1968 Ghia ignition replacement
jpjohns
jpjohns is offline
PostPosted: Thu Jul 24, 2014 8:38 pm    Post subject: 1968 Ghia ignition replacement Reply with quote
I couldn't find much info on replacing the ignition assembly on '68 Ghias so I figured I'd take pics while I did mine.
So, after you have the steering wheel off and have removed the turn signal ring, you will need to remove two screws to slide off the ignition cover.
The ignition assembly will slide right out.
You will need to use a small point to press in the locking tab on the lock cylinder. I used a pen tip.
There is a retaining pin pressed into the housing to hold down the coupler and spring. Press this out with needle nose pliers. It will not come out all the way.
Coupler removed
The ignition switch slides into the bottom of the housing and is secured by a small threaded pin. Remove this pin and slide out the switch.
Be careful, mine came out in pieces and the metal can stuck inside and had to be soaked in penetrating oil to remove it. Be very careful trying to pry it out if it is stuck as the housing is made of very soft pot metal and will crack easily!
New switch just slides into the housing and secures with the threaded pin
Just a tiny bit of blue Loctite is all you need.
When reinstalling the coupler, note the shape of the pin as it fits a certain way into the switch. Also, the cutout on the left must clear the notch inside the can.
I added a little white lithium grease before installing the coupler.
The tab on the bottom of the lock cylinder fits into the hole on the coupler.
The only problem I had with the reproduction lock cylinder is that it had no cutout for clearance of the pin that holds the coupler down and doesn't allow the lock cylinder to slide in and clip into place.
This is the notch on the OEM cylinder
A Dremel with a metal cutting bit will make a quick notch on the repro cylinder.
The lock cylinder will now push in far enough to snap into place and can be installed back into the steering lock column.
I hope this helps. Main thing is be careful with the ignition housing because it's so soft. I tried prying the old switch can out but it quickly started to distort and gouge the housing. Needless to say I stopped and just soaked it.
Good luck!
-Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member)
sputnick60
sputnick60 is offline
PostPosted: Thu Jul 24, 2014 11:40 pm    Post subject: Reply with quote
Excellent write up! Makes me want to get a '68 Laughing
I'm sure John will be here soon and will turn this into a stickie!
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
2014 Passat B7 130TDI wagon (cheats in tests)
"Have no fear of perfection - you'll never reach it."(Salvador Dali)
John Moxon Premium Member
John Moxon is offline
PostPosted: Fri Jul 25, 2014 12:27 am    Post subject: Reply with quote
Yep added to the "How To" sticky at the top of the Ghia Section.
Great write up...many thanks Jared. Very Happy
John.
dcat917
dcat917 is offline
PostPosted: Fri Jul 25, 2014 10:15 am    Post subject: Reply with quote
Kudos, that was a great article and DIY info.
1981 Puma GTB http://www.thesamba.com/vw/forum/viewtopic.php?p=7794566#7794566
1971 Karmann Ghia http://www.thesamba.com/vw/forum/viewtopic.php?t=591290&highlight=
Past Projects:
1951 Studebaker Business Coupe https://goo.gl/photos/eHPuNo89m9PXZwBM8
1953 Studebaker 2-Door Sedan https://goo.gl/photos/pe38HEShzUrVSwcV8
jpjohns
jpjohns is offline
PostPosted: Fri Jul 25, 2014 2:23 pm    Post subject: Reply with quote
Thanks, I hope I helps someone.
-Jared
Mrfun2fly
Mrfun2fly is offline
PostPosted: Sat Feb 13, 2016 10:16 pm    Post subject: Re: 1968 Ghia ignition replacement Reply with quote
Jared,
I noticed your old ignition had only 3 wires but the new ignition has 4 (the grey is extra). What did you do with the grey wire?
Thanks,
Lee
jpjohns
jpjohns is offline
PostPosted: Mon Feb 15, 2016 10:22 am    Post subject: Re: 1968 Ghia ignition replacement Reply with quote
The grey wire isn't used.
-Jared
Mrfun2fly
PostPosted: Mon Feb 15, 2016 10:36 am    Post subject: Re: 1968 Ghia ignition replacement Reply with quote
Jared,
Just to be clear, the key switch part actually needs to be removed to install the electronic portion of the ignition?
Thanks!
jpjohns
jpjohns is offline
PostPosted: Wed Feb 17, 2016 12:26 am    Post subject: Re: 1968 Ghia ignition replacement Reply with quote
If you are just replacing the switch, it goes in the bottom. Theres a small flat head screw that has to be removed to get the switch out but it helps to remove the key housing too.
-Jared
xzener
xzener is offline
PostPosted: Wed Oct 26, 2016 6:27 pm    Post subject: Re: 1968 Ghia ignition replacement Reply with quote
Was about to ask about the 4-wire part I received... Thank goodness I found this thread. Very informative. My 68's ignition has been rebuilt, now to shove it in and wire it up. Thanks everyone!!
