Engine does not fit on transmission
05gh
05gh is offline
PostPosted: Thu Jul 24, 2014 1:22 pm    Post subject: Engine does not fit on transmission Reply with quote
I have a 1963 double door panel van. I think the transmission and engine do not belong to this bus. But anyway i will use them but the engine does not fit on the transmission. Wich modification or adaptor do I need. The transmission is the model with the reduction box and the engine is a 1600. See pictures
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Jul 24, 2014 1:24 pm    Post subject: Reply with quote
Most likely trying to fit a 200mm flywheel into a 6v tranny.
You need to do some grinding of the tranny case for it to fit.
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
mandraks
mandraks is offline
PostPosted: Thu Jul 24, 2014 1:53 pm    Post subject: Reply with quote
As always when you are not 100% sure what you are trying to match up, find out.
if you are putting a 12 volt motor with the 200mm fly wheel on a transmission that was last used in a 6 volt car with a 180mm fly wheel, you will need to look at the entire clutch and throwout bearing assembly. Just by a kit that includes all pieces matching.
it is typically very easy (and backyard mechanicy) to just "machine" the tranny with the flywheel during installation. Turn it over with the starter.
make sure you use a 12 volt starter matching your flywheel. This might require some fitment into the actual transmission case, (bushing or no bushing)
Ultimately, it will fit, no doubt
regards
Uli
05gh
05gh is offline
PostPosted: Thu Jul 24, 2014 2:12 pm    Post subject: Reply with quote
Thanks for sharing the photo's, (the flyweel is 275mm)
Mr. 010
Glenn is offline
PostPosted: Thu Jul 24, 2014 2:21 pm    Post subject: Reply with quote
200/180 refers to the clutch size, not the total diameter of the flywheel.
Glenn
mandraks
mandraks is offline
PostPosted: Thu Jul 24, 2014 2:29 pm    Post subject: Reply with quote
good point, should have worded this better somehow....
maybe a 12volt flywheel for a 200mm clutch? tranny from a 6volt car with 6 volt flywheel?
regards
Uli
05gh
05gh is offline
PostPosted: Thu Jul 24, 2014 2:41 pm    Post subject: Reply with quote
starter 6 or 12V ? and how do I measure the flywheel diameter?
Mr. 010
Glenn is offline
PostPosted: Thu Jul 24, 2014 2:47 pm    Post subject: Re: Engine does not fit on transmission Reply with quote
You have a 200mm flywheel.
Glenn
Eric&Barb
Eric&Barb is offline
PostPosted: Fri Jul 25, 2014 5:31 pm    Post subject: Reply with quote
That starter cover was used on both 6 and 12 volt self supporting starters..
Count how many teeth on the flywheel. You could have a 12 volt or 6 volt geared flywheel.
In Stereo, Where Available!
05gh
05gh is offline
PostPosted: Sun Jul 27, 2014 12:03 pm    Post subject: Reply with quote
flywheel has 132 teeth and the starter 9
BarryL Premium Member
BarryL is offline
PostPosted: Sun Jul 27, 2014 12:36 pm    Post subject: Reply with quote
12.06 volt for you unless you have 130 teeth then it's 12 volt.
Starter is 12 volt.
