RBEmerson Samba Member
Joined: November 05, 2011 Posts: 2108 Location: SE PA
Posted: Wed Jul 30, 2014 4:34 pm Post subject: |
Well! Photobombed by your dog. Some days ya just can't win.
Seriously, good video and good products. Good on ya! _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
backyard_cnc Samba Member
Joined: July 20, 2012 Posts: 385 Location: MANITOBA CANADA
Posted: Sat Aug 02, 2014 5:00 pm Post subject: |
She's a good looking dog and destined to be a star someday,......... I am lucky to be upstaged in such a manner!! |
Posted: Sun Aug 17, 2014 11:14 am Post subject: |
Well its not looking like I will be running a BEIGE version of the Skylight screen as there just was not enough interest expressed to justify the special order and quantity of material I would have to purchase to make it happen. So yesterday I was making a new panel for my sliding door from 1/8" ABS and since it was bright white it would require a coat of paint to tone it down and blend more with the interior of my van. I chose a Satin IVORY paint and since I was setting up for that I thought I would carefully mask off an assembled Skylight screen and paint it at the same time. Here are the results. I am not interested to paint these for sale but simply post it as a point of interest that you can easily do it yourself to a color of your choice. This screen was a black version and since it is a custom for my personal van I did the 2tone effect by masking off the center logo. The paint I used is shown in the last picture. This sort of paint job should be easily within the capabilities of most if not all westy owners. I did manage to get a few spots of paint of the screen but it cleaned up ok with varasol paint thinners.
Gerald
Posted: Mon Aug 18, 2014 8:37 pm Post subject: |
I like that! Where did you find the VW pattern? _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Windig89 Samba Member
Joined: September 22, 2011 Posts: 184 Location: Montreal
Posted: Tue Aug 19, 2014 6:57 am Post subject: |
RBEmerson wrote: |
You're braver than I am!
BTW, my wife wondered if the outside width of the frame might be better off about 1/4" wider, to conceal the yellow glop that Goo Gone and even acetone can't remove. It probably would mean necking the frame down where it goes under the winder for the skylight. Just a thought from SWMBO. |
I posted this earlier in the thread, but check out this link
http://www.thesamba.com/vw/forum/viewtopic.php?t=551318&start=0
It worked like a charm, no more brown goo, looks nice and clean. _________________ 1989 Vanagon GL Westfalia - 2.1L waterboxer |
Posted: Tue Aug 19, 2014 7:17 am Post subject: |
I don't quite follow how you used the chisel. Did you basically just drag it over the glue residue, relying on the blade to be, in a effect, a non-bending razor blade? _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Posted: Tue Aug 19, 2014 12:35 pm Post subject: |
You use the chisel exactly as you would use it on wood. Push it forward with very gentle downward pressure (no mechanical assistance i.e. no hammer) its all steady hands and angle of the blade. You are basically shaving the glue off little bits at a time, taking it down to the fiberglass which is the same color as the flocking and although it will appear as a shiny surface after compared to the flocking, it still blends in rather nice. The idea is to keep your outside cut lines in the flocking straight as possible for a clean look. keep your angle of the blade as small as possible to avoid digging in by accident causing a gouge. I laid out a big drop sheet to catch all the glue shaving for quick and easy cleanup. Total time was about 15 mins. Use a good sharp chisel with no nicks or dents in the blade (this is key), buy a new one if needed, the results are worth it.
I don't get too many compliments from the wife after I complete a job on the Westy, but this time I got a "wow it looks so much cleaner in here ". I didn't even tell her about the new screen in advance so it was totally an unbiased first impression.
Here is a quick little video showing the technique being used on wood around .040 seconds is the part you want to watch.
Good luck _________________ 1989 Vanagon GL Westfalia - 2.1L waterboxer |
Posted: Tue Aug 19, 2014 1:28 pm Post subject: |
Now I'm really confused. Chisel at right angles to the surface with the glue or parallel to that surface? _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
AKWesty Samba Member
Joined: April 12, 2014 Posts: 680 Location: Haines, Alaska
Posted: Mon Mar 16, 2015 3:39 pm Post subject: |
Gerald, thanks for the great screens! These are well worth the money. The mosquitos won't have a chance. -Chad
_________________ 84' Westy 2wd
EJ22 - 4spd - Peloquin TBD
GW +1.5 Springs
215/70-16's
www.CatchTheKraken.com
"Never go to Alaska as a young man because you'll never be satisfied with any other place as long as you live." -John Muir |
Posted: Mon Mar 16, 2015 3:45 pm Post subject: |
Thanks Chad,
Glad they made the postal trip to Haines in one piece. I spend a lot of time just packaging these larger screens to hopefully ensure they arrive safely!
