mcdonaldneal Samba Member
Joined: June 13, 2013 Posts: 2649 Location: Gullane, Scotland
Tcash Samba Member
Posted: Sun Jul 01, 2018 7:10 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Hay that Orange Dorm is awesome!
Tcash |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jul 01, 2018 7:22 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
I agree, those judges have no taste
Although that fabric bodied Austin (or whateverthehellitis) is really neat too. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
dasdachshund Samba Member
Joined: March 29, 2010 Posts: 728 Location: Vancouver, WA USA
Posted: Tue Jul 03, 2018 12:39 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Keep the weather happy for me!!!!!
Ohhhh, two more weeks!!!!
-dasdachshund |
Posted: Tue Jul 03, 2018 2:44 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
We've a couple of camping trips planned, but the last day we were out in the Kombi there was quite a smell of fuel. The consensus on another thread was that it is probably the 40year old fuel filler pipes, or the tank vent tubes.
So, I've ordered the replacement tubes (including the MB Sprinter angled fuel pipe to replace the NLA rubber between the tank and the filler pipe).
I'm going to have a good go at sorting it on Thursday, without dropping the engine, through the firewall and the 'pie plate' hole. You'll see how I get on!
It did occur to me that if I can remove all of the top of engine ancillaries and mask up, then maybe I could respray the inside of the engine compartment and battery tray areas. I suspect I'm being optimistic, but I'll let you know how it looks!
While the carbs are off, I'm going to go up a size on the main jets to try and reduce the overheating issue that I'm chasing down. More in the carb thread here:
PDSIT carbs on a 2.0l engine _________________ 1978 marino yellow Bay Dormobile camper
1969 signal orange Karmann Ghia convertible
1976 martini olive Bay Dormobile camper
Stop dead photo links! Post photos to The Samba Gallery! |
Posted: Thu Jul 05, 2018 6:16 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
mcdonaldneal wrote: |
I can’t remember a Summer like it Gill!
Fingers crossed it lasts, did you see this video clip from Gullane Hill a couple of weeks ago when they were starting preparations for the Scottish Open?
dasdachshund wrote: |
-dasdachshund |
Now THAT looks like a Scottish summer.
-dasdachshund |
Posted: Thu Jul 05, 2018 7:08 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
There is just enough room to wriggle the panel out into the daylight.
There seems to be the remains of a foam strip around the lower edges to make a seal, and the top had been 'sealed' with grey tape. Probably not factory!
Once I could see in to the fuel tank compartment, under the thick layer of dust (!) the hose between the tank and the filler pipe did seem to be suspiciously clean on the lower half, and in close-up you can see the perished rubber. Looks like a good call!
I'll replace the vent rubber connections too, the plastic lines measure about 7mm, so I'll use the larger 7mm fuel hose. I'm not looking forward to the one behind the spare wheel well (in fact, I'll leave it until last, maybe it won't get done!...)
Posted: Thu Jul 05, 2018 9:29 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Those hoses all look suspicious, things should be much less stinky now.
That to edge of the tank panel is mangled, it should be flat and sticking straight up, as it is now I doubt the sides will seal well. The grey tape was put there by VW.
To install the tank panel the top has to tuck up into a channel on the body first and then the bottom swings into place, it'll run into the tin over the flywheel so you'll either have to pry and mangle, or lower the engine a few inches. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
1970fun Samba Member
Posted: Thu Jul 05, 2018 11:21 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Pfew... those rubbers look bad, just in time!
I replaced mine 2 years ago when engine and gearbox were out just to be sure they had some cracks but not as bad as yours.
Is that sunshine i see those pics |
Posted: Thu Jul 05, 2018 12:32 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
1970fun wrote: |
You're right Harry, just in time, and yes, we're having the best Summer anyone can remember!
Thanks for the info busdaddy, the panel did come out without too much of a struggle, so I think it'll be ok..I've replaced the foam with some closed cell foam strip and I'll replace the grey tape with duct tape probably!
The new rubber at the filler looks poorer quality than the VW original that was on, but I'm pleased that the screw holes at the filler line up much better than the original one!
I've stalled now though, because the tank to filler pipe rubber hasn't arrived in the post, so I'll have to wait. I've replaced the carb jets though, so hopefully I'll be able to get everything back together when I get the rubber in the post. _________________ 1978 marino yellow Bay Dormobile camper
chimneyfish Samba Member
Joined: July 28, 2009 Posts: 881 Location: United Kingdom
Posted: Thu Jul 05, 2018 2:32 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
I'm not looking forward to the one behind the spare wheel well (in fact, I'll leave it until last, maybe it won't get done!...) |
There is an easier way. I'm 6ft tall but found it relatively easy to replace that tricky piece of hose under the spare wheel well when the rear of the vehicle was jacked up onto axle stands, as you are then able to do it pretty much standing up.
If the bus is not jacked up then attempting the job is a complete PITA, to the extent you give up on it, unless you are as nimble and short as Yoda that is. _________________ 1965 Type 1 Deluxe (1200cc)
1976 Type 2 T2b Microbus L (1800cc Type 4)
Previously...
1972 T2 Camper (Devon), 1988 Golf, 1972 Type 1, 1984 Polo, 1972 T2 Camper (Danbury) |
