whyismyvwbroken Samba Member
Posted: Thu Aug 14, 2014 8:57 pm Post subject: Turboing |
I've watched so many videos, and googled everything under the sun to find out how to turbo. I need a list as to what I need to turbo. I know how to run the exhaust and everything, but I don't know how to run oil to the turbo, or what carb to use. I just need a list on what I need. If you can help, I will be so grateful. |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Fri Aug 15, 2014 3:55 am Post subject: |
The exhaust needs to be routed to feed into the turbo, oil can be tapped off from the pressure side of the pump, carb can be before the turbo, after if turbo-prepped, or for the best and safest, go EFI (though it is also the most expensive.)
Every turbo install seems to be unique, unless you buy a kit, so I'd suggest doing a few searches here and looking at how others did it for the "everything." Seriously, though, if you know that little you should start with a HiPo N/A engine and work your way up. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5300 Location: Atlanta,Michigan
Posted: Fri Aug 15, 2014 4:30 am Post subject: |
Just install a T at the oil pressure to feed the Turbo,If u tap into the pump outlet u can kill 'Skeeters' outlet on the bottom of turbo needs to be at la good size I think mine is 1/2",good reads are Turbomaina and Turbochargers by Hugh MacInnes,, more turbo guys are over on www.shoptalkforums.com ,Weber sidedraft DCOE or a dell carb work well for 'draw threw',,Madmike _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Fri Aug 15, 2014 4:31 am Post subject: |
Just install a T at the oil pressure switch location to feed the Turbo,If u tap into the pump outlet u can kill 'Skeeters' outlet on the bottom of turbo needs to be at la good size I think mine is 1/2",good reads are Turbomaina and Turbochargers by Hugh MacInnes,, more turbo guys are over on www.shoptalkforums.com ,Weber sidedraft DCOE or a dell carb work well for 'draw threw',,Madmike _________________ 'Black Ice'Drag Buggy 'Turbo'
jcmyers Samba Member
Joined: March 09, 2012 Posts: 184 Location: United States
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Fri Aug 15, 2014 9:49 am Post subject: Re: Turboing |
whyismyvwbroken wrote: |
I need a list as to what I need to turbo. |
You need to know how to tune a turbo engine before you go slapping parts on it, so the logical follow up question is what is your level of tuning ability and do you have the right tools at your disposal? If the answer to those questions is 'very little' and 'none', I'd advise you seek out some knowledge before you make your screen name a reality. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Posted: Fri Aug 15, 2014 10:13 am Post subject: |
ha! didn't even notice that! it's true, my setup takes a lot more time and cussing than my wife's non-turbo dual carb 1776 |
mightymouse Samba Member
Posted: Sat Aug 16, 2014 8:23 pm Post subject: |
Yup. Mini is right. This isnt a simple endeavor.
Also need to have an oil restrictor at the turbo. Cant just pump 30+ psi and corresponding volume full tilt into it.
You ask the manufacturer of the turbo what restrictor jet size they recommend.
They will tell you and thats what you buy. Keeps your turbo alive and happy and doesnt blow the seals out the first day.
Email aj at lowbugget and get a few outlines from him.
You can get a kit with a standard t3/t4 and a draw through 2 barrel and make very nice power.
Local guy to me has a home made kit with a T3 off a nissan 300zx. One of AJs draw thru 2 barrels.
I tuned it for him, 7 psi and 20 degrees timing his 1679 made 130 WHP.
runs like a top and we havent even turned it up yet.
HAVE to have a wideband so you can see the AFR at all times.
Mappable ignition is very good to have too if you plan to daily drive it. Having fixed timing SUCKS. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
Posted: Sun Aug 17, 2014 6:51 am Post subject: |
mightymouse wrote: |
Also need to have an oil restrictor at the turbo. Cant just pump 30+ psi and corresponding volume full tilt into it. You ask the manufacturer of the turbo what restrictor jet size they recommend. They will tell you and thats what you buy. Keeps your turbo alive and happy and doesnt blow the seals out the first day. |
Correction: a restrictor is typically only REQUIRED on ball bearing turbochargers. I have never needed one on the journal bearing turbos and I've never had a problem with them, but you do have to make sure the drain is perfectly clear and drains above oil level in either case. The people that seem to have the most trouble are the ones draining to a deep sump below oil level like with the CB sedan header. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4130 Location: NW Washington
Posted: Sun Aug 17, 2014 8:21 am Post subject: |
A -3 feed line without a resrictor will usually work out for most turbos.
A large, straight drain is probably the most important. My Subaru IHI turbo has a 5/8ths or metric equivalent size drain. _________________
richardcraineum wrote: |
I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah .. |
cbeck wrote: |
His user name in a previous life was dick head. |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Mon Aug 18, 2014 6:32 pm Post subject: |
I'm never dissatisfied with posting to these forums. I have every tool you can think of using (family owns body shop/dad is very extensive with his tool collection). You guys basically just told me everything I need to know. Thank you! Any of you know what kind of HP a stock 1600 DP would put down? |
Posted: Mon Aug 18, 2014 7:28 pm Post subject: |
My 1679 with 16 lbs boost and a 2.24 second 60 ft. did 99.2 mph in the quarter. It was spinning heavily in first and short shifted into second at 4800 rpm.
I'm sure it has more in it since I'm at 17 lbs now......
With a better 60 ft. and more boost it could see low to mid 13's fairly soon.
Here is my Iphone Dynoliscious run from last fall.
Acceleration
0-10 MPH: 1.43 sec
0-20 MPH: 2.20 sec
0-30 MPH: 3.20 sec
0-40 MPH: 4.09 sec
0-50 MPH: 5.35 sec
0-60 MPH: 6.72 sec
0-70 MPH: 8.11 sec
0-80 MPH: 10.07 sec
0-90 MPH: 12.68 sec
Elapsed Time
60': 2.24 sec @ 27.4 MPH
330': 6.07 sec @ 59.8 MPH
1/8 mi: 9.17 sec @ 78.4 MPH
1000': 11.88 sec @ 90.1 MPH
1/4 mi: 14.17 sec @ 99.2 MPH _________________
cbeck wrote: |
Audi TT intercooler
EcuMaster PMU16
Posted: Wed Aug 20, 2014 8:14 am Post subject: |
Dang. That's nice. Pretty quick little car. |
