igotta40 Samba Member
Posted: Wed Nov 08, 2017 11:25 pm Post subject: Re: Installing Door Panels |
Igotta40
My compliments on your work!
Question- my first time doing this, how did you get the window cranks off, and put back on? |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Thu Nov 09, 2017 4:48 am Post subject: Re: Installing Door Panels |
on the 73 you peel/pop off the cover and there is a screw. the cover does not come all the way off, just hangs on the opener, but enough room to get a screwdriver in there I used a popsicle stick last time so I did not mar up the cover. |
Posted: Fri Nov 10, 2017 8:55 pm Post subject: Re: Installing Door Panels |
I think I get what you're saying, I'll try tomorrow, thanks |
Posted: Tue Nov 14, 2017 4:51 am Post subject: Re: Installing Door Panels |
what went wrong? |
Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Fri Mar 30, 2018 10:30 am Post subject: |
skills@eurocarsplus wrote: |
asiab3 wrote: |
curtis4085 wrote: |
That vapor barrier is missing the inner flap |
Does anybody here know for certain if the factory installed the flaps on early bays without the flow through ventilation vents? I have never gotten a 100% certain answer. |
yes. I can verify that on 69, 70, 71 they had flaps. never parted a 68 so I cant say for sure |
I know this thread is old, but I came across it during research and found this detail unconfirmed...
My 68 did NOT have the flap. My original plastic was held on by some sort of black gooey adhesive. The plastic was brittle and a lot was gone, but there was no extra flap.
Sounds like a good idea though, so I'll be including one when I replace the plastic liner.
By the same logic, would a flap for that lower opening also be prudent? I know that's where my panels got the most water damage. _________________ ~Kevin
My 1968 Campmobile |
