vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Thu Feb 25, 2016 6:04 am Post subject: Re: Dave's 1973 Wild Westerner Project |
I had a little time to work on it last night. I finally separated the old transaxle and the engine. I was thinking that since it wasn't that long since I had put it together, I'd not worry about the engine oil seal or clutch or any of that.
Well, it had other ideas. The seal was leaking and had made quite a mess in there, so it needs to be replaced. Also the clutch disc was worn enough to warrant replacing that too. Might as well get a pilot bearing too, even though that is also pretty new.
Oh well.
Also, the little square nut that holds the thermostat cable is stripped out. Does it have to be a square nut, or would a simple nut and bolt do for this? _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Tue Mar 01, 2016 6:27 am Post subject: Re: Dave's 1973 Wild Westerner Project |
Over the weekend, I applied the Master Series silver primer. It must be some pretty good stuff, because I got a little bit on my arm and that is not coming off!
Once it dried, it did seem to be very hard and secure.
For the whole project, I've just been working on the window frames, so nothing really visible. I taped off right at where the edge of the window rubber will be so even the tape lines should be covered.
Because my main goal is just to stop the rust and keep water out, and everything will be hidden by the window rubber, I didn't worry about making it smooth and pretty. Just stopped the rust for now with grinding and acid treatment, and the Master Series.
This is what I used to apply the mixed-by-code paint I bought:
http://store.preval.com/collections/preval-sprayer/products/preval-sprayer
I would say that overall it worked pretty well. The paint color is much closer than the mixed spray paint I ordered at first. This time it is regular automotive paint, pushed through the Preval sprayer.
I forgot to take any pics of the Master Series before painting most of it, until I was ready to paint the windshield area. Sorry they're a little grainy.
1973 Wild Westerner
My Thing |
Posted: Sun Mar 06, 2016 9:21 pm Post subject: Re: Dave's 1973 Wild Westerner Project |
Did some more work on the bus today.
The main goal was to get the engine into the bus.
I got real close.
For those following along, there are lots of little differences in the front tin that would have to be dealt with to install FI. I didn't buy different tin, I've been modifying the current tin.
I had to drill a hole for the pressure regulator. There was one that appeared to be in the right spot when the engine was sitting on the floor. However, it ended up that the nipple was interfering with the frame, so I had to drill a lower hole.
I also have elected to run both the brake booster line and the fuel line through the left side of the tin. On the '73, the booster line was all that went through the tin. On the FI buses, the booster line went through the body. I put a second hole in the tin, one for each.
I had to block off the old carb preheat hole on the right side. So I cut a piece of metal and bolted it in place. The riser is still there, just blocked off. The metal blocking it is sandwiched between the riser and front tin.
From pics I could see, it appeared that the accelerator cable went through a rather large hole that was closed up by a piece of rubber. So I made that.
The big problem was when I bolted the motor up.
I didn't remember that the accelerator cable went through the upper motor mount. I looked at it all and just decided it must be routed between the top of the bellhousing and the mount bracket. Oops. It was totally pinched in there by the time I was done!
Luckily for me, I have a later mount from the '78 in the garage, so it'll go in this week. By the time I realized my mistake, I was too tired so I showered and wrote this! _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Mon Mar 07, 2016 9:50 am Post subject: Re: Dave's 1973 Wild Westerner Project |
Here is a list of some things to consider if going this route (installing FI on a pre-FI Bus) that may or may not occur to you:
You'll need to cut a hole to mount the computer if you want it in the factory position. Otherwise you'll need to come up with an alternative way to protect it.
You'll need to attach the airbox mount. I've started by welding a bracket to it and screwing that to the body, but that may or may not be secure enough as time goes on.
You'll need to cut/drill a hole in the front tin for:
*vacuum line
*fuel pressure regulator
*accelerator cable
You'll also need to block a tin hole that was for the carb preheat.
The accelerator cable on FI routes through the upper bellhousing mount. You'll either need an FI mount, or drill a hole through yours in the correct location and attach a tube.
Mounting the fuel pump.
