PAPI Samba Member
Joined: February 25, 2014 Posts: 43 Location: United States
Posted: Sun Jul 20, 2014 2:27 pm Post subject: Fog and driving light laws |
Just picked up some Hella 500 driving lights, and noticed that they are tapped into the high beam lead, which means they will only come on with the high beams. Is this to comply with some motor vehicle law? Is it really a big deal if I pull my switch voltage from somewhere independent of the head lights? |
hans j Samba Member
Joined: May 06, 2006 Posts: 2714 Location: Salt Lake City UT
Posted: Sun Jul 20, 2014 2:35 pm Post subject: |
Just run them independent so you can choose when they are on. I doubt anyone will hassle you about it.
They are actually only "supposed" to be run on low/dipped beam and turn off when high beam is selected.At least that is how it is on the modern VW/Audi cars I see. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Sun Jul 20, 2014 2:44 pm Post subject: |
I would wire independently and use when I need it...
just use your common sense and don't burn the retina of the ones in front of you or the ones in the opposite lane... |
goffoz Samba Member
Posted: Sun Jul 20, 2014 2:48 pm Post subject: Re: Fog and driving light laws |
PAPI wrote: |
AFAIK the "driving lights" should go out on low beam, on with high beam.
"fog lights" are on always when selected.
That being said, I have my "driving lights" down low, (like fogs) and have them switched...my choice for when I use them.
hella 500s are nice |
vanonimous Samba Member
Joined: October 19, 2013 Posts: 362 Location: Burien, Center of the Universe
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Sun Jul 20, 2014 6:03 pm Post subject: |
Lighting laws do vary by state, but in general driving lights are meant to be switched on with the high beams only due to the long, narrow shape of the beam. If your state has strict safety inspection laws, improperly switched lights could be a reason for failed inspection.
In most places, a properly aimed set of auxiliary lights that can be switched on and off independently of the headlights is the best way to go since it will provide an alternative source of lighting if your headlights fail.
Good aiming instructions for auxiliary lighting can be found here: http://www.danielsternlighting.com/tech/aim/aim.html _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
PAPI Samba Member
Posted: Mon Jul 21, 2014 7:19 am Post subject: |
Thanks- I may go with the independent set-up. Any suggestions for a good switched relay voltage source? |
Posted: Mon Jul 21, 2014 7:37 am Post subject: |
I would use a stock Vanagon fog light switch, or the back-lit Porsche 944 fog light switch (both fit identically).
Let me know what year your van is and I will suggest some possible hookup options. You will have to add your own relay.
If you would rather buy a ready made wiring harness solution with a fuse, relay and switch, I can set something up for you. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Mon Jul 21, 2014 11:00 am Post subject: |
As others have posted, the Hella 500's can be connected independently of the Headlights. I have mine switched using a Porche 944 Unit. In addition, I wired in a relay to have them follow the ignition switch, and use them as Daytime Running Lights. The ignition switch relay ensures I don't leave them on accidentally when exiting the vehicle.
FWIW, I've been running the Hella 500's night and day for several years here in SoCal without attracting the attention of the Police, or getting high-beamed by opposing traffic. I do have them mounted low and adjusted low. _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
PAPI Samba Member
Posted: Mon Jul 21, 2014 11:57 am Post subject: |
The 500's came with a relay. The unit draws signal voltage from the high beam wire and runs through a panel mount switch. If I replace the leg from the high beams off the switch, does the new source have to be relayed?
BTW- I thought Hella's instructions were just awful. |
