Manfreds78bay Samba Member
Posted: Fri Jun 20, 2014 10:46 am Post subject: Post Front Suspension Rebuild Questions |
Hello All,
I'm about done with my front end rebuild. She got a new beam, ball joints, tie-rods, and drag link.
Once everything is done, what next? Do I need to get an alignment? Will it be okay to test drive? My plan is to make sure the tie rods are the same length as the old ones. I bought two adjustable tie rods. What should I pay attention to during the install as far as setting up the steering?
I have a trip coming up over the 4th of July weekend and I want to make sure my rig is safe to drive with all new front end components.
Thanks. _________________ 1978 2.0L FI Campmobile
1982 AMC Eagle SX4 4.2L FI |
airschooled Air-Schooled
Posted: Fri Jun 20, 2014 11:04 am Post subject: Re: Post Front Suspension Rebuild Questions |
Manfreds78bay wrote: |
Once everything is done, what next? Do I need to get an alignment? Will it be okay to test drive? My plan is to make sure the tie rods are the same length as the old ones. I bought two adjustable tie rods. What should I pay attention to during the install as far as setting up the steering? |
That sounds like a good start to getting the parts installed, but you will need to follow the correct procedure to get your steering set up correctly. You could get it until the wheels and steering wheel are straight, and you could drive it and feel good, but it would ruin your steering box and maybe other things. It would be a shame to spend all that time/money just to make a worse problem. Your service manual has the correct steps to take, but the steering box must be centered first.
The box needs to be able to rotate freely to do this. You can do it now while everything is disconnected. Then make sure the pitman/drop arm is installed on the box correctly; there are notches on the arm and shaft that need to line up. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Wed Jun 25, 2014 9:58 am Post subject: |
I've been calling around to alignment shops and keep getting turned down. They say they can't do my alignment because my vehicle is not in their computer.
I found a shop mentioned on the Samba that is close to my home relatively speaking. He was nice enough to tell me that what they are telling me is hog wash. He said that all the computers can be over ridden to input specific specs or just tell them to look up a 93 Vanagon, which should be pretty close.
I'm just going to show up to a shop early on Saturday with my Bentley and just argue them down.
Wish me luck. _________________ 1978 2.0L FI Campmobile
Skoolieman Samba Member
Joined: January 31, 2011 Posts: 573 Location: Chattanooga TN
Posted: Wed Jun 25, 2014 10:48 am Post subject: |
Why not do it yourself. I just did mine and it was a lot easier than I would have ever imagined and made a huge improvement-not to mention I saved 60 bucks _________________ '69 Westfalia Camper~Cassidy
1600dp with H30/31 carb 009 distributor and alternator conversion |
Posted: Wed Jun 25, 2014 10:52 am Post subject: |
I'm taking a a long trip up to the Michigan UP over the 4th of July weekend. I've never done it before and I don't want to guess at something and ruin all my new parts. If I had more time to play with it I would learn it. _________________ 1978 2.0L FI Campmobile
Desertbusman Samba Member
Posted: Wed Jun 25, 2014 2:26 pm Post subject: Re: Post Front Suspension Rebuild Questions |
My plan is to make sure the tie rods are the same length as the old ones. I bought two adjustable tie rods. |
It was a mistake pretending to outguess VW and putting on 2 adjustable tierods. One nonadjustable tierod as was stock is there for a reason that you have poopooed
Don't adjust your tierods based on how they were before. Maybe the prior person working on it didn't know what they were doing either.
You want to adjust the LH tierod to the exact same pin to pin length that a stock nonadjustable tierod has. Sorry, I don't remember the dimension, you'll have to do some homework. And then adjust the toein per the book with your adjustable RH tierod. It's critical to adjust the drag link so the steering box is centered like we have outlined in detail in the past. _________________ 71 Superbug
71 Westy |
wcfvw69 Samba Purist
Posted: Wed Jun 25, 2014 6:25 pm Post subject: |
Yes, you should get it aligned correctly. You removed the eccentrics from the upper ball joint. They affect the camber and a little for the caster. As Desert Bus stated, you need to also set the toe in/toe out as well.
Any reasonable alignment shop should be able to align it. It's not rocket science. _________________ Contact me at [email protected]
The Samba member since 2004.
GMATech Samba Member
Joined: September 03, 2012 Posts: 220 Location: South East Pennsylvania
Posted: Wed Jun 25, 2014 7:22 pm Post subject: |
Do not attempt any sort of alignment at home. Maybe just to get it in the ballpark, but alignment equipment measures the wheel angles to the hundredth of a degree. You want it to be accurate for tire life and proper handling. _________________ 77 westfalia vr6 project
72 standard beetle project - for sale
ASE Master Tech since '03 A1-A9 L1 L3 G1
PA safety and emissions inspector
General Motors guru |
Posted: Mon Jul 07, 2014 8:54 am Post subject: |
So after calling around to a lot of shops, I finally got a hold of a reasonable person. He told me to just drive in without an appointment and give the guys the specs. Which I did and it worked. I went to a local Firestone shop who turned me down on the phone. But when I pulled up with the specs they seemed happy enough to help me out.
I did 1000 mile road trip this weekend without a hitch.
Thanks for the help. _________________ 1978 2.0L FI Campmobile