I also discovered that with the additional depth of the 091 transmission, the alternator to starter wire may be a couple inches too short. I need to double-check that it isn't caught on something. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Tue Mar 08, 2016 10:20 pm Post subject: Re: Dave's 1973 Wild Westerner Project |
This one was a little weird. I expected that swapping in the upper bellhousing mount would be simple.
However, the '78 mount wouldn't go in as easily as the '73 came out. The rubber mounts had the same part number and all that, but I had to swap the '73 rubber mounts to the '78 metal mount to get it to go in. The '78 rubber mounts were a couple mm longer despite the same part number. Maybe the '73 were a little compressed from hanging the engine while the '78 haven't had any weight on them in a couple years? Weird.
I also got the fuel pump side of the double relay wiring fixed up and in the bus. The hole in the bus for the wiring was sufficient to pass all the wiring through, but it required a grommet with a larger ID.
In crawling under the motor, I found a bit of extra wiring slack on the alternator wiring and I think that will be enough to hook that up.
Getting closer to hearing the engine run again! _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Sun Mar 13, 2016 12:08 am Post subject: Re: Dave's 1973 Wild Westerner Project |
Well it was a long-ass day of working on the Bus but I think I made a lot of progress!
I've got the engine installed and all put together. As it turns out, I think I bought some Vanagon FI parts mixed in with the Bus stuff I (thought I) bought. For example, the S boot, which seems to be shorter than a Bus one.
Oh well, with some pieces of copper pipe and rubber hose, I think I have all the large vacuum lines plumbed up.
I got the shifter hooked up, and axles reinstalled. I had to replace one of the axle boots. What a messy and nasty job. Ugh.
I finally got to where I could try to start the engine. I poured some gasoline in and gave it a shot...
No fire just yet. Rats. I know that the fuel pump runs when I push the flapper door, and I'm also sure I heard it run when I was cranking the starter. So that is a good sign.
I dumped a little gas in the boot and got one or two coughs each time but that was it.
However, by the time I got to that point, it was super late so I called it a night and took a shower.
When I went back to the garage to grab a drink, though, I thought the smell of gas was really strong.... I took a peek under the bus to see that there was a pretty strong drip/stream of gas leaking!
So I changed into work clothes (I've got a box out there) and was able to reset the fuel line and clamp to stop the leak. Unfortunately, I got some gas on me and had to take a second shower.
Tomorrow I plan to finish working on the slider door rear hinge so I can rehang it, then I can work on diagnosis of why the engine doesn't want to run yet. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Mon Mar 14, 2016 7:44 am Post subject: Re: Dave's 1973 Wild Westerner Project |
Progress this weekend.
I got the engine install buttoned up but I'm having a hard time with getting it to run.
http://www.thesamba.com/vw/forum/viewtopic.php?t=650213
I did install one window last night by myself, and it worked out OK though the seal did tear a little bit in one small section. I guess I need to re-read the installing windows thread!
I also freshened up the wipers a bit per Colin's post, though I didn't open up the motor itself. I installed a speaker to the dash as a center channel. I'm hoping it will fill in the gaps a bit from the two speakers that are mounted fairly low.
I was hoping to have the dash on yesterday, but somehow managed to scratch it! Damn! So I had to touch up that spot. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Sun Mar 20, 2016 9:40 am Post subject: Re: Dave's 1973 Wild Westerner Project |
I forgot to post pics of the underside of the dash with the speaker installed.
I ended up going with a 6" speaker which fit pretty well other than needing to notch the sides of the speaker housing to avoid interference with the heat tubes. It is wired up as a center channel so as I said, I'm hoping that it will bounce some of the higher frequencies off of the windshield and fill in for where those sounds get lost by the lower speakers that are under the dash.
As you can see, I put some Reckhorn mat on the underside of the dash too, to avoid having it buzz/vibrate. I also put some foam weatherstripping along where the speaker touches the dash to further avoid buzzing, etc. Because it is white and was partially visible from above, I covered it with a piece of electrical tape.
1973 Wild Westerner
My Thing |
Posted: Sun Mar 20, 2016 9:55 am Post subject: Re: Dave's 1973 Wild Westerner Project |
I spent several hours with the Bus yesterday.
The projects included installing a pump for the washer fluid, and a switch to operate the pump
I also installed the rear defroster heater kit I had ordered previously.
I finished the dash install.
I got the back window as well as a couple of the slider windows installed, too.
The seals seemed to fit well on the back windows, but there is a gap in the front bottom corner of the middle window of the slider. I had a hard time with installing the slider windows. It wasn't the worst thing ever, but I think the seal did catch and slightly tear in somewhere on each one. The back window installed significantly more smoothly. I did all of the windows (two rear sliders, middle slider, and back window) by myself.
I'm hoping that will possibly settle in a little bit as time goes on and I start driving it again. It actually did look like a little bit less of a gap this morning compared to last night.
I'm having a friend come over to help me with the other middle slider and the windshield this afternoon.
Once those are in, the main thing to do before I can drive it is just wait until the injectors are re-cleaned and returned. 3 of the 4 injectors were frozen stuck shut.
I do have upgraded headlights with relays I may install while I'm waiting for the injectors. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Sun Mar 20, 2016 10:27 am Post subject: Re: Dave's 1973 Wild Westerner Project |
oops! the speaker I told you about was for a early bay. sorry about that
looks like you have it sorted, and you will be amazed by how that one center channel works _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Sun Mar 20, 2016 6:37 pm Post subject: Re: Dave's 1973 Wild Westerner Project |
skills@eurocarsplus wrote: |
looks like you have it sorted, and you will be amazed by how that one center channel works |
I had no idea the dash tops were different until your comment made me go look at a pic of your '71's dash.
But, your comment along the way of the Kicker brand not having the center protrude as much was helpful when I looked to get my speaker. That proved true for this speaker as well.
Also, I'm glad you commented and confirmed that anyone was actually seeing this thread anymore!
Do you *only* have that speaker? I've got two under the dash as well. In my reading about center channels, I found you could control the volume of the individual speaker with a variable resister. I may turn the center speaker down a little bit but otherwise it does sound nice with the windshield in. The sound does seem to bounce off of it and toward me as anticipated.
The brackets were from the PO's speakers. The housing for the new 6" speakers are 6" PVC pipe cap, with the cap part cut out. (The back is open.) Black plastic spray paint worked nicely. They work pretty nicely and are unobtrusive, and not as low as other speaker options.
Today I got the side window and windshield in. Unfortunately, the damn windshield cracked while installing! Dammit!! Oh well, I can drive it for now (once the injectors come back) and find another I guess.
I also installed European style headlights with a relay kit from Bus Depot. I bought their VisionKit that is marketed for early Vanagons. However, it plugged right into the Bus wiring almost exactly like they described except I didn't change the headlight grounds, and the red wires plugged into a different fuse.
I had made my own relay kit for the '78 but this time I had decided I'd try a simpler version. The install was super easy-it came with the headlight housings, pre-wired relays, and the bulbs.
The bulbs in my '78 both burned out recently so I used both spares I had on hand, so I'll need to order some more.
This pic shows the difference in the high beams against my garage door. When I took it, I had installed the relays and the left European light. So left is the upgraded lights, right only has the relay upgrade.
I miss driving this bus, and I'm anxious to test the FI out! I can't wait to get those injectors back! _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Sun Mar 20, 2016 7:20 pm Post subject: Re: Dave's 1973 Wild Westerner Project |
in my deluxe I have the dash speaker, 2 in the rear hatch and 2 10" subs.
in the westy I have dash speaker and 1 in each front door (p/o install)
the deluxe has a real clean sound. the 2 in the rear hatch make a huge difference.
the deluxe was a challenge to run the wires. I HATE, HATE,HATE wires all over the floor so I spent a ton of time snaking wires all over the place.
the hatch wires run along the roof and down the A post. then the sub wires also run along the roof, but down the C post...that was a huge challenge. add to that the amp power wire, which also runs down the C post.
it was not a fun project as you had to drill into the C posts from the roof...there are like 3 panels that come together in there. _________________
Jake Raby wrote: |
Brian wrote: |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Sun Mar 20, 2016 8:17 pm Post subject: |
vwwestyman wrote: |
secretsubmariner wrote: |
Nice!