Thanks for posting the pics the screens make a Nice looking Westy even nicer! I have the LT style mirrors on mine as well but haven't ponied up for the SA grill and nice bumpers although it is part of some plan in my mind, If only there was unlimited budgets eh.
cheers
Gerald |
Posted: Mon Mar 23, 2015 1:45 pm Post subject: |
Greetings Fellow Vanagonauts,
The Skylight Screen Machine has been turned on for Season 2- the Redux and I cut 2 dozen frames today to stock up and allow me to fill a Group Purchase from members of the UK based 80-90 club.
I do offer a 10% discount on orders of 5 or more pieces when shipped to a single address and there is also a large postage savings to be had on multiple pieces shipped together. 5 screen kits in one package will cut the postage cost per screen to half or less than the single screen postage cost but even 2 or 3 screens in a package can be a good savings. Please contact me thru my classified ad for more details: http://www.thesamba.com/vw/classifieds/detail.php?id=1650932
Gerald
65Tops Samba Member
Joined: March 22, 2015 Posts: 43 Location: San Diego, California, USA
Posted: Mon Mar 23, 2015 5:37 pm Post subject: |
Have you thought about shipping them with the "spoilage" to protect the ears and edges or would it make the package too big? _________________ 89 Vanagon 2.1 WBX Westy Camper "Spanky" |
Posted: Mon Mar 23, 2015 5:48 pm Post subject: |
Well i have only ever had one report of damage in the post and it would have happened regardless of any added pvc. I replaced the damaged panel at no cost to the customer. My packaging for shipping has proved to be very effective to date so I see no reason to change anything at this point unless I have a run of bad luck. Thanks for mentioning it though, might be useful at some point.
cheers
Gerald
Last edited by backyard_cnc on Mon Mar 23, 2015 10:06 pm; edited 1 time in total |
Yellow Rabbit Samba Member
Posted: Mon Mar 23, 2015 8:25 pm Post subject: |
Are you selling the front screens? |
Posted: Mon Mar 23, 2015 9:52 pm Post subject: |
Yes all screens, front rear and skylight, as shown in my samba classified ad are built and shipped to order. Please review the classified ad mentioned a few posts above for complete details or PM me if you have unanswered questions.
Thanks
Gerald |
Posted: Sat Apr 18, 2015 11:16 pm Post subject: |
I recently shipped a number screens to the UK for a group buy from a group of westy owners on the Club 80-90 Forum. My new friend Daniel who organized the buy, produced a great installation video which puts my own video to shame! Please check it out at the link below and also view his other videos while you're there.
Gerald
https://vimeo.com/125075145 |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 752 Location: Falls Church, VA
Posted: Sun Apr 19, 2015 5:46 am Post subject: |
[quote="backyard_cnc"]Not a skylight screen and I will likely start a new thread soon on this related topic , but here's a sneak peak at a front window screen I mocked up today. Slips into the window groove and laps the top of the glass which rolls up to clamp the screen into place.
Unfortunately the overall size might make shipping a bit of a $$ problem but at least my westy will have them . Gerald
Gerald: For some destinations, check the cost of sending via Greyhound Bus. You have to take them to your local terminal, and the buyer will have to go to his bus station to pick them up, but it should cut shipping to less than half. I used to make a 3-wheel pedaled vehicle for the handicapped we shipped that way; Greyhound's size limit is huge, and an accommodating weight limit, too. I shipped a Ford 3-speed tranny once, and I bought an extra targa top for a Porsche 914 once; it was 46 x 32, and no problem. Check first to see if they've reduced limits, |
Posted: Sun Apr 19, 2015 9:32 am Post subject: |
The front window screens are not able to stay in place when the window is up. The screen fits into the track where the glass slides up/down and the glass actually holds it up into place!
I have used Grayhound to ship larger heavier items within Canada but not for lightweight stuff like this. Plus I have a post office within 10 round trip from my house but. The Grayhound terminal is over an hour round trip in traffic and likely $8 in gas in my truck so hardly convenient even if it was several dollars cheaper. _________________ Gerald
Check out my Classified Ads for neat stuff:
https://www.thesamba.com/vw/classifieds/detail.php?id=2364358 |
photogdave Samba Member
Joined: April 05, 2004 Posts: 3053 Location: Vancouver Island, B.C.
