Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Tue Jun 10, 2014 10:10 am Post subject: |
You really don't want to run 87 octane with this combo. I agree 1.4 rockers are too much for a dd car. I would run 1.25 and 1.3 are on the edge.
Dan |
Posted: Tue Jun 10, 2014 10:26 am Post subject: |
The Web 163 was designed for 1.3 rockers. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7219 Location: Videbaek Denmark
Posted: Tue Jun 10, 2014 10:42 am Post subject: |
Ditto that.
I have used the 163 with 1,25īs along with a light valvetrain several times, and can spin 6600 with no valve float if I want to.
I also have made my own version of the 163 with 0,472" lift on intake valve (About equal to 1,25 ratio on a stock cam) and stock 0,422 on exhaust, due to the fact that most aftermarket heads actually flows too much on the exhaust for engines w peak power below 6000 rpm. Especially on sub 2 liter engines this cam works very very well. Significantly more power than the W110 mainstream cam and way more usable torque. A further plus is a valve train that is not noisy.
For medium grade fuel I see no problems running 9-1 CR. Especially not if you use 1,25 rockers as they WILL bleed off a little dynamic compression. On nippy engines I use 9,5-1 CR and high grade fuel (about equivallent to 93 octane) At that CR it really produces both power and torque.
T |
Posted: Tue Jun 10, 2014 2:04 pm Post subject: |
I agree, did not say it is a bad cam and rocker combo but for a dd car sometime going a little on the conservative side is a good idea. Nice combo.
Dan |
