EverettB Administrator
Joined: April 11, 2000 Posts: 69696 Location: Phoenix Metro
Posted: Sat Jul 29, 2017 4:42 pm Post subject: Re: Official Oval Beetle Engine Finder Thread |
Yes, I have done that sort of math before and it's generally correct to within a week. I compared it against where the VIN # fell in the charts though, not against what it said on the birth certificate.
Are you wondering if that engine is original?
I would say Yes since it's so close, unless you know otherwise.
You can also Order a VW Birth Certificate and they will tell you if it's original if you give them to engine # to verify. _________________ How to Post Photos
cooter19 Samba Member
Posted: Tue Aug 01, 2017 3:53 pm Post subject: Re: Official Oval Beetle Engine Finder Thread |
I received a birth certificate years ago but never gave a thought to looking up the engine number. I know I waited a very long time for the certificates as I sent in for three. I am not sure if they would answer my outreach to them with an engine number. I wish someone could publish the information they have that's got to be on a micro phisch somewhere......
On a side note, Is there an official way to find out how many ragtops were made in 55? Striking zero at this moment.
Thank you!
Nathan |
calibob Samba Member
Joined: February 19, 2006 Posts: 137 Location: Pinon Hills Ca aka BFE
Posted: Fri Aug 11, 2017 3:35 pm Post subject: Re: Official Oval Beetle Engine Finder Thread |
Hea EverettB you should make this topic a STICKY _________________ 57 oval project ( og diamond green )
67 Baja
64 Manx |
Derosse Samba Member
Posted: Sat Nov 25, 2017 12:56 pm Post subject: Re: Official Oval Beetle Engine Finder Thread |
Engine case 1-0679350 available! very early oval 25hp engine case! |
EurOval Samba Member
Joined: September 11, 2019 Posts: 5 Location: The Netherlands
Posted: Wed Sep 11, 2019 4:18 am Post subject: Re: Official Oval Beetle Engine Finder Thread |
Engine Case 1-0562155 Available. Zwitter Case. Late februari 1952.
For split beetle with the oval dash.
SOLD SOLD SOLD |
Posted: Thu Sep 12, 2019 1:38 pm Post subject: Re: Official Oval Beetle Engine Finder Thread |
Engine 1956387 July 1957 late Oval.
Incomplete
Turns by hand.
Located in the Netherlands.
Posted: Thu Sep 12, 2019 1:40 pm Post subject: Re: Official Oval Beetle Engine Finder Thread |
Incomplete Engine 1471511 May 1956 Late Oval availebal for sale.
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1293 Location: south san francisco
Posted: Sat Sep 14, 2019 5:26 pm Post subject: Re: Official Oval Beetle Engine Finder Thread |
available
1-1190011 / 55
1-1267098 /55
2201552 /58
2201470 /58
1543599 /58
more to come!
all bare cases
I can check condition. _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
davetaylor Samba Member
Joined: May 24, 2006 Posts: 218 Location: Hawesville, KY
Posted: Tue Oct 08, 2019 2:06 pm Post subject: Re: Official Oval Beetle Engine Finder Thread |
I have the bare case of engine -1-1212444 if it belongs in anyone's car _________________ 1954 3-fold ragtop Beetle project
1969 Porsche 912 (sold)
1979 Beetle triple white German Look convertible
1980 Porsche 911 SC Targa (sold) |
bwaz Samba Member
Posted: Tue Oct 08, 2019 3:08 pm Post subject: Re: Official Oval Beetle Engine Finder Thread |
EurOval wrote: |
Incomplete
Turns by hand.
I think this would be mid August 57, so early square window beetle? I have a July 15/57 built, August 2 delivered square window I'm looking for a block to in the 1937XXX - 1939XXX range |
pdxeuro Samba Member
Posted: Sun Jun 07, 2020 7:26 pm Post subject: Re: Official Oval Beetle Engine Finder Thread |
I have 1-0956080 which looks to be 1954. I have a May 1959 bug and looking for a case around the 3000000 number. _________________ ----------------------------------------
Portland, Oregon
1991 Westy MV
1959 Bug
1977 Westy Bus - sold
1968 Bug - sold
2002 Eurovan - sold |
bwaz Samba Member
Posted: Wed Jun 17, 2020 2:45 pm Post subject: |
Kjell Roar wrote: |
Jrb572 wrote: |
I am looking for an early 1957 April motor. The car was built on the 11th.
I think I would like from 1797568 - 1813000 give or take a few in April.
I have 1909548 which I think is June. Motor runs but my need a case half. The side with out the serial number. I have a weird trap door bolted between the oil pump and the oil pressure relief valve. Just noticed it wasn't supposed to be there. |
You should search for a march engine, too. Engines where often build a month or more earlier. My oval has July engine and chassi, was buildt in August.
Its easier to get engines from mid 57 and newer, they have better oil feed, and are better engines. So I think the old cases where scrapped when they came in for refurbishment at VW. |
I know old topic, but always topical! Trying to guess my engine number for my what the birth certificate is a July 15/57 build date. It left the factory August 2, 1957. Yes it's a square window, serial 1601113. The closest to my car I can find is 1606506 with and engine 1927844. According to Vin/chassis numbers on the Samba, the newest my engine number could be is start of August 57, but this other car doesn't line up with the charts as the engine is too early for those stats which say 1937052 is the last engine in July?
Someone with a July 13/57 oval, has a serial number 1595226 and original engine # 1922450. This car is 5620 cars away from the end of July stats, but the engine is 14602 away from the end of the month stats. I assume engines also went to buses and ghia's then, but in lesser numbers so the numbers would never be sequential on cars? I wish we could know how much of a break happened between late ovals and the first square windows, although if these date numbers are correct, the oval was built on a Saturday and my car a day away on Monday. So.... which is correct, detective work or the progressive refinements numbers. The PR dates say Aug 2 has a car 1601517 had engine 1939746? That's 671 cars from start of month, but 2694 engines after the start of the month? My head hurts
(Just to add confusion, Progressive refinements says August 1, 1957, the backing plates were changed and the wheel cylinder is now at the top. My car still has it on the bottom like an oval. I would guess that the backing plates are original to my car... which is mostly original in a lot of other ways.) So is my car a July 57, or an August 57... yes, a square window, and I really don't care about the dates.. just what motor is most correct. |
Posted: Wed Jun 17, 2020 4:38 pm Post subject: Re: Official Oval Beetle Engine Finder Thread |
Ar you trying to figure out the exact number based on other cars and VW data? Impossible.
I believe all you can is make an educated guess based on whatever date you can find.
Even then I'm sure it would be in a range.
I don't think there is a guarantee that the engine in VIN # 1601114 (one VIN after yours) had a higher engine #. They probably got a batch and stuck them in as needed as the assembly line rolled onward. Would 1601114 even necessarily be behind 1601113 on the assembly line? What is one was a ragtop and one a hardtop, necessitating different assembly work? Something to think about... _________________ How to Post Photos
bwaz Samba Member
Posted: Wed Jun 17, 2020 9:42 pm Post subject: Re: Official Oval Beetle Engine Finder Thread |
It would be interesting to know if they did a run of deluxe hardtops, then a run of ragtops, then standards... or intermixed along the way? No, not trying to find an exact number, but within 20,000 would be nice... and where my questions come from is as the crossover of months and new body style add an extra layer Of confusion |
Jimone Samba Member
Posted: Sun Oct 24, 2021 2:13 pm Post subject: Re: Official Oval Beetle Engine Finder Thread |
i have some cases.
casually looking for #503416 for my bug. have #596780 that would be available in a trade here or for a different 25hp.
cases i have:
1046134 - april 55
1180911 - sept 55
1638302 - nov 56
1872780 - may 57
2034?09 - oct 57
2138724 - dec 57
also have several more modern cases from 58s, 59s, 60s and several dual ports. _________________ november 1952 ragtop
november 1954 single cab |
mark1laura Samba Member
Joined: January 03, 2016 Posts: 14 Location: Reno, NV
Posted: Sat Nov 06, 2021 7:49 pm Post subject: Re: Official Oval Beetle Engine Finder Thread |
Looking to find a 1957 model year engine case with a number that preferably places it in Nov/Dec 1956 production - i.e in the 1 600 000's. Thx for any leads! |
TornadoRed06 Samba Member
Joined: August 30, 2020 Posts: 183 Location: Porto - Portugal
Posted: Sun Nov 07, 2021 8:15 am Post subject: Re: Official Oval Beetle Engine Finder Thread |
mark1laura wrote: |
okay then, up one post, there is case 1 638 302 as stated for Nov 1956... |
Posted: Sun Nov 07, 2021 12:37 pm Post subject: Re: Official Oval Beetle Engine Finder Thread |
Thx TornadoRed06, had noticed that post right after I posted mine and we are in contact. Cheers! |
Posted: Tue Mar 01, 2022 9:13 am Post subject: Re: Official Oval Beetle Engine Finder Thread |
davetaylor wrote: |
I have the bare case of engine -1-1212444 if it belongs in anyone's car |
This is a September 1955 case, to save anyone the trouble of looking it up. _________________ 1954 3-fold ragtop Beetle project
