risk Samba Member
Joined: June 24, 2004 Posts: 710 Location: Stumpbroke, Arkansas
Posted: Mon Jul 21, 2014 8:25 am Post subject: Empi / CB Perf Oddball Disc Brake Pads |
I'm looking for a better pad for my CB front disc brake kit, preferably ceramic.. The pads that came with the kit puts off a lot of dust.
This type of pad is used in both the Empi and CB Performance front disc kits. It is not a ghia pad like some other kits.. it is an oddball.
I spoke with CB Perf. and they say the pad is for a mid 1990's Brazilian Fiat.. but couldn't say for sure what model or a good part #.
I have searched the forums and found nothing, also searched rockauto and found some similar pads but nothing exactly the same.
Here are some pics:
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Mon Jul 21, 2014 10:22 am Post subject: |
You may have some luck here figuring out what you have. Once you can identify it, then you can go to Hawk, or other brake manufacturers and purchase a harder compound pad then what you have now.
Most manufacturers use a very soft pad for street use simply because they usually don't make noise (squeak) and they are easy on the rotors. The down side is they put a lot of brake dust on the wheels.
Going to a harder compound brake pad should reduce the amount of brake dust you get on the wheels, BUT you may find other problems that are more annoying.
Rotors may wear faster, the brakes will make more noise, or they may deposit other things on the wheels.
Some metallic pads have a tendency to leave metal particles on the wheels that will then rust. When that rusting begins it can actually pit alloy wheels. And this can happen very quickly - like over night or even in a few hours if conditions are right for it. So even the most meticulous person who keeps everything spotless and clean may find their wheels pitting.
And just to educate you a little, racing brake pads DO NOT work well on a street car! So this is one area where you want to stay away from the racing parts. Racing pads are designed to work at much more elevated temperatures then you will ever get on the street. As such, the car won't stop too well when the pads are not up to temperature. _________________ Mother Nature is a Mean Evil Bitch! |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1214 Location: Eerie PA
Posted: Mon Jul 21, 2014 10:29 am Post subject: |
If you have a CARQUEST in your area try them, believe it not I had some issues finding 944 brake pads and had to return two sets either due to quality control issues or just plain wrong pads. I went to CARQUEST and they got them from their foreign parts line and they fit great, ceramic and a hell of a lot cheaper than Hawks. If I was racing the car than Hawks would be my choice but since its a street car that wont see the extreme braking requirements of the track I felt OEM quality was more than sufficient.
Another source for brake parts other than the auction website is Amazon for odd ball stuff, they sell Hawks brake pads on there. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 11 Window (Zelda)
1965 13 Window (Lucas)
1957 Oval ragtop
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk |
fluxcap Samba Member
Joined: February 07, 2006 Posts: 1969 Location: Newnan GA
Posted: Mon Jul 21, 2014 10:44 am Post subject: |
the shape/design looks very similar to those listed on ebay for a fiat tempra. except these have some type of sensor hooked to one of the pads.
http://www.ebay.com/itm/FIAT-TEMPRA-TIPO-Models-NO...3ce379025d
http://www.ebay.com/itm/Pagid-Front-Brake-Pad-Set-...4602d926f6
Let us know what you find out. I also have cb disc and just planned to buy new ones from CB when needed, but would still be interested to know if there is something comparable at the local parts store. _________________ Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black." |
