mcdonaldneal Samba Member
Joined: June 13, 2013 Posts: 2648 Location: Gullane, Scotland
Posted: Tue May 30, 2017 2:03 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Our predictions about finding a campsite were correct. With the weather getting hotter and hotter, temps into the 90'sF, and tempers getting shorter, the first campsite said they were full, the village up the coast was full and the village down the coast was full...
Ok. Let's abandon the coastal plan.
We headed inland and found a small town, Schagen. The site there juggled a few things around and found us a space! We then made the mistake of walking into town. It was ancient and beautiful with plenty of bars and cafes, a tuneful chiming clock tower that sounded every 15 minutes, and a supermarket where we could buy dinner to cook in the Kombi. The mistake was that it was easily a two mile walk in, and by the time we got back to the bus we were shattered! Even the cat was too bad tempered to cooperate with a selfie!
The next morning we were determined to reach the sea, so we saddled up and cycled the 20mile round trip to the beach. We started at 8am, as it was shaping up to be a scorcher! Notable sights for the yellow bus T-shirt were the fields of flowers and two battered Bay panel vans and a beetle at an ACVW restoration shop! I couldn't work out why the water was too dangerous to swim in, but the North Sea is notoriously cold, so we didn't!
We travelled the short distance down the North Holland coast but it was really getting unpleasantly hot, despite all windows open and the 'accessory' fan on full blast all day. Any car parks were too exposed to the sun to be able to leave the poor cat, so we found a shady tree between the bike path and the road to have a cool lunch.
_________________ 1978 marino yellow Bay Dormobile camper
1969 signal orange Karmann Ghia convertible
1976 martini olive Bay Dormobile camper
Stop dead photo links! Post photos to The Samba Gallery! |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Tue May 30, 2017 5:37 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Dang, what a good looking bunch of cars. Your trip looks like fun. Enjoy it! _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Joined: August 31, 2013 Posts: 12848 Location: North Carolina
Posted: Tue May 30, 2017 8:07 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Lot of great memories there, keep the pics coming. Thanks! _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue May 30, 2017 10:30 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
I found this video clip from the canal lock gates at Workum in the central Netherlands.
After we arrived back on British soil, and remembered to start driving on the left again, we came up the Northumberland coastal route I had taken a couple of weeks ago. The oil temp was behaving very well in the cooler British conditions but then, on the main road back towards Edinburgh the temp light (225 F) came on if we drove above about 50mph. Clearly that is no good at all, so I am going to record a standardised set of temperature and pressure readings, from cold, with the current setup and then get hold of some Valvoline VR1 20W50, which seems to be a popular choice on the 3245 page oil selection thread and compare the readings. (I'm going with that heavier weight because of the low oil pressure on startup and at hot idle, and because if the engine temps do get hot, that oil will handle it a bit better than a lighter weight.
Well, that's the end of this travelling adventure. We had a blast, and I hope you enjoyed following along with us! More to come as soon as we are able!...
dasdachshund Samba Member
Joined: March 29, 2010 Posts: 728 Location: Vancouver, WA USA
Posted: Tue May 30, 2017 12:25 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Your "Scottish tan" legs are freaking me out in some pics.....
Take care my friend and glad you had a good time. All the best to Shona, too. 90F over here in Vancouver over the weekend.
Of all the pics this one is my fav.
-dasdachshund |
Posted: Wed May 31, 2017 12:28 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
I want to be able to make a comparison to see what effects changing the oil weight has.
I have devised a test route that takes about an hour to drive, a mixture of hills and quiet dual carriageway, where I can get up to and maintain a good speed (70mph) and stop at defined points to check the temperature.
I realise that there are real limitations in the accuracy of (20 year old) dash gauges and of IR temp measuring guns, but this is what I have:
VDO oil pressure gauge, marked at 20, 40 and 60 psi
VDO oil temp gauge, marked at 50, 100, 125 and 150deg C. The sensor is drilled into the oil pressure relief plug, which seems to be (according to Samba search!) one of the better and 'hottest' test locations, although with a bit of a time lag. I can't know if the scale is linear, but I'm assuming that the mid point between 100 and 125 is 112.5deg C.
