Drain 4spd tranny warm or cold ?
the joker
the joker is offline
PostPosted: Fri Jun 20, 2014 6:09 pm    Post subject: Drain 4spd tranny warm or cold ? Reply with quote
Ready to change the hyp gear oil in the 4spd should you drain it cold?
Few people told me to run it a while drive a few then drain
My thoughts are the shit in the bottom ( cold) will drain out
If it was warm all that shit would be smeared out all over the place Rolling Eyes
Jon_slider
Jon_slider is offline
PostPosted: Fri Jun 20, 2014 7:54 pm    Post subject: Reply with quote
lol
warm
if you drain cold, a thicker coating of old oil stays behind
My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco
joseph928
joseph928 is offline
PostPosted: Fri Jun 20, 2014 8:36 pm    Post subject: Trans Reply with quote
Hot or cold doesn't matter, just takes longer cold. Did mine cold just let it drain tell no more oil comes out. Like 2 hours for me! And it helped to have the front end up. Very Happy
1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug.
dobryan
dobryan is online now
PostPosted: Fri Jun 20, 2014 9:49 pm    Post subject: Reply with quote
IMHO warm is better (you are going to let it drain for a while so nothing is really going to be stuck to anything if significant), but best is to change it.... warm or cold! Very Happy
Dave O
Join the Vanagon Rescue Squad on the VanAlert app.
http://vanalert.com/
Building a bus for travel in Europe
IdahoDoug
IdahoDoug is offline
PostPosted: Fri Jun 20, 2014 10:16 pm    Post subject: Reply with quote
Warm. I always have my oil drain pan out for engine or diffy or tranny drain time so when I come back to the garage I have the drain plug out within a minute or two. I also remove the fill plug first so the oil can come out at high velocity, and also because it's good practice in case the fill plug strips or otherwise won't come out so you are not stranded.
DougM
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa project in pieces.
Wildthings
Wildthings is offline
PostPosted: Fri Jun 20, 2014 10:52 pm    Post subject: Reply with quote
If you drive the van for a bit before pulling the plug, more nasties are apt to be held in suspension and will be removed with the oil.
the joker
PostPosted: Sat Jun 21, 2014 8:45 am    Post subject: Reply with quote
Drained it -normal metals on the magnet-small stalagmite of 90K of wear Confused
Filled it 1.6 qts plus -but don't feel any at the plug hole shouldn't I Confused
It's on a slight grade in my driveway but still, don't have my Bentley
Any input would be appreciated
Randy in Maine
Randy in Maine is offline
PostPosted: Sat Jun 21, 2014 8:56 am    Post subject: Reply with quote
I always warm up the new gear oil in the microwave so that it pours or pumps easier.
the joker
PostPosted: Sat Jun 21, 2014 9:03 am    Post subject: Reply with quote
Anyone have their Bentley handy - need the capacity if a 84 1.9 originally
T-25 4spd. Was I wrong to think 1.6qts. Is it more like 3.6qts
the joker
PostPosted: Sat Jun 21, 2014 9:17 am    Post subject: Reply with quote
Just goggled it 2.8qts- is that correct?
Snort
Snort is offline
PostPosted: Sat Jun 21, 2014 10:15 am    Post subject: Reply with quote
The manual says 3.2 quarts.
However, it also says after that spec, "To reduce shifting effort, transmission oil capacity has been reduced. ... Oil should only be poured in to a level approximately 15mm below the hole."
Wildthings
PostPosted: Sat Jun 21, 2014 10:44 am    Post subject: Reply with quote
I tried that BS when I first bought my Syncro as it couldn't hardly be forced into gear. As one would expect dropping the level made zero difference.
Jon_slider
PostPosted: Sat Jun 21, 2014 10:52 am    Post subject: Reply with quote
yes, fill it full til it runs out the hole, with the van level. I recommend Mobil Delvac 75w-90
http://www.thesamba.com/vw/forum/viewtopic.php?p=7235988
70coupyel
70coupyel is offline
PostPosted: Sat Jun 21, 2014 12:26 pm    Post subject: Reply with quote
I just had mine rebuilt and my rebuilder said to put 3.2 qts. in.
How much oil are you guys putting in when you fill it to the fill hole?
TheAndante wrote:
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc.
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer
