How did this happen? |
Somebody used a Fram filter from Wmart |
7% |
[ 1 ] |
Somebody had oil changes done every year or 2, at Jiffy Lube |
14% |
[ 2 ] |
Somebody didn't use proper rated tires |
21% |
[ 3 ] |
That is what always happens when 2.1 rod bolts get old |
35% |
[ 5 ] |
The engine heard the word Subaru being discussed and threw a fit |
21% |
[ 3 ] |
Total Votes : 14 |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9936 Location: Orbiting San Diego
Posted: Thu Jul 03, 2014 5:53 pm Post subject: 2.1 wbx parts identification help needed |
I recently acquired a used 2.1 wbx engine. As I was moving the engine a piece fell onto the floor. When I looked on top of the engine there were more loose pieces. These were all laying on top of the case under the intake runners. There were some strange looking dark areas on the top of the case as well. What are these parts? How did they get on top of the engine? What sequence of events could have led to this happening?
Mark |
Vanagon Nut Samba Member
Posted: Thu Jul 03, 2014 6:05 pm Post subject: |
Good golly. Miss Moly?
Is that what I think it is? Piston and ring shrap?
Edit: and case shrap?
Wow. Just, wow.
1988 West DIY 50º ABA
VE7TBN |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Thu Jul 03, 2014 6:06 pm Post subject: |
pieces of a exploded grenade?
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Thu Jul 03, 2014 6:12 pm Post subject: |
Hmmm A game of Clue!
Tired engine. Low oil pressure to #3 main bearing. Bearing seizes. Rod bolts break. Rod through case. Owner either A) Gives up B) Searches TheSamba and every engine conversion under the sun is recommended.
And Colonel Mustard in the living room with the candlestick is to blame. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Thu Jul 03, 2014 6:13 pm Post subject: |
Meteorites.
Or just some bits that got homesick and were heading back to Hannover.
Hope it wasn't option 1 as I do use the orange filter from the blue store. |
chazz79 Samba Member
Posted: Thu Jul 03, 2014 8:25 pm Post subject: |
I took some stuff off of the engine to get a picture of the strange dark areas on the top of the block. I think those other bits came out of them.
I am still curious what the chain of events was.
The guy I got the engine from said it already didn't run when he got it. He just pulled it complete to do a conversion and gave me the leftovers. It was all fully assembled when I got it. I may find time to take the heads off and see if they are usuable cores before I scrap it. The intake runners have small bits of metal inside them all the way to the plenum.
Mark |
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Thu Jul 03, 2014 11:13 pm Post subject: |
Yikes. That block has been lightened. _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1890 Location: Montreal
Posted: Fri Jul 04, 2014 2:41 am Post subject: |
This is one of those rare barn finds. Been sitting and the mice got at it. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Jul 04, 2014 7:29 am Post subject: Re: 2.1 wbx parts identification help needed |
crazyvwvanman wrote: |
...What sequence of events could have led to this happening? |
Surprised you don't know all about this: http://volksweb.relitech.com/21rodbrg.htm
Ventilated block - rare option. _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Fri Jul 04, 2014 7:52 am Post subject: Re: 2.1 wbx parts identification help needed |
Did you read the poll options I gave?
Of course I expected most people to just assume the failure is due to the much mentioned 2.1 rod bolt failures. But the 2 rods where the 2 extra case holes are look to be still bolted to the crank journals. More on that later.
Mark
dhaavers wrote: |
Ventilated block - rare option. |
insyncro Banned
Posted: Fri Jul 04, 2014 8:04 am Post subject: |
Does the crank still spin?
The shrapnel looks like layers of case and JB Weld. |
1vw4x4 Banned
Posted: Fri Jul 04, 2014 8:57 am Post subject: |
You are the proud owner of one of those rare self venting engines. Several people locally have tried to make these but I've stopped them in the nick of time. One person (locally) was putting new head gaskets on one just to
make a vent hole!
SO, you'll get a lot of good parts.....
Zeitgeist 13 Samba Member
Posted: Fri Jul 04, 2014 9:15 am Post subject: |
I'm kinda surprised that pieces of the piston came out the top.
Incorrect amperage fuses will do this every time _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Fri Jul 04, 2014 10:59 am Post subject: Re: 2.1 wbx parts identification help needed |
Hmmmm, interesting. Veerry interesting.
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Fri Jul 04, 2014 11:00 am Post subject: |
This is why everyone says to change your fuel lines! _________________ '86 Syncro Westy SVX |
Posted: Fri Jul 04, 2014 11:34 am Post subject: |
The bits and pieces seem to be all from pistons. Looking in through the larger new hole at cyl #1 you can see the small end of rod and the entire wrist pin is there fully exposed. The various loose bits of piston are so hammered and rounded that I have to think the engine continued to turn long after the basic failure occurred. That countless small bits of metal made it up the intake runners also points to a longer term destruction and that is why I am curious about the sequence of events. Who could keep moving down the road with the horrendous noises that must have been occurring? I have heard stories about tow trucks driving off with the tranny in a low gear but that is mere speculation in this case. Or maybe when whoever was driving the van experienced the problem they decided to just keep driving until it wouldn't go any farther.
Mark |
Posted: Fri Jul 04, 2014 12:34 pm Post subject: |
...decided to just keep driving until it wouldn't go any farther... |
Did this once with a Chevy Malibu in grad school...50 miles to get to the scrap
yard...kept going another 20 miles after the rod broke the case, spraying oil all
over the car following behind. (My wife, running support in case of plan B.)
Every mile closer to the scrap yard was one less to pay for towing. Made it the
whole way, so I saved $50 and then pocketed another $150 for the scrap.
"The WonderVan"
Posted: Fri Jul 04, 2014 1:32 pm Post subject: |
The result of not using hand planked rods |
