0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Tue Jul 15, 2014 10:02 am Post subject: decision... decision... please help |
hi all,
could you please pitch in your though...
WBX 2.1 - 125K miles needs to be rebuilt
- cylinder walls good condition, still have score marks
- good pistons
- bad rings, to be replaced
- bad heads, to be replaced...
- no prior signs of bad bottom end
now the question - doing top end only or a full rebuild? (cost wise, full rebuild is double of top end only)
many thanks in advance... |
whynotvw Samba Member
Posted: Tue Jul 15, 2014 10:37 am Post subject: |
go all the way, or do a engine conversion |
rubbachicken Samba Member
Posted: Tue Jul 15, 2014 10:40 am Post subject: |
who's doing the work dan ?
if you are doing it, i'd maybe go the whole hog.
if you are paying for it to be done, and you know the bottom end is good, only replace what's needed _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
Posted: Tue Jul 15, 2014 10:47 am Post subject: |
thanks for the reply
if I could afford I'd go full rebuild for this engine which will go in my 1990 Carat..I love conversion but it's way over my budget... and...
there's also my Syncro... which the engine will need a rebuild soon too... how soon I don't know... but I can see the dark clouds on the horizon..
the work will be done by a local mechanic....
geodude Samba Member
Posted: Tue Jul 15, 2014 10:50 am Post subject: |
If you have pulled it out and are going to pull the pistons out to do the rings I'd go all the way on the rebuild. You are doing most of the work, so why not know that everything is in great shape. The way I look at it you can spend $1,000 extra now and have a reliable completely rebuilt engine for the next 10+ years or risk having to pay $3,000-$4,000 again in a couple years. _________________ 1988 GL Camper
1991 Multivan — the basket case |
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Tue Jul 15, 2014 11:00 am Post subject: engine |
geodude wrote: |
If you have pulled it out and are going to pull the pistons out to do the rings I'd go all the way on the rebuild. You are doing most of the work, so why not know that everything is in great shape. The way I look at it you can spend $1,000 extra now and have a reliable completely rebuilt engine for the next 10+ years or risk having to pay $3,000-$4,000 again in a couple years. |
X-2 If you are going to keep it more then 6 mo. Do it all! _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
atomatom Samba Member
Joined: May 15, 2012 Posts: 1867 Location: in an 84 Westy or Bowen Island, BC
Posted: Tue Jul 15, 2014 11:14 am Post subject: |
you could get the mechanic to measure the endplay - you can make your bottom end rebuild decision based on that. if sloppy and leaking oil, out the main seal you might want to invest a bit more.
if you don't split the case, you might consider at least getting new rod bearings and reconditioned rods: http://www.van-cafe.com/home/van/page_679_269/connecting-rods-set-of-4-see-description.html _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Tue Jul 15, 2014 11:16 am Post subject: |
A compromise would be to remove the connecting rods, have the bolts replaced and have them resized at the local machine shop. This way you aren't into the case, but don't have to worry about a rod coming off once you put some load on it with the top end overhaul. _________________ ☮️ |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6246 Location: Portland OR
Posted: Tue Jul 15, 2014 11:21 am Post subject: |
If it's not a daily driver, do the top end only. You may get 5-10 years down the road before you have any problems with the bottom.
I drive my van about 5000 mi/yr, so a 50,000 mile repair lasts a long time. _________________ 89 Westy 2.1 Auto |
Posted: Tue Jul 15, 2014 1:27 pm Post subject: |
PDXWesty...
no... it won't be a daily driver... it will be a recreational van for camping when time permits... 5K miles a year max, not even that...
atomatom ...
thanks for suggestion of the end play checking...
rsxsr ...
I will talk to the mechanic about the connecting rods bolts
no matter the decision, I will put in an external oil cooler with fan... |
sea_sick Samba Member
Joined: July 21, 2012 Posts: 113 Location: West Coast
Posted: Tue Jul 15, 2014 1:42 pm Post subject: |
PDXWesty wrote: |
I drive my van about 5000 mi/yr, so a 50,000 mile repair lasts a long time. |
FWIW, I'm on board with this line of thinking if on a budget. |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Tue Jul 15, 2014 7:39 pm Post subject: |
Find someones used engine from doing a conversion. It seems alot of vans get more than 125k from the stock engine. Call some conversion shops see if you can find one with less than 100k on it. Most people who do a conversion dont want much for their engine. I gave mine away and it seemed to run well. At that point someone doing a conversion has spent alot of money and youd think they would be trying to recoupe as much as possible. But I think if they were like me they were just happy to see it gone. |
Posted: Tue Jul 15, 2014 7:40 pm Post subject: |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Tue Jul 15, 2014 7:56 pm Post subject: |
I was told once by a very credible VW shop that the bottom ends are good for double the top end. I didn't listen and got a fully rebuilt engine. It was a lot more expensive and the idea that I was somehow saving myself trouble was not the case and I wish I had listened.
My vote is for top end. Disclaimer, I am not a mechanic, just a customer most of the time. But people here will usually go overboard in my experience. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6832 Location: Fort Lauderdale, Fl.
Posted: Tue Jul 15, 2014 10:23 pm Post subject: |
look into changing the camshaft for more power if your going to split the case. |
Posted: Tue Jul 15, 2014 10:47 pm Post subject: |
rsxsr wrote: |
A compromise would be to remove the connecting rods, have the bolts replaced and have them resized at the local machine shop. This way you aren't into the case, but don't have to worry about a rod coming off once you put some load on it with the top end overhaul. |
2x, I would strongly recommend dealing with the rod bolt problem. This is a notorious problem that happens to most 2.1 WBXer engine in the 140-180K mileage range, and will waste out any money you spend without addressing it and wreck your core. Heads can often be handled by filling the corrosion pits with JB Weld. It is possible to get by for only a few hundred dollars if you are doing the work. YMMV |
Posted: Tue Jul 15, 2014 10:50 pm Post subject: |
rsxsr wrote: |
2x, I would strongly recommend dealing with the rod bolt problem. This is a notorious problem that happens to most 2.1 WBXer engine in the 140-180K mileage range, and will waste out any money you spend without addressing it and wreck your core on top of everything else. Heads can often be handled by filling the corrosion pits with JB Weld. It is possible to get by for only a few hundred dollars if you are doing the work. YMMV |
boroko Samba Member
Joined: September 11, 2012 Posts: 326 Location: S.W. Michigan
Posted: Tue Jul 15, 2014 10:55 pm Post subject: |
i had a 2.1 go 250k without a bottom end rebuild. Then again, when it did go, it was a rod bolt.
2nd on the JB weld for head pits in the coolant area. Works great.
Mark _________________ '87 SyncroWesty: Smokey the Turtle, '85 SubiWesty: Chappie, '84 GTI, '86 GTI in full Rally trim,
previous: 2 Syncro tin tops, 2 Vanagons, 3 busses, 3 Ghias, 2 Jettas, a 411, a gas and a diesel Bunny and about 25 Beetles, one that only drove left. |