My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>!
kiwighia68
kiwighia68 is offline
PostPosted: Wed Oct 26, 2016 9:29 pm    Post subject: Re: 1968 Ghia ignition replacement Reply with quote
Hi Jared
Since you're the expert on this, please help me solve this problem. My '68 Ghia has the original switch and key. When I turn the ignition on, the key does not jump back to a neutral position, with the result that the starter motor keeps running until I manually move the key back to neutral.
I have a new switch - the part you replaced. Before I start replacing things I'd like to know where you think the problem lies. Please.
Chris M
Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015
BulliBill
BulliBill is offline
PostPosted: Wed Sep 13, 2017 7:50 am    Post subject: Re: 1968 Ghia ignition replacement Reply with quote
It looks like I'll be doing this on a Jan of 1970 production Ghia Coupe soon. I imagine that the process so very well shown above on a 1968 will be fairly similar on a 1970, but if anyone has done this on a 1970, can you add any details and differences in the process? I believe that the electrical switch is broken on mine, I think the key mechanism is fine and will attempt to re-use that. I ordered the switch from KGPR and it looks similar to the one used in the '68 above with four wires. So am I also NOT using the grey wire at all in my 1970 Ghia? Thanks for any advice! I'm not looking forward to this, but until I pull this repair off, I can't drive my old Ghia...
Bill
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
swavananda
swavananda is offline
PostPosted: Wed Sep 13, 2017 9:41 am    Post subject: Re: 1968 Ghia ignition replacement Reply with quote
Bill
The gray wire is for the 'key left in' buzzer. Your choice to still use it or not.
I was doing "Van Life" way before there was ever such a thing.
https://www.thesamba.com/vw/forum/viewtopic.php?t=489454
BulliBill
PostPosted: Wed Sep 13, 2017 9:50 am    Post subject: Re: 1968 Ghia ignition replacement Reply with quote
I would probably hook up the key buzzer reminder feature with that gray wire. When looking at my original dirty harness, what wire or connector or terminal do I hook that gray wire to? Do you know the color or combination of colors of the wire in the old original harness that the new grey wire should make too? I have an original dealership wiring diagram for my 70 guia to refer to, just need to find what that grey wire should connect to.
Thanks so much for the speedy reply and advice. My symptom initially was that I would turn the key to the on position and then continue to turn it all the way to "start" position and the engine would crank over and fire up, but when I release the key to spring back to the "on" position the engine would die. So I cannot get the engine to run without repairing what I assume is the electrical part of the ignition switch. Thanks again!
Bill
BulliBill
PostPosted: Fri Sep 15, 2017 12:19 pm    Post subject: Re: 1968 Ghia ignition replacement Reply with quote
Hi all,
I got tired of dicking around with the Ghia and not being able to drive it, so I decided to jerry-rig the brand new new switch in and unplug the old switch still in the steering column of my 1970 Ghia. I wanted to test it in a way that I could definitely confirm that the original electrical switch in the column was the culprit of my non running issues. So I unplugged the wires behind the dashboard to the fuse box and light switch from the original electrical switch. Then I wired in the new switch and plugged it up and left it laying loose up in the front trunk area. Then i hooked up the battery and held my breath and used a screwdriver to simulate the key and turn the switch to "start" and back to "on/run". The new switch worked like a charm! It was so good to hear that 1776 running after about 2 years of sitting in the garage. So good that I left everything the way I wired it and took the car out for a 25 mile drive to run some fuel through it and Ponder my next move. Now I will have to take the Formuling France steering wheel off the column and take apart the ignition switch/lock assembly and remove the old original electrical switch and reinstall the new one and putting everything back together. I might even re-install the stock steering wheel again, who knows? Great to hear the Ghia running again!
If I remember. I will try to take some photos of the process to add to this thread concerning a January of 1970 production Ghia switch replacement...
Bill Bowman
sputnick60
PostPosted: Fri Sep 15, 2017 4:25 pm    Post subject: Re: 1968 Ghia ignition replacement Reply with quote
Glad to read you had a moment of enjoyment with your Ghia. Endless problem solving gets old ofter a time but getting out on the road is a joy.
Yes, please do add to the thread, we all enjoy well documented contributions in that regard.
Nicholas
xzener
xzener is offline
PostPosted: Fri Sep 15, 2017 5:00 pm    Post subject: Re: 1968 Ghia ignition replacement Reply with quote
And don't use third party picture hosting. Wink
PostPosted: Fri Sep 15, 2017 11:57 pm    Post subject: Re: 1968 Ghia ignition replacement Reply with quote
Haha...Bill posting 3rd party...wash your mouth out. Laughing
John.
BulliBill
PostPosted: Sat Sep 16, 2017 7:11 am    Post subject: Re: 1968 Ghia ignition replacement Reply with quote
I didn't post ANY photos yet in my above posts. I'm assuming the comment from "xzener" was a preemptive warning? I have NEVER used third part photo hosting, I have ALWAYS hosted any photos that I have right on the Samba gallery. Did I do something wrong, did I miss something? Are you guys are "harshing my Ghia buzz"?
Bill Bowman
xzener
xzener is offline
PostPosted: Sat Sep 16, 2017 7:23 am    Post subject: Re: 1968 Ghia ignition replacement Reply with quote
Just a friendly reminder. Smile