Beautiful bus, man. Enjoy it!
Do you have any interior pictures? |
No interior pics. All of the seats are pretty rough, especially the fronts. If I do get it running very soon, I might invest in some foam from Wally World to throw down on them for a little bit.
I'm thinking something along the lines of what these guys did with theirs, only in blue plaid would be pretty sweet.
FYI and FWIW, the upholstery color for the Wild Westerner Appearance Group is black. But that blue plaid does go well with the paint scheme! _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
jtauxe Samba Member
Posted: Sun Mar 20, 2016 8:18 pm Post subject: |
vwwestyman wrote: |
Just ordered a set of Hankook RA08s for it, to be put on tomorrow.
I think I'll slap a coat of paint on the rims tonight. Won't be perfect, but will be a little prettier.
What color should I go with? Silver, white, or blue? |
FYI and FWIW, the original rims would have been silver. _________________ John
http://vw.tauxe.net
Posted: Sun Mar 20, 2016 8:26 pm Post subject: |
jtauxe wrote: |
vwwestyman wrote: |
FYI and FWIW, the original rims would have been silver. |
Yes, I did end up going with silver. I had seen a pic somewhere of a Westerner with Porsche (Phone Dial, I think) rims painted the blue color of the stripe and thought they were cool, but ended up with Silver.
I think the reason I even considered white is that was the color of the rims on my '78. Recently I read that the rims on the Champagne buses were painted to match the top half. _________________ Dave Cook
1973 Wild Westerner
My Thing |
jtauxe Samba Member
Posted: Sun Mar 20, 2016 8:30 pm Post subject: Re: Dave's 1973 Wild Westerner Project |
vwwestyman wrote: |
<snip> I also painted the driver side "track" cover, though I'm not happy with the color of the paint I ordered. I ordered two rattle cans of paint mixed to match the upper green but it is pretty far off. |
I tried the Ravenna Green that Sherwin-Williams Automotive Division had in their system, and it is pretty close! I also had them match (and add to the system) the Apple Green for these Wild Westerners. So you might try them. _________________ John
http://vw.tauxe.net
jtauxe Samba Member
Posted: Sun Mar 20, 2016 8:35 pm Post subject: Re: Dave's 1973 Wild Westerner Project |
vwwestyman wrote: |
<snip>
I'm thinking while it is off, I will also work on the windshield washer system--replacing the sprayers, the hoses, and the wiper shaft bushings.
Good sources for those? (Spray nozzles and wiper shaft bushings.) |
Do you mean these?
http://www.busdepot.com/311955261a
And maybe these, for an upgrade to the nozzles...
http://www.busdepot.com/211955993ds _________________ John
http://vw.tauxe.net
Posted: Sun Mar 20, 2016 8:36 pm Post subject: |
jtauxe wrote: |
vwwestyman wrote: |
Nice!
FYI and FWIW, the upholstery color for the Wild Westerner Appearance Group is black. But that blue plaid does go well with the paint scheme! |
I have not done anything with the seats yet. I still think the blue plaid would probably look good but I'm undecided. It would probably also be more comfortable than the vinyl. I dunno...
I think I'd like to get a 3-person middle seat, and I've spotted one that isn't too terribly far from me. This may or may not be irrational, but at least part of what is holding me back from getting it is I'm afraid of facing the facts of what rust may be in the floors!
The body looks pretty good, but the floors do have some rust from water leaking in the old windows for so long and being trapped under the rubber mat.
All that to say, I'm very indecisive with what I'd do with the interior at this point.
I know that seat covers would be fairly easily reversible if I should decide I didn't like them, but that sure wouldn't be cheap!
The only thing I can say for sure is that the front seats will be heated.
The other thing I'm indecisive about is whether or not to install the BA6 heater I have sitting in the shed. Luckily it's getting to be spring so I can put that off for a while.
Side note: As I was typing this, I had an ADD moment and hit the "show my recent gallery photos link just below this text box. I never noticed that feature before but what a great idea! From that feature, here is a pic of the Westerner being a little Wild last summer. I've since replaced the front emblem.
1973 Wild Westerner
My Thing |
