Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Mon Jul 14, 2014 11:48 pm Post subject: |
but it means my gas gauge works, and since its under a seat cusion, i dont care that i have a hole on each of the busses i have. plus, on the 72, we plan on installing a vanagon hatch too...i dont like having such little acess to the engine... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Tue Jul 15, 2014 8:25 am Post subject: |
Stuartzickefoose wrote: |
but it means my gas gauge works, and since its under a seat cusion, i dont care that i have a hole on each of the busses i have. plus, on the 72, we plan on installing a vanagon hatch too...i dont like having such little acess to the engine... |
I get that... I totally do. After I renewed my fuel system, recalibrated my sender and replaced the gage voltage stabilizer on my 1977 bus, everything worked great!
For about three months.
I then replaced the gage vibrator/stabilizer up in the dashboard, hoping that would solve my problem. Nope!
I totally agree with having easy access to the sender...especially since it is difficult to find high quality sending units to begin with. But trying to get the corrugated sheetmetal to lay down the way it was stamped at the factory was difficult without causing more creases on the long bend. It was a shitload of work just trying to get it somewhat right. Doesn't help that I suck at bodywork! I guess it comes down to a personal decision. It could be argued that cutting a hole into the tank recess through the passenger cabin creates a safety hazard, but that's a whole other argument.
In the end, I will lower or pull out the 1977's engine (again!) just to dick with the sender. I wish my PO didn't cut that hole in my 1973 bus, but so far, at least that fuel system seems to be working. |
Posted: Wed Aug 20, 2014 11:31 pm Post subject: |
i managed to somehow not have a horn for the last few months...finally fixed a bad ground last week right at the horn. glad i got that solved!
in the process, my kickpanels get more and more worn every time i tear them out and put them back...only a matter of time (removed for testing and such) _________________ Stuart Zickefoose
206-841-7324
[email protected] |
richparker Samba Member
Joined: November 24, 2011 Posts: 6983 Location: Durango, CO
Posted: Mon Aug 25, 2014 9:29 pm Post subject: |
Today after work I hoped into the bus, pushed in the clutch and POP. Oh shit! First I looked at the spring on the transaxle, it was fine. Then I pulled the pan to find a mostly destroyed clutch cable. Dam, that cable only had 7,000 miles on it. I carry a spare cable, clevis pin and Bowden tube. The tube was fine so I installed the new cable and clevis pin in the parking lot at work. Yes, I greased the cable. Took about 30 min and I was on my way. Can't forget to get another back up cable and clevis pin.
_________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
wcfvw69 Samba Purist
Posted: Mon Aug 25, 2014 9:50 pm Post subject: |
richparker wrote: |
7k miles and it popped?
Where did you buy that cable and are you running a heavier than stock pressure plate? _________________ Contact me at [email protected]
The Samba member since 2004.
that reminds me...i still need to buy another spare. i apparently didnt have a spare last month when mine went out on me after less then 10k miles...
and i need to get a good way to have grease stored in the bus for such repairs... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Mon Aug 25, 2014 10:58 pm Post subject: |
wcfvw69 wrote: |
Where did you buy that cable and are you running a heavier than stock pressure plate? |
I am running a heavier pressure plate. Big blue as my builder calls it .
Not sure where that cable I was running came from or the the clevis pin. I went over the job again tonight to make sure my parking lot repair was up to par. Turns out the clevis pin I installed was correct but a poorly produced one and the clip did not stay on. This is the second one I had this issue with and most likely from the same order. I had one I ordered from CIP1 and it was much better quality and clamped onto the cable a lot better. New cable, which was my spare is part #211 731 335E from Pacific. Let's see how long this one lasts.
CIP1 clevis pin, no name 10 miles on it, no name used 7k
and i need to get a good way to have grease stored in the bus for such repairs... |
Small tubes of grease work great for this. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
Posted: Tue Aug 26, 2014 7:15 am Post subject: |
I fubar'd the adjustment cable on my slider door that activates the rear latch. Now my door doesn't open
I attempted taking it apart because the interior lock stopped sliding down all the way into the locked position. It REALLY sucks not having a slider door
I crumbled the brown plastic front door interior handle screw covers...luckily I had an extra set in Tony's Spare Champagne Parts Stash!
Apart from those things, I have been making my bus much more comfy for the road. _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI |
Posted: Tue Aug 26, 2014 7:26 am Post subject: |
secretsubmariner wrote: |
Apart from those things, I have been making my bus much more comfy for the road. |
i know where to get another slider door cable.....
call ken at the busco (206) 523 6525 _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Evilrift Samba Member
Posted: Tue Aug 26, 2014 9:18 am Post subject: |
I smoked my original Sapphire radio this past week. I had completely refurbished and verified it was working.. then fubared by hooking it inline with a bad voltage regulator.
It has probably been over a decade since the bus had that much smoke in it. |
dugfresh Samba Member
Joined: November 04, 2012 Posts: 651 Location: Seattle
Posted: Tue Aug 26, 2014 9:41 am Post subject: |
I bashed into a Yellow Bollard and dented in my passenger side door to match my drivers side door (dent caused by a Friend who in tradition will be unatributed) . Fortunately I managed to pull the card and pop it back out by hand... only small dent to match the rest of the bus now! _________________ 78 Riviera
http://flic.kr/s/aHsjDRJPa1 |
copellos Samba Member
Joined: February 18, 2004 Posts: 937 Location: sonora ca
Posted: Tue Aug 26, 2014 11:17 am Post subject: |
Incinerated my rear inner wheel bearing last week.. |
Posted: Sat Sep 20, 2014 6:33 pm Post subject: |
messed up my car gharging ports...now i have to fiddle with it to get my phone to charge...bugger. gotta relocate the charger and install my temp gauge. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
No Simple Highway Samba Member
Posted: Sat Sep 20, 2014 6:52 pm Post subject: |
#2 spark plug threads in a '77 and too inexperienced to know what to do!!! HelllLLLLuPP! |
77VWBusDude Samba Member
Posted: Sun Sep 21, 2014 5:09 am Post subject: |
No Simple Highway wrote: |
Too late now if you've already cross-threaded it (going to need an insert professionally installed in your head), but next time slide the top of the plug into a 6" (give or take) length of hose and use that to get it threaded in the head before using your socket wrench to tighten it. The hose gives you good feel for what you're doing and holds the plug loosely enough that it won't let you damage the threads (usually). A wobbly also helps get your socket on the plug once you've got it started. _________________ '77 Bus auto EFI(stock)
WendyArmbuster wrote: |
Oh man, I had forgotten the smell of a running bus. Sort of like a combination of old things and burning dust. Smells like... victory. |
Posted: Mon Sep 22, 2014 8:37 pm Post subject: |
well...oops.
time to fix the rust and get those new tail light buckets and lenses i have been needing.... |
206-841-7324
[email protected] |
karlonwheels Samba Member
Joined: February 09, 2014 Posts: 128 Location: new yorkish
Posted: Tue Sep 23, 2014 9:18 pm Post subject: |
PO did a rustoleum paint job on my 73, and even though I KNEW this, i still got too close with the sprayer at the car wash and... washed some paint right off her. Fortunately, I learned that one bright part of rustoleum paint jobs is that touchups are a breeze. _________________ 73 daily bus: "Betty June"
69 Westy Project: "Stella." |
