jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Sun Jun 29, 2014 4:40 pm Post subject: Suddenly running hot |
As part of my preparation and detailing of a 1979 Transporter readying it for sale, this morning I cleaned up the engine compartment. In the course of cleaning, as is typical I bumped loose a hose here and a wire there. Got them all reattached, and the engine fired up fine. I took it out for a 10-minute drive to get the oil warmed up for changing, and when I got back the engine was unusually hot, though it runs and idles fine. Normally, the dipstick is cool to the touch, but it was really hot this time. Never seen that before.
I am running a 2.0-L GE fitted with a single Weber carb. It has run this way just fine since I got it about 1000 miles ago.
I've tried to trace down the usual suspects... vacuum leaks, for example. I find none. There are not many places to check on this carbureted engine.
I did not adjust timing or any other engine parameters.
What could be causing running hot all of a sudden? _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Danwvw Samba Member
jtauxe Samba Member
Posted: Sun Jun 29, 2014 6:03 pm Post subject: |
Danwvw wrote: |
Check the timing, see if it is advancing! |
Well, the distributor is clamped down tight, but I guess it does not hurt to check...
The timing seemed slightly advanced, sitting at 32 BTDC. I moved it to the mark on the timing scale at 28 deg. We'll see how things go.
Q: Is there an altitude correction to be made for timing? I live at 7300 ft (2225 m) elevation. _________________ John
http://vw.tauxe.net
curtis4085 Samba Member
Posted: Sun Jun 29, 2014 6:35 pm Post subject: |
Is the egr blocked off? Possible big leak. Experienced this recently myself. Luckily I had a LM-2 meter and caught it within seconds.
Also check for loose valve cover. Big vacuum leak if the gaskets not seated. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
SGKent Samba Member
Posted: Sun Jun 29, 2014 6:49 pm Post subject: |
Is the fan guard on? If not check to see if the fan ingested a rag etc.
Check the flaps to make sure they open all the way. |
jtauxe Samba Member
Posted: Sun Jun 29, 2014 7:44 pm Post subject: |
SGKent wrote: |
Fan guard intact. No rags.
Cooling flaps -- also worth a check, esp. since I just installed a thermostat. _________________ John
http://vw.tauxe.net
busdaddy Samba Member
Posted: Sun Jun 29, 2014 8:52 pm Post subject: |
jtauxe wrote: |
I just installed a thermostat. |
Hmmmm.... and the lower sled tins?, maybe a check for binding linkage is in order. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Danwvw Samba Member
Posted: Sun Jun 29, 2014 10:17 pm Post subject: |
32' dynamic that's with everything hooked up and engine reved to 3400 RPM or So? It may be retarded! That would sure cause heat! It should be about 40' Advance if it's the 205 Distributor they came with. It should drop back to 7.5' Degrees or so at Idle. http://www.oldvolkshome.com/ignition.htm#B7679
Add the 7.5' static+10'Vacuum+22.5'Centrifugal=40' See the OldVolksHome Link ref. above "Distributor: VW 021-905-205P, Bosch 0231 168 005 > 022-905-205S, 0231 170 093 Note: 0231 170 093 dist primarily used on California Late 1976-1978 and all Federal 1979 Models".
It could run as high as 43' or as low as 39' full advance no load at 3400 If I read the reference correctly. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Sun Jun 29, 2014 10:26 pm Post subject: overheating |
perhaps The thermostat cable is hanging up in the tin before it is hooked
to the flap crossbar.
Look in the hole where the cable comes through the tin.
my $0.02 _________________ V.W.owner since 1967 |
Posted: Mon Jun 30, 2014 4:43 am Post subject: |
Danwvw wrote: |
It could run as high as 43' or as low as 39' full advance no load at 3400 If I read the reference correctly. |
Set timing with vacuum hose off and max advance all in 3500 rpm. Dial it to 30*btdc. Make sure your engine at operating temp when doing this. _________________ Special Thanks to:
jtauxe Samba Member
Posted: Mon Jun 30, 2014 7:33 am Post subject: |
curtis4085 wrote: |
Danwvw wrote: |
Set timing with vacuum hose off and max advance all in 3500 rpm. Dial it to 30*btdc. Make sure your engine at operating temp when doing this. |
I obviously should have mentioned the type of distributor... it's an 009, so it has no vacuum advance.
I'll warm it up and put the advance back to 32 degrees BTDC. I don't think that had changed anyway, and would not be the cause of the sudden heating.
old DKP driver wrote: |
my $0.02 |
Good thinking, but the thermostat and flaps are working as intended.
I'll be taking it out for a drive again today, rather gingerly, to see if I can reproduce the problem. _________________ John
http://vw.tauxe.net
jtauxe Samba Member
Posted: Wed Jul 02, 2014 9:36 am Post subject: |
Interestingly, the overheating problem seems to have gone away. I suppose as I futzed around with vacuum hoses and timing and such I must have fixed whatever was wrong. It's nice that it is solved, but not nice that I never did determine the exact cause. :k Oh, well, sometimes you just have to roll with it and be attentive to things as you go.
For now, I'm good. _________________ John
http://vw.tauxe.net
Posted: Thu Jul 03, 2014 5:10 am Post subject: |
If I set my max advance to 32*btdc rpm all in I start to build heat, if I set it to 30*btdc it runs lot cooler.
Idle timing for me sit 5-6* btdc. Having a improved cam I run a 13.5 AFM she idles smooth. _________________ Special Thanks to:
SGKent Samba Member
Posted: Thu Jul 03, 2014 7:39 am Post subject: |
curtis4085 wrote: |
Idle timing for me sit 5-6* btdc. Having a improved cam I run a 13.5 AFM she idles smooth. |
we get the same. Power starts to fall off at 29 degrees but 28 - 29 is cooler than 30 to 32. These 2L buses just can't shed the heat they can make so they have to be detuned. We'd see more power at 32 degrees and a leaner AFM but we'd also be replacing heads and pistons more frequently too. Shame VW didn't build in 10 - 15% more cooling. |
