Jahbah Samba Member
Joined: July 27, 2011 Posts: 299 Location: McMenaminville, Oregon
Posted: Sun Jul 20, 2014 10:10 pm Post subject: High beam/ low beam switch failure. Rebuild? |
I am in the process of installing jetta cruise control in my '87 Syncro weekender. After installing the jetta turn signal/ cruise control selector I noticed that my high beam were on. I couldn't then select low beams pulling the selector, nothing was happening. I reinstalled the factory turn signal stock to find that wouldn't work either. Upon investigation I figured out the high beam switch was not clicking back and forth. I popped it open to see if there was anything obviously wrong. I can manually shift the selector to high/low beam, but it won't work when the switch is all back together. I cleaned and lubed all parts with dielectric grease. Any tips or tricks to putting this switch back together? I don't want to toss it and hunt for a new switch.
The white plastic fork in the picture above rides on the switch in the picture bellow. The black post in the middle of the switch is the pivot point and holds the fork in place. The fork has a tab on the bottom of it that pushes the switch to high and low beam.
Really cool little switch, I'd love to put it back together and make it work! Any advise on fixing it... Or toss it and find a new one?
Cheers
Dustin _________________ '87 Westfalia Weekender + '86 Syncro Tintop +'02 Impreza 2.5RS
= '86.5 SuperWestySyncroSubyWeekendermobileagon =
Bueno.
Jahbah~D |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 8894 Location: Orbiting San Diego
Posted: Sun Jul 20, 2014 10:46 pm Post subject: |
A problem I have seen is that the external tab from the lever is out of position and then lifting the lever does not move the switch enough for it to switch modes.
Mark |
Jahbah Samba Member
Posted: Mon Jul 21, 2014 1:09 pm Post subject: |
Thanks Mark,
I have the whole switch disassembled. When it's back together I can pull the switch lever all the way out, and I checked the alignment it's okay. Pulling the switch lever all the way out still doesn't yield the click of the switch. Bummer. _________________ '87 Westfalia Weekender + '86 Syncro Tintop +'02 Impreza 2.5RS
Bueno.
Jahbah~D |
apchief Samba Member
Posted: Sat Jan 17, 2015 1:19 pm Post subject: |
I just worked on this today and realized what my issue was b/c I couldn't get it to work. The ends of the metal piece that goes under the white switch have to be inserted into 3 notches. So when you're putting it in the case go at it in an angle, get it in those 3 notches and it should work. |
tjet  Samba Member
Posted: Sat Jan 17, 2015 1:37 pm Post subject: |
Might be a good time to install a headlight relay kit too _________________ super rusty lifted '87 syncro tintop |
