nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed Feb 17, 2016 11:34 am Post subject: Re: Early deck lid spring help needed! |
Which prop rod are you asking about? |
CaLiBus Samba Member
Posted: Wed Feb 17, 2016 12:35 pm Post subject: Re: Early deck lid spring help needed! |
Early style prop. Bug has a similar looking one. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
Posted: Thu Feb 18, 2016 8:15 pm Post subject: Re: Early deck lid spring help needed! |
Perfect. Thanks Everett ! |
Skylab Samba Member
Posted: Fri Jun 10, 2016 8:02 pm Post subject: Re: Early deck lid spring help needed! |
Success ! Thanks Guy's for the help! Photo's,Photo's,Photo's ! I couldn't have it with out the Photo's. Great Photo's ! Tks everyone! Mike..... |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Fri Jun 10, 2016 8:40 pm Post subject: Re: Early deck lid spring help needed! |
20 years of buses, I never knew about these springs until I found them on the Wolfsburg West site. Ordered them, got them, and then could not figure how to install them.
Then I found this thread. I installed them on a bus I'm rebuilding and then when I went to install them on my single cab found that the springs on both the treasure chest and decklid were both popped out of functional position but still hanging on the tang. Put both back into proper position and BOOM OG springs working great now. Very happy, thank you samba people _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
stephensog Samba Member
Joined: December 01, 2016 Posts: 24 Location: palmdale
Posted: Sat Mar 25, 2017 12:25 pm Post subject: |
My prop bracket seems to be mounted too far back? 1965.
thomspeed Samba Member
Joined: February 25, 2016 Posts: 27 Location: Sarastoa, Florida
Posted: Wed Jun 21, 2017 5:05 am Post subject: Re: Early deck lid spring help needed! |
Does the spring get painted? _________________ @saltworksfab on Instagram.
"Form Follows Function" |
Posted: Wed Jun 21, 2017 9:20 am Post subject: Re: Early deck lid spring help needed! |
thomspeed wrote: |
Does the spring get painted? |
This black spring?
I think that is just black plating, not paint.
It looks like it does have some overspray on it though - maybe they painted the Bus with that spring installed?
My Sealing Wax Red Truck is the same - I see red on the spring _________________ How to Post Photos
Posted: Wed Jun 21, 2017 12:17 pm Post subject: Re: Early deck lid spring help needed! |
thank you. _________________ @saltworksfab on Instagram.
mastorna Samba Member
Posted: Wed Jun 21, 2017 12:54 pm Post subject: Re: Early deck lid spring help needed! |
My 1962 OG paint absolutely has paint all over it. Its been used and the paint has def chipped off but I cleaned it up and the center coil def has OG paint. _________________ 1959 Type II Mango SO-23
1962 Type II Kombi Light Gray
1963 Type II Standard Sunroof SWR\BG
1963 Type II Deluxe MG\PW |
gitchesum Samba Member
Joined: November 10, 2003 Posts: 513 Location: North Cali
Posted: Thu Jul 20, 2017 8:14 am Post subject: Re: Early deck lid spring help needed! |
Thanks guys for those great photos....Now I just need to find a treasure chest door lock. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go... |
Joined: December 09, 2015 Posts: 42 Location: richmond,va.23221
Posted: Mon Sep 17, 2018 6:54 pm Post subject: Re: Early deck lid spring help needed! |
Thanks Guys, Awesome photos! |
thuestis Samba Member
Joined: September 07, 2012 Posts: 80 Location: brentwood, tn
Posted: Sun Jul 14, 2019 6:51 am Post subject: Re: Early deck lid spring help needed! |
Guys, looking for some advice concerning my engine lid. Unfortunately a garage door mishap pushed my engine lid closed while it was propped open.
Good news is there was no damage to the engine lid. But now the engine lid stay does not hold it as securely as it used to. I would like to adjust the mechanism so that the lid stays more securely.
What methods or techniques have you used to make the lid stay more securely open? I presume it might be slightly bending something or tweaking something.
Thanks in advance. |
Posted: Sun Jul 14, 2019 7:32 am Post subject: Re: Early deck lid spring help needed! |
It looks ok in that photo.
Is it closing on you without releasing it or ?
Maybe the piece on the body that it sits on when open got bent?
I would remove the deck lid prop and take a look at how everything looks off the vehicle.
Is the entire decklid prop still straight?
The piece that goes up to the decklid with the bolt should be straight too and the bracket welded to the decklid should be at a 90-degree angle - sometimes that gets bent.
This bracket, as seen on my Bus
(It's a little bit tweaked) _________________ How to Post Photos
Posted: Sun Jul 14, 2019 10:30 am Post subject: Re: Early deck lid spring help needed! |
Everett,
Thank you very much for your response.
The decklid after being struck by the closing garage door, now when propped up will release to close at the slightest of touch.
Want to try to get the lid to hold more securely when in the upright position.
Will follow your advice! |
Posted: Sun Jul 14, 2019 2:30 pm Post subject: Re: Early deck lid spring help needed! |
Everett,
Followed your advice and took off the lid arm. Bent it in a couple of places & now it holds the lid fine.
Really appreciate all that you do for the VW community!!!! |
Walk Thru KO Samba Member
Joined: August 14, 2003 Posts: 156 Location: North Carolina
