Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 679 Location: SE Oklahoma
Posted: Mon Jun 30, 2014 7:58 am Post subject: Spark plug wire popping off |
Was test driving my '71 Super after installing new electronic ignition distributer. Ran fine at first but suddenly lost power. Barely made it home. Saw that wire popped off #2 plug. No big deal, I thought and reattached. I decided to double check timing and as I revved up the engine the same plug wire popped off again. What could be causing this? _________________ 1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to." |
Randy in Maine Samba Member
Posted: Mon Jun 30, 2014 8:17 am Post subject: |
Try putting a little squeeze on the wire with your needle nose pliers. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Mon Jun 30, 2014 9:05 am Post subject: |
is it this original type? If so make sure the clip is still there
(I know it's broke just for reference ) _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Mon Jun 30, 2014 9:40 am Post subject: |
I recently had the same thing happen to my car. Took a friend on a ride and after shifting 3rd, I dropped a cylinder. I pulled over and found #4 wire laying there. I put it back on and everything was fine.
It came off as I shifted @ 6400rpm so I assume the air pressure pushing on the spark plug wire air seal forced the wire off.
I replaced the wire end with a new one and it fits much tighter. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Jun 30, 2014 9:49 am Post subject: |
We bus guys use these instead of the bosch wiring seals with pretty good success at sealing up the cooling system. I want to say they are $10. I put a set on my friend's FI super and they have stayed on so far.
http://coolfj40.stores.yahoo.net/tierodbootfj.html |
