Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9808 Location: Mt Lemmon, AZ
Posted: Fri Jun 27, 2014 3:39 pm Post subject: Removing broken bolt from aluminum - a new twist |
New to me anyway -- I had never heard of the technique described here:
Dissolving the steel bolt
Of course, it has to be a part you can submerse, but nonetheless an interesting process. |
sanchius Samba Member
goffoz Samba Member
Posted: Fri Jun 27, 2014 8:22 pm Post subject: Re: Removing broken bolt from aluminum - a new twist |
Ahwahnee wrote: |
Yep this is really old school stuff...i'm really old in a old school proffession
but have been doing this for years, in machining you often break a drill bit in a deep hole ,if you can't submerge the part, you dam it with putty/clay, and fill the hole with alum solution and use a mini immersion heater to keep it hot...in reality it takes a couple of hours to rot it out.
...usually an overnight thing
The quick method is to carefully apply drops of concentrated nitric acid.
stuffs hard to get nowadays |
rubbachicken Samba Member
Posted: Sat Jun 28, 2014 2:33 am Post subject: |
i'm liking this, very useful to know
revitalizing older forgotten ways, doing things old school is the way IMHO _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
pushkick Samba Member
Posted: Sat Jun 28, 2014 10:14 am Post subject: broken bolts |
never thought about using acid. but you could take to a local machinist and he could edm, waterjet, or mill out the bolt or broken easyout. _________________ i see said the blind man to his deaf dog
i am going to quit smoking and drinking and die a healthy man. gotta laugh
there is no deed to the planet earth
1990 vw automatic camper |
