campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Fri Aug 24, 2007 5:46 pm Post subject: |
Does this help?
dms Fred G. Sanford
Joined: August 05, 2007 Posts: 493 Location: At large. . .
Posted: Fri Aug 24, 2007 11:28 pm Post subject: deck lids |
Thank you everyone for the pics , I found my deck lid prop laying in the engine compartment . that answers a lot of questions . _________________ If you don't like the way I drive , stay off the sidewalk . |
Stocknazi Samba Member
Posted: Sat Aug 25, 2007 2:56 pm Post subject: |
yep, that pic shows me what i needed to know. it seems to be working correctly now. the long slot threw me off, made me think the tab should have slid in it when the lid is being closed. thanks for the pics. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Wademcgee Samba Member
Joined: September 14, 2002 Posts: 52 Location: Powder Springs, Ga.
Posted: Sat Nov 22, 2008 12:02 pm Post subject: OK gurus, I need some help |
I'm new to the bus world, but been into VWs for 2 decades. Not the smartest guy on the planet either, but I am an engineer... With all that being said I can NOT for the life of me figure out how this rear deck lid hinge is supposed to close when installed correctly. I have to pull the spring loaded portion out of its housing to get the deck lid to close. I assumed the hinge was broken by the P.O., so I replaced it. Hinge was perfect, along with the spring...same issue. It gets within about 1 inch or so and won't go a bit more. It would appear that the slot that allows the hinge to slide fore and aft should also have a vertical option for clearance. Please enlighten me and tell me I'm a complete moron and have been doing something very wrong for the last 3 weeks. HELP!!! The dam thing clanks like crazy just free hanging in there.
Regards,
Wade McGee
Tried to take the best pics that I could in all positions possible. _________________ Regards,
Wade McGee |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
Posted: Sat Nov 22, 2008 3:54 pm Post subject: What? |
I can't use the split spring type of prop, way not correct. I have the proper 62 stuff, but I think the previous owner (or someone down the line) re-welded the guts a bit low...thus messing up the pivot point.
I relocated the pivot point on the elbow by .75" and now it works like butter. I'll snap some pics tomorrow. I assumed they were factory welds on the mounts...suppose I was wrong.
Wade _________________ Regards,
Wade McGee |
Posted: Sat Nov 22, 2008 3:56 pm Post subject: Sorry |
I misunderstood what you meant. Now I see what you mean.
I guess I know have a Frankenstein setup...but it works. _________________ Regards,
Wade McGee |
Posted: Sat Nov 22, 2008 4:14 pm Post subject: Re: What? |
Wademcgee wrote: |
Wade |
That decklid is off a '66-'67 bus with the push button style latch setup. The early decklid uses a church key. Do you have the wrong apron too? |
Posted: Sat Nov 22, 2008 4:23 pm Post subject: Not sure |
This is my first "real" bus, so I'm a little in the dark. Chances are that I probably do have a later model apron and decklid. I never paid it much attention, the lines are dead on and seals perfectly. I assumed it was all proper. I guess I need to do some closer inspecting. _________________ Regards,
Wade McGee |
Posted: Sat Nov 22, 2008 4:28 pm Post subject: Re: Not sure |
Wademcgee wrote: |
This is my first "real" bus, so I'm a little in the dark. Chances are that I probably do have a later model apron and decklid. I never paid it much attention, the lines are dead on and seals perfectly. I assumed it was all proper. I guess I need to do some closer inspecting. |
My '62 panel was the same way.....had a later decklid and apron with no decklid prop. I ended up swapping them out for some correct '62 parts so I could run the stock decklid prop. Much better than the broom handle I was using before. |
Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1773 Location: Finland, Jakobstad
deepseeman Samba Member
Joined: January 13, 2004 Posts: 435 Location: san diego
Posted: Sun Jun 26, 2011 1:00 pm Post subject: |
anyone know where I can find a bracket?
_________________ in the barn:
61' Double Cab-restored driver
91 SYNCRO |
mrfallon Samba Member
Joined: June 15, 2006 Posts: 290 Location: Somewhere on American soil
Posted: Sun Jun 26, 2011 2:23 pm Post subject: |
I took the spring out of my 57 dove blue panel, and it was primered!!! Not sure if this is correct...but theres some insight for you |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Jeff Power Samba Member
Joined: October 13, 2004 Posts: 1170 Location: with any luck, in my garage building bass guitars.
Posted: Sun Jun 26, 2011 2:39 pm Post subject: Re: OK gurus, I need some help |
Wademcgee wrote: |
Not the smartest guy on the planet either, but I am an engineer... |
Classic _________________ I build complete Westy Style camping interiors check them out here > www.rjcampers.com
Check out my basses here www.ellabasses.com
jerry wrote: |
Nothing says "I love busses" more than picking up a mouse turd filled with horse hair seat padding |
Posted: Sun Jun 26, 2011 3:11 pm Post subject: |
thanks. guess I didnt search well enough. _________________ in the barn:
91 SYNCRO |
sventinker Samba Member
Joined: June 10, 2009 Posts: 1481 Location: the sandbox
Posted: Sun Jun 26, 2011 4:25 pm Post subject: |
Here's an NOS one I bought off a samba member I was going to use it but I found another. I have been trying to work something out with gerson so he can reproduce it but we haven't fully communicated yet. Ignore Yogi he was just there when it arrived.
_________________ April 3rd 62 standard mgr/pw
374 North American equipment
Includes 6 popouts
025 Safety belts
195 Adjustable bench seat/backrest (until 1963)
dawerks wrote: |
Perfection only comes with delusion. |
http://www.oacdp.org/ |
splitscreendreammachine Samba Member
Posted: Fri Oct 26, 2012 5:12 am Post subject: |
Has anyone a pic of the tab on the body ?
I need to build mine up with weld as it's just won't stay up , the slightest knock and the lid falls on my head .... I need to see an original non worn tab to work out what to do
many thanks in advance for any help
*UPDATE* may have sorted it tab was bent on the body ..... |
farnhamassoc Samba Member
Joined: February 16, 2010 Posts: 122 Location: Riverside ca
Posted: Tue Aug 27, 2013 10:40 am Post subject: VW the great marketing company |
I would like to find the engineer that designed that prop and fire him myself. Everybody says how great vw engineering is and I completely disagree.
Just look at that prop and tell me it will last 20 years. metal on metal wear. the bent tabs. Come on.
Vw has so many engineering flaws. But if you look at their marketing it is truly amazing. I actually begrudgingly have owned literally hundreds of VWs over the years including a TDI jetta which is what brought me back to VW after several years of my middle finger up at them. The truth is Nothing has changed. Still electronic and wiring issues. Many whaaaats. But how can you beat the MPG of a TDI 40-45. In the early years it was the same for me. A bug was a cheap and relatively good mpg car. _________________ Owned Countless VWs over the last 35 years.
Restored near 100 vws.
80 Rabbit diesel 1.9 TDI turbo 45mpg
06 Jetta TDI 45mpg
Restored several 11 window kombi and standard
Current inventory 66 delux hard top, so23
60 ragtop and 61 hard top bugs 54 hardtop bug
67 tin top so42 62 SO10 ruthmann bucket truck |
CaLiBus Samba Member
Posted: Wed Feb 17, 2016 10:48 am Post subject: |
EverettB wrote: |
You have a mid-64 to 1965 deck lid which uses the later prop spring assembly so it can't fold up correctly.
'63 with prop rod:
'64 with spring:
Note position of welded-on bracket |
Anyone have a picture of the bolt that attaches the prop to the lid mount ? |