Infra-red temp gun. I am taking readings from the black painted bottom of the oil filter, at right angles to the surface, averaging over five or so readings. On my test runs, this IR reading is within a few degrees of the dash gauge.
The temp sensor location does mean that I haven't checked the length and condition of the oil pressure relief spring, but I should do that sometime. The engine was 'rebuilt' and checked a couple of years ago, but I can't assume that was checked then.
For info, the engine is a 2.0 litre, dual carb, type 4, in a relatively heavy camper conversion with steel 'roo bars. Valves, timing, choke adjustment and air/fuel mixture are all OK.
I'll post the results of last night's test run next.
Posted: Wed May 31, 2017 1:00 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
OK, the numbers from last night (outside temp was about 16deg C, 60F).
The video shows the delay in the oil warning light going out and the pressure gauge coming up to pressure (cold start, no throttle).
The current oil is quite fresh, but a mixture of weights. I plan to replace with Valvoline VR1 20W50 but I also have 10W30 and 15W40 with ZDDP if the Valvoline is no good.
Cold start:
Time to oil light off, 5sec
Time to stable oil pressure, 12sec
Idle pressure, 35psi
Oil pressure under power with engine cold, 58psi (approx)
Gentle driving until temp coming up, then quite hard driving. Hills and 70mph on dual carriageway. Bus has Automatic transmission.
Time to reach 100degC (212F) on gauge, about 18 min
First stop point:
Oil press at 70mph, 38psi
Temp gauge, 105C (221F)
Oil filter temp 102C (215F)
Idle pressure, 12psi approx
Second stop:
Oil pressure uphill at 55mph, 35psi
Temp gauge, 110C (230F) *Save my bus warning light flickering
Oil filter temp, 112.5C (235F)
Idle pressure, 8psi approx
Third stop:
Oil pressure uphill at 55mph, 30psi
Temp gauge, 115C (240F) *save my bus flickering more strongly
Idle pressure, 7psi approx
So, at least I've got some numbers to make a comparison! Oil is draining out now, I plan to check the pressure relief spring and fill with fresh oil when it arrives in the post!
Any comments at this stage are welcome, I don't have any particular new thoughts after that test run. _________________ 1978 marino yellow Bay Dormobile camper
Abscate Samba Member
Joined: October 05, 2014 Posts: 22641 Location: NYC/Upstate/ROW
Posted: Wed May 31, 2017 2:22 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
That's a nice sculptured car in the ferry, and that E-type is nice too...
_________________ .ssS! |
Posted: Wed May 31, 2017 6:36 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Did the issue with the oil pressure start after you changed to your Frankenstein oil? And can you remind me of what weight (on average) your oil is currently? _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
richparker Samba Member
Joined: November 24, 2011 Posts: 6980 Location: Durango, CO
Posted: Thu Jun 01, 2017 1:30 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Spike0180 wrote: |
Did the issue with the oil pressure start after you changed to your Frankenstein oil? And can you remind me of what weight (on average) your oil is currently? |
I had a look back to remind myself and the oil I have in is about half 20W50, half 15W40, with about a pint of 0W30.
The only way the oil pressure is behaving differently from usual is that it is taking longer to come to pressure from a cold start. The main issue (if it is an issue!) is the high engine temperature on the motorway.
If there is an equation: engine heat generated vs engine heat removed by cooling system, I don't see any reason for generating way too much heat with the current setup, but the oil/ oil cooler/ airflow system seems not to be working properly.
My suspicion is that the oil pressure relief spring could be too weak or too short through age, and so the oil cooler is not getting enough flow to give maximum cooling. I hope to check it today. _________________ 1978 marino yellow Bay Dormobile camper
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Thu Jun 01, 2017 6:21 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
mcdonaldneal wrote: |
I assumed (!) that the thermostat has blown, and on my way to work, I stuck my phone under the car to take a pic of the thermostat.
Pop quiz: what is wrong with these photos?
