busdaddy Samba Member
Joined: February 12, 2004 Posts: 51121 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jul 23, 2021 4:29 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
No doubt you've studied vapour barrier threads and know of the added flap on it?
I'd be vacuuming out those doors and blowing some rust preventative wax in there before the lid goes back on, make sure the drains are clear as well (little bumps in the inner skin hidden under the seals that form a gap between the skins).
Keep it up with the adventure pics, you visit some fantastic places and it's cool to see them from a bus drivers perspective. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
mcdonaldneal Samba Member
Joined: June 13, 2013 Posts: 2648 Location: Gullane, Scotland
Posted: Sat Jul 24, 2021 7:08 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Thanks Busdaddy. Yes, any new job on the Kombi involves endless reading around in the Bentley and on TheSamba until I summon up the courage to dive in!
I removed the passenger side door panel today (our left) and was surprised to find a mostly intact vapor barrier, peeled away at the top rear, badly repaired at the bottom front and with much extraneous plastic and sellotape! It’s clear I can’t use it but I’ll inspect how it is attached in detail and work out what clips and grommets need replacement. The bottom part of the panel is kind of damaged but I can’t see yet if it is water damage, glue, foam or what. The bottom clips are rusted though but I’m sure the panel is very salvageable.
_________________ 1978 marino yellow Bay Dormobile camper
1969 signal orange Karmann Ghia convertible
1976 martini olive Bay Dormobile camper
Stop dead photo links! Post photos to The Samba Gallery! |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Sat Jul 24, 2021 8:42 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Colin has a great post for making new vapor barriers...
https://itinerant-air-cooled.com/viewtopic.php?f=49&t=9122 _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Posted: Sat Jul 24, 2021 3:15 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Thanks KentABQ, I am closely following Colin’s guidance!
Although my passenger vapor barrier was damaged and displaced I was able to see how it was originally installed:
The plastic nearest the card comes down as far as the edge of the flow through vent and is stuck/trapped there. That top piece actually goes straight across at one level and a second piece is added on at the lowest part of the door, and taped/stuck to the main plastic piece.
The ‘flap’ is at the level of the cut-out in the door metalwork and although it is stuck to the main piece for exactly the width of the cut-out it does extend a little at either end, kind of inside the door.
The door pull and the window winder are effectively punched through the plastic sheet.
By mounting the plastic on the removed card panel and lining up the grommet holes I get a better idea of the whole orientation.
Posted: Sat Jul 24, 2021 4:46 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Blah!, that was dirty!
No doubt you've read up about both potential missing or broken springs, if your door doesn't unlock itself when closed with the lock button down (and not squeezing the outer handle while closing) the spring is gone. Another indicator is a very hard to turn key when unlocking. Later doors don't have that rear window track, yours is normal.
I've repaired door cards like that with polyester resin and fiberglass cloth in the past, we'll see how the glue does long term. With an intact vapour barrier and inner flap that diverts window leakage back into the door it should last a long time. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Jul 25, 2021 3:25 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Thanks Busdaddy. The two usual springs are intact but I managed to bend another spring! The one built into the door handle that lets the trigger spring back is awkward to replace without getting it off line. Eventually sorted it so it works smoothly though!
One rewarding task today was cleaning the old adhesive, foam and dust from the door skin nearest the cabin, lovely.
The inside of the door though is a mixture of dried debris, grease, cavity wax and some surface rust. My guess is that the door has failed to drain at some stages of its life and was predominantly facing uphill, as all the rustiness is at the rear, near the flow through vent. You can see it in the pics. It is a pretty horrible area to rub down the rust, although I have attacked it with small pieces of sandpaper to some effect.
My plan is to degrease, rust convert and then use Eastwood rust encapsulator aerosol, primer and colour and eventually cavity wax or fluid film.
I will remove the grommet at the lower part of the inside door, as I would rather any water can drain out, and I will drill a new drain hole at the bottom rear as there is no effective drainage there.
Posted: Mon Jul 26, 2021 1:55 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
So, further disassembly of the door today. I removed the door check strap to gat access to clean the hinge area and stupidly thought I could retract the strap with the assembly out of the vehicle. The 44yr old rubber parts immediately snapped and I cursed under my breath. Luckily I have a spare door check strap, but it’s a shame to have done it.
My bright idea for the inaccessible inner door to prep for paint was to spray in concentrated degreaser, leave a while and then use a pressure washer to blast all the crap out. Worked a treat and then I used the airline to get rid of most of the water and left it to dry in the sun.
Posted: Tue Jul 27, 2021 1:29 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Slow progress on the doors.
I’m just doing the drivers door at the moment and the weather was good enough to rust treat the inside of the door, rinse and dry and get a couple of coats of rust encapsulator. It’s not perfect, but I’ll leave it for a few days and put in some sort of wax before the trim panel goes back on.
We are going camping at the end of the week. The doors won’t be finished, but we do need the locks and handles back on! I fitted the clean, lubed hardware and it is an absolute delight to use. I spent many happy minutes clicking the lock back and forwards and opening and shutting the door!
The replacement check strap is very good quality and is working very well. With my newfound knowledge I was able to carefully remove and clean the passenger side check strap without breaking it and it too works perfectly now. (The pic is the clean, original passenger side).
