff stays pretty flexible and gooey and doesn't quite harden entirely. It pretty much fixes any ones that are a little loose although probably not ones where that socket is cracked. And it doesn't harden so much that the mirror is now permanently stuck in it's new position. _________________ 1970 Commercial Kombi
1971 ghia (waiting)
Posted: Mon Mar 16, 2020 9:15 am Post subject: Re: Rear View Mirror+Mirrors ID T2 |
asiab3 wrote: |
NASkeet wrote: |
Robbie
I tried that approach without success Robbie.
When I enlisted the help of the workshop technicians at university, they got too heavy handed with it and cracked the socket; highlighting the dangers of consulting so-called experts!
I was going to try putting the stem in the freezer for a few hours to shrink the ball and warm the plastic socket to expand & soften it, but by that time the damage had been done! _________________ Regards.
Nigel A. Skeet