Bonus point: what should I do about it? |
It appears like the threaded rod holding the cable has loosed. And it has caused the thermostat to be trapped open by clamping itself to the bracket.
Moving and tightening the rod will be a whole lot easier and cheaper than replacing the thermostat. And Locktite the rod so it doesn't repeat.
But that doesn't answer the high heat problem. Hmmm... _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
wcfvw69 Samba Purist
Posted: Thu Jun 01, 2017 8:02 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Phil,
If I was you I'd do this with the oil temp issue-
Drop down to 10-30 and see what that does. I lowered my oil from 10-40 to 10-30 and saw an 8-10 degree lower oil temps. My engine is fairly new so it has tight bearing clearances and excellent oil pressure. The thick oil can keep the relief valve from letting the oil get to the cooler faster. That was the case for me.
I personally would NEVER run a 10-50 weight in any VW. Way too thick in my opinion.
Next, I would insure your cooling air is getting to all parts of your engine. Type 4 engines are not my specialty but.. I'd make sure there's no obstructions and your thermostat system is working and allowing FULL air flow over the cooler and to the heads/cylinders. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Thu Jun 01, 2017 2:01 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
KentPS wrote: |
But that doesn't answer the high heat problem. Hmmm... |
Top marks Kent!
Actually, the hex rod doesn't screw right down onto the thermostat, leaving the gap. When I jiggled the thermostat it snapped back into place.
I cleaned up the threads but it won't go all the way down, and it's a non metric thread so I don't have the tap and die. This thermostat is from Awesomepowdercoat.
I decided to add a washer between the hex rod and the stat, which seems to close the gap and prevent the problem happening again. I'll add loctite too, thanks for the tip!
Posted: Thu Jun 01, 2017 2:19 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
wcfvw69 wrote: |
Phil,
Next, I would insure your cooling air is getting to all parts of your engine. Type 4 engines are not my specialty but.. I'd make sure there's no obstructions and your thermostat system is working and allowing FULL air flow over the cooler and to the heads/cylinders. |
Thanks Bill, good advice.
I've been thinking the whole thing around in circles and, at the end of the day, I just need to try a new oil weight and see what it does.
I will double check the cooling air flow passages, although I've seen most of them over the winter. I have also ordered a new pressure relief spring (standard, not heavy duty) as mine is actually at the low end of spec, and I don't want the risk of some oil flow being diverted away from the cooler at motorway speeds and pressures. I'll check its compression specs before use.
I was nervous about using a low weight oil like 10-30 because of my slow pressure build up on start-up, and the fact that my oil pressure is only just 10psi/1000rpm at the moment, but I have some high zinc 10-30 so I might just give that a go, and I can always change again if it doesn't work well. It won't necessarily make things worse!
(My other mental argument for using 20-50 was that, if the temperature is going to run on the high side, the VR1 oil withstands high temperatures without breaking down as much, but that is a bit of a defeatist argument!)
Cheers. _________________ 1978 marino yellow Bay Dormobile camper
Posted: Fri Jun 02, 2017 4:52 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
They make a vr1 10w-30. That is what I'm using. It's a racing oil too, so should hold up to heat well. Though it is a bit hard to find at times, it's hopefully worth the hunt (Ive only got 43 miles on my new engine, so it hardly proves anything lol). _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Fri Jun 02, 2017 2:31 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Thanks Spike, I have some 10W30 with ZDDP and I am probably going to try that first.
I had ordered a new standard oil pressure relief spring which arrived today. You can see it is slightly longer (top) than the old one and the tension at the spec of 39mm is 8.2kg which is nearer the high end of 6.8-8.8kg, so I will use that. It should reduce any potential to divert oil from the cooler.
My plunger piston was clean, but had a bit of a wear pattern on the top surface which shows up in the photo. I don't have a replacement, so I have gently polished it with 2500 grit emery and oil to make sure it is smooth.
Also, I can't find a torque value for the pressure relief plug, just the Bentley caution 'do not overtighten the plug'! I wouldn't worry but as I have a temp sensor integrated into it I'll have to use that nut to tighten. Hopefully I can crush the washer without stripping the sensor out of the plug!