Posted: Sun Aug 01, 2021 10:55 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
I’ve almost (but not quite) finished the front door refreshment. They are both painted inside and I ‘just’ need to clean the lock mechanism on the passenger door.
However, I had an extra pair of hands today and so I took advantage by taking the sliding door off…
I wanted to clean and lubricate the hinge and rollers and I suspect the nylon block has broken recently, as it has started wobbling at the top roller.
Following a combination of Amskeptic and the Bentley I eventually got the track cover off, but it was pretty stuck with dust, grime and old paint. The track is of course filthy and in blowing away the loose dirt with the air line I revealed some rust at the lower edge of the track rails.
I was a bit despondent (as was my assistant!) but after cleaning, the rust does seem superficial, and not extending as far as the bend line in the bodywork, so I think I will be able to rub down to bare metal and prime and paint.
I’ve also cleaned the lower door track of grease and I will prep and paint that at the same time. The old seal has come out intact, so I will probably clean and reuse it.
Posted: Mon Aug 02, 2021 1:18 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
I had a day free today, so I set to cleaning up the slider tracks. Not pleasant, but there are worse profiles to rub down and clean. A combination of abrasive paper, scotchbrite pads, scrapers and degreaser eventually got everything reasonably clean.
I have decided to use phosphoric acid prep and a rust stable primer, which is applied with a brush so should get to all the slider track surfaces. Then white primer and body colour on top. I’ll give it as long as I can to cure, but I guess it is quite likely to rub off where the rollers run but it’s hard to avoid that.
I’m leaving the sliding door furniture until I have done the paint, and I have sourced a replacement bearing and nylon block for the hinge element.
The Volkswagen Ranch Samba Member
Joined: November 24, 2002 Posts: 700 Location: Arizona
Posted: Tue Aug 03, 2021 10:41 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Thank you for posting your progress….. I check on you every night! You are a few steps ahead of me, and keep me “ going”. You are doing a great job! Best Wishes, Bob _________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
Posted: Tue Aug 03, 2021 11:30 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
The Volkswagen Ranch wrote: |
Thank you for posting your progress….. I check on you every night! You are a few steps ahead of me, and keep me “ going”. You are doing a great job! Best Wishes, Bob |
Hi Bob, thanks for the post. I had a look at your thread and you are doing great work, there are so many similarities in our buses and the work you are doing. I suspect your bus has slightly better ‘bones’, as ours has suffered from 20 years in the Scottish climate (but was very solid before that).
I always feel I am making slow progress, but I guess that’s just the way it goes, I’m impressed you have made such a good recovery from your back problems.
I don’t have pics yet, but I spent the whole day yesterday masking up the channels and applying rust treatment. Then, just as I was ready to paint, it started raining! So, I moved the Kombi into the garage and brushed on two coats of rust treatment primer and hopefully I’ll be able to spray white primer today. Like you, I’m using colour matched rattle cans, and I find it can turn out pretty well for small areas. _________________ 1978 marino yellow Bay Dormobile camper
Posted: Wed Aug 04, 2021 8:34 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
In between coats of paint I started on the sliding door hardware.
Removal revealed that the hinge and roller assemblies were really caked in dirt and grease. I’m actually amazed that the door worked as smoothly as it did!
I haven’t disassembled for a proper clean yet but a toothbrush and kerosene, followed by some alcohol does at least mean I can see what’s what.
Can I be amazed also that the 44yr old felt washers under the rollers are still intact?! I wonder if I dare risk cleaning them a little?
It was a pleasure to clean off some ugly overspray on the hinge mechanism. It’s been bugging me for years!
As I had guessed, the nylon block is broken.
Posted: Wed Aug 04, 2021 10:40 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
You are doing just fine on your painting. If there’s any “ trick “‘to painting with rattle cans, I have learned that patience is the key. You have already noticed that it takes more paint of this particular color to bring up
the proper depth of color. The reason for this is that the amount of solids used to make our particular color have been reduced by EPA in the past few years. I have found that prepping a smooth surface followed by 2-3 coats of Rustoleum
“Filler primer” provides a good base for the final paint color. It is a medium grey color, and apply each coat as a thin coat. Let each dry 1/2 hour to 45 minutes. After coverage looks uniform, start applying the first 3 coats of color . Again, these are thin coats, using a “criss-cross” pattern . Again let each dry 30-45 minutes. On the 4th coat start laying down a thicker coat . You will know when you have it “ right” as it will cover evenly, and look like glass. Let this final coat dry over night. If you have an uneven coverage, too much paint, or not to your liking, just lightly sand with 2000 grit ( wet sand) then buff with Meguire’s
“ pro speed” compound with a variable speed buffer under 1800 RPM with a wool bonnet. Follow up with “ swirl remover “ and you will have the kind of finish you are looking for. I used single stage acrylic enamel to match the type of paint the MAACO shop used ( PO had it shot by MAACO). The paint job they did on the bus was maybe a 7/10. By using this method and touching up , it should look nice when I am done… many, many , many hours away from now. I may apply clear over the blended surfaces , we will see. Hope this helps. Bob _________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
