Modified spare tire clamshell to hold BFG 215/70R15
Sodo
Sodo is offline
PostPosted: Fri Jul 11, 2014 9:52 am    Post subject: Modified spare tire clamshell to hold BFG 215/70R15 Reply with quote
Originally did this in 2007 (an old "Big Brakes thread) I repeated it here to have a more "searchable" subject.
It's been working fine. Gets easier as the tires wear down. It's a Syncro. I don't know if it works on a 2WD. Also, there are tolerances on any vanagon chassis and theres probably no way to pre-confirm if a tire's gonna actually fit in YOUR vanagon. Other than getting the fully mounted tire, on the rim, and testing it. It's that tight.
If you have questions about the spare tire clamshell, I'd prefer to answer them in this thread.
I started out using that large "nut" as a spacer at front then found it wasn't necessary but decided to 'store' it there in case some condition occurred (slightly larger tire? Overinflated?) then if I needed it, it's there.
If there are any questions about the spare tire clamshell I'm happy to help. Probably better to post in this thread because it has a better searchable title.
....KTMs, GasGas, SPOT mtb
coclimber
coclimber is offline
PostPosted: Fri Jul 11, 2014 2:26 pm    Post subject: Reply with quote
Sodo - thanks for this. I thought I'd add in our private discussion on the hinges, so everyone benefits.
Hinge Angle: You mentioned it was 10 degrees (or 170, however you look at it! Smile )
Location of Hinge (above vs. below the clam shell): You mentioned it was better to keep inside so it doesn't get caught on road debris (especially with a syncro). I'd agree. Will do the same!
'83.5 Westfalia Camper - SOLD
'86 Westfalia Weekender
2001 Subaru Legacy 2.5L donor
Rocky Mountain Westy kit
PDXWesty
PDXWesty is offline
PostPosted: Fri Jul 11, 2014 2:46 pm    Post subject: Reply with quote
I had a thought about the location of the hinge being inside that it could rub/wear the tire or rim. Located on the outside might be better if the clamshell is not also being used as a skid plate for a 2wd.
89 Westy 2.1 Auto
coclimber
PostPosted: Fri Jul 11, 2014 2:49 pm    Post subject: Reply with quote
If hinges were attached under the clamshell, on the outside, I wonder if a little bigger angle would be better?
Sodo
Sodo is offline
PostPosted: Fri Jul 11, 2014 2:51 pm    Post subject: Reply with quote
Whenever placing the tire in the clamshell, I have to lever the tire away from the steering shaft before tightening the bolt. It never migrates back to touch the shaft, so I don't think there's any "motion". But agreed wouldn't want the hinge touching on the rim.
furrylittleotter
furrylittleotter is offline
PostPosted: Fri Jul 11, 2014 2:53 pm    Post subject: Reply with quote
Nice mod. Thanks for sharing
Neil2
Last edited by furrylittleotter on Fri Jul 11, 2014 5:00 pm; edited 1 time in total
Sodo
Sodo is offline
PostPosted: Fri Jul 11, 2014 3:01 pm    Post subject: Reply with quote
furrylittleotter wrote:
Sure it could be done different. Hopefully people will actually try different methods and post them rather than try and say what you shoulda/woulda/coulda done. Rolling Eyes
That gets old with a quickness.
I love mods like this. Keep them coming! Cool
Neil2
Hmmmm. A second look from a different point of view, even from a guy who will never do it, can still be a GREAT idea.
A different angle (and spacer at front bolt) would accommodate a wider tire or wider wheel. The wheel in this pic is a 5.5" Audi 5000 wheel. I don't think it's an ideal wheel for a Vanagon, but it was only $25.
If your wheel is wider than 5.5, i think it would be advisable to use a steeper angle (and you may need a spacer at front). Just cram it up in there and weld the hinges to work with the tire you have. And the spacer.
coclimber
PostPosted: Fri Jul 11, 2014 3:12 pm    Post subject: Reply with quote
I'll be putting a 15" x 7" rim in there, so when I figure out the angle & spacer requirements for that mod, I'll report back to here. It will be a week or two, but I will get 'er done!
Sodo
Sodo is offline
PostPosted: Mon Jul 14, 2014 1:18 pm    Post subject: Reply with quote
Here's a pic of my current bolt. My van has the regrettable situation where the front lugs are 19mm bolts and the rear lugs are 17mm nuts. So I set it up so whichever wrench I have will let the spare tire pan down.
Also, if on the road, and for some reason my tire pan can't hold whatever tire I'm putting up there, then I can put the spacer on the other side to spacer it down a little.
If you're cramming a fat wheel up there, pay attention that your fat wheel doesn't pinch off the radiator hose when you crank it up tight.
Try a "tinfoil thickness guage" Ball up some aluminum foil leaving it a little fluffy but able to compress and hold a set. Tape it near your hoses, then crank everything up and see how far is squashes the tinfoil then you'll have an idea what its doing to the hoses. There can be springback in the tinfoil ball, do some testing so you know what it's telling you.
Sodo
Sodo is offline
PostPosted: Tue Jul 07, 2020 9:30 am    Post subject: Re: Modified spare tire clamshell to hold BFG 215/70R15 Reply with quote
Link showing 7x15" Rhein wheels:
Clamshell does fit 215/75R15 BFG AT on 15" Rhein updated
montanasurfer
montanasurfer is offline
PostPosted: Sun Apr 16, 2023 6:14 pm    Post subject: Re: Modified spare tire clamshell to hold BFG 215/70R15 Reply with quote
Question for folks who have done Sodo's clamshell mod. Has anyone done it with a 2WD successfully? Does the syncro subframe provide more clearance?
I have a 1987 2wd and I'm thinking of doing this mod.
1987 Vanagon GL - Wolfsburg Edition
davideric9
davideric9 is offline
PostPosted: Sun Apr 16, 2023 10:03 pm    Post subject: Re: Modified spare tire clamshell to hold BFG 215/70R15 Reply with quote
I may have missed it but I have not seen any mention of the two different clamshells sizes and protective brackets.
ETKA lists clamshell 251-801-901D and then 255-801-901A for tire size: 205
ETKA list left bracket 251-801-913A and then 255-801-913 for tire size: 205
Just thought I'd throw this out there in case your results don't match the work being shown in these threads.
1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012)
Sodo
Sodo is offline
PostPosted: Mon Apr 17, 2023 10:19 am    Post subject: Re: Modified spare tire clamshell to hold BFG 215/70R15 Reply with quote
Good call davideric9 the smaller tab on the 2WD clamshell can be seen in your ETKA pic (near bolt#5).
Going up this page couple replies is a pic of the 'long tab' of a Syncro that had the VW Alloy 14" wheels (205?).
Heres a 'smaller' 2WD clamshell with the front tab extended for wider tires.
The pic is kinda "upside down' where the extension allows the clamshell to drop down farther.
